[GeoNode-devel] Using "/" as SITEURL
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Mar 19 01:56:24 PDT 2018
Currently is hard to say.
The response is, yes, it could be feasible but the whole code should be
reviewed in order to catch places where relative urls are not taken into
account.
As far as I know, for the moment everywhere the assumption is that SITEURL
is absolute.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-03-16 3:49 GMT+01:00 Olivier Dalang <olivier.dalang at gmail.com>:
> Hi !
> When serving one Geonode instance using different host names or schemes
> (e.g. LAN/WAN ip, HTTP/HTTPS, multiple domain names), one would have to use
> "/" as SITEURL, so that absolute urls refer to the same scheme/domain.
> When doing so, I get the following exception when creating layers
> programmatically or running the updatelayers command
>   File "/usr/local/lib/python2.7/site-packages/geonode/base/models.py",
> line 940, in resourcebase_post_save
>     if urlsplit(settings.SITEURL).hostname not in link.url:
> It seems it is assumed that SITEURL is an absolute URL including scheme
> and host name.
> The bug would be very easy to fix, but since it seems to be assumed
> SITEURL must be absolute, I was wondering if there may be some side effects
> in using "/" as SITEURL ?
> If there are no side-effects, wouldn't it be good to have "/" as a default
> instead of " http://localhost:8000/" ?
> Thanks !
> Olivier
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180319/ec702df7/attachment.html>
More information about the geonode-devel mailing list
