[GeoNode-devel] Bulk update: Django 1.11.11 / ArcGis Remote Services / PyCSW 2.2.0 / Fixed Celery configuration with timeouts / Download Layer Raw Data / Proxy GeoServer Endpoints
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Mar 23 02:25:15 PDT 2018
Dear all,
few notes on GeoNode improvements on master (aka development) branch wich
we would like to port soon.
First of all about the PR:
The PR https://github.com/GeoNode/geonode/pull/3674 is a cumulative PR
meant to allow you to test the new features all together.
This is not meant to be merged, but it should be used to test and create
fixes accordingly.
Please, read the PR description in order to understand what have been
improved.
There are important fixes on security. In particular major protection of
Proxies that were exposed to several weakness before (CSFR attacks, man in
the middle, and others...)
Django 1.11
The most interesting improvement is about Django version. That PR allows
GeoNode to work against the latest Django 1 series version.
Currently this arised a couple of severe issues on GeoNode. Basically old
versions somehow did not handle correctly celery and messages. With the
update those now work as expected and evidenced some issues on the workflow
that were hidden before.
Almost all of them have been fixed. Fixes have been applied on all the
codebase.
Issues preventing to upgrade to Django 1.11
Currently all the old tests have been improved and adapted.
There is a blocker on qgis-server integration. It seems mostly an issue
with travis scripts (or paver). Basically the live instance of qgis seems
to not be active during travis tests.
This should be fixed soon, or qgis-server downgraded to contrib module and
disabled by default.
Please send comments and feedbacks.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180323/423fd6dd/attachment.html>
More information about the geonode-devel mailing list
