[GeoNode-devel] Geonode Installation from Source - WSGI ISSUE
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed May 9 10:26:31 PDT 2018
I would like to add my geonode.conf file bellow and make a note that my
virtualenv directory Envs is the root's home.
WSGIDaemonProcess geonode
python-path=/home/geonode/my_geonode:/root/Envs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2
<VirtualHost *:80>
    ServerName http://localhost
    ServerAdmin webmaster at localhost
    DocumentRoot /home/geonode/my_geonode/my_geonode
    LimitRequestFieldSize 32760
    LimitRequestLine 32760
    ErrorLog /var/log/apache2/error.log
    LogLevel warn
    CustomLog /var/log/apache2/access.log combined
    WSGIProcessGroup geonode
    WSGIPassAuthorization On
    WSGIScriptAlias / /home/geonode/my_geonode/my_geonode/wsgi.py
    Alias /static/ /home/geonode/my_geonode/my_geonode/static_root/
    Alias /uploaded/ /home/geonode/my_geonode/my_geonode/uploaded/
    <Directory "/home/geonode/my_geonode/my_geonode/">
         <Files wsgi.py>
             Order deny,allow
             Allow from all
             Require all granted
         </Files>
        Order allow,deny
        Options Indexes FollowSymLinks
        Allow from all
        IndexOptions FancyIndexing
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/static_root/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/thumbs/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/avatars/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/people_group/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/group/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/documents/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/geonode/my_geonode/my_geonode/uploaded/layers/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Proxy *>
        Order allow,deny
        Allow from all
    </Proxy>
    ProxyPreserveHost On
    ProxyPass /geoserver http://127.0.0.1:8080/geoserver
    ProxyPassReverse /geoserver http://127.0.0.1:8080/geoserver
</VirtualHost>
Thank you very much for your time
Julierme
2018-05-09 14:03 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> HI Geonode developers !!!
> After following geonode installation guide
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/>
> on an Ubuntu 16.04 VM, I got the following error message in the browser as
> a response for http://localhost
> Internal Server Error
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator at webmaster at localhost to inform
> them of the time this error occurred, and the actions you performed just
> before this error.
> More information about this error may be available in the server error log.
> Apache/2.4.18 (Ubuntu) Server at localhost Port 80
> Geoserver *2.12-SNAPSHOT* is running like a charm, but my Geonode does
> not start up. Find bellow apache2 error,log:
> [Wed May 09 12:36:14.268403 2018] [wsgi:warn] [pid 1391:tid
> 140437432260480] mod_wsgi: Compiled for Python/2.7.11.
> [Wed May 09 12:36:14.268425 2018] [wsgi:warn] [pid 1391:tid
> 140437432260480] mod_wsgi: Runtime using Python/2.7.12.
> [Wed May 09 12:36:14.271376 2018] [mpm_event:notice] [pid 1391:tid
> 140437432260480] AH00489: Apache/2.4.18 (Ubuntu) mod_wsgi/4.3.0
> Python/2.7.12 configured -- resuming normal operations
> [Wed May 09 12:36:14.271409 2018] [core:notice] [pid 1391:tid
> 140437432260480] AH00094: Command line: '/usr/sbin/apache2'
> [Wed May 09 13:34:03.434306 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709] mod_wsgi (pid=2091): Target
> WSGI script '/home/geonode/my_geonode/my_geonode/wsgi.py' cannot be
> loaded as Python module.
> [Wed May 09 13:34:03.434374 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709] mod_wsgi (pid=2091): Exception
> occurred processing WSGI script '/home/geonode/my_geonode/my_
> geonode/wsgi.py'.
> [Wed May 09 13:34:03.434427 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709] Traceback (most recent call
> last):
> [Wed May 09 13:34:03.434461 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]   File
> "/home/geonode/my_geonode/my_geonode/wsgi.py", line 44, in <module>
> [Wed May 09 13:34:03.434593 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     application =
> get_wsgi_application()
> [Wed May 09 13:34:03.434616 2018] [wsgi:error] [pid 2091:tid
> "/usr/local/lib/python2.7/dist-packages/django/core/wsgi.py", line 14, in
> [Wed May 09 13:34:03.435240 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     django.setup()
> [Wed May 09 13:34:03.435269 2018] [wsgi:error] [pid 2091:tid
> "/usr/local/lib/python2.7/dist-packages/django/__init__.py", line 17, in
> setup
> [Wed May 09 13:34:03.441804 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     configure_logging(settings.LOGGING_CONFIG,
> settings.LOGGING)
> [Wed May 09 13:34:03.441843 2018] [wsgi:error] [pid 2091:tid
> "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line
> 48, in __getattr__
> [Wed May 09 13:34:03.442576 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     self._setup(name)
> [Wed May 09 13:34:03.442599 2018] [wsgi:error] [pid 2091:tid
> 44, in _setup
> [Wed May 09 13:34:03.442635 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     self._wrapped =
> Settings(settings_module)
> [Wed May 09 13:34:03.442653 2018] [wsgi:error] [pid 2091:tid
> 92, in __init__
> [Wed May 09 13:34:03.442682 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     mod =
> importlib.import_module(self.SETTINGS_MODULE)
> [Wed May 09 13:34:03.442707 2018] [wsgi:error] [pid 2091:tid
> "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
> [Wed May 09 13:34:03.443265 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709]     __import__(name)
> [Wed May 09 13:34:03.443311 2018] [wsgi:error] [pid 2091:tid
> 140437323732736] [remote 127.0.0.1:18709] ImportError: No module named
> my_geonode.settings
> [Wed May 09 13:34:05.395421 2018] [wsgi:error] [pid 2092:tid
> 140437323732736] [remote 127.0.0.1:18709] mod_wsgi (pid=2092): Target
> [Wed May 09 13:34:05.395485 2018] [wsgi:error] [pid 2092:tid
> 140437323732736] [remote 127.0.0.1:18709] mod_wsgi (pid=2092): Exception
> geonode/wsgi.py'.
> [Wed May 09 13:34:05.395536 2018] [wsgi:error] [pid 2092:tid
> last):
> [Wed May 09 13:34:05.395587 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.395720 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.395742 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.395814 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.395839 2018] [wsgi:error] [pid 2092:tid
> setup
> [Wed May 09 13:34:05.395909 2018] [wsgi:error] [pid 2092:tid
> settings.LOGGING)
> [Wed May 09 13:34:05.395935 2018] [wsgi:error] [pid 2092:tid
> 48, in __getattr__
> [Wed May 09 13:34:05.396047 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.396068 2018] [wsgi:error] [pid 2092:tid
> 44, in _setup
> [Wed May 09 13:34:05.396099 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.396117 2018] [wsgi:error] [pid 2092:tid
> 92, in __init__
> [Wed May 09 13:34:05.396144 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.396168 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.396243 2018] [wsgi:error] [pid 2092:tid
> [Wed May 09 13:34:05.396281 2018] [wsgi:error] [pid 2092:tid
> my_geonode.settings
> This issue was discussed here
> <https://lists.osgeo.org/pipermail/geonode-devel/2015-September/000361.html>
> but the solutions did not help me. Does anyone has faced the same problem?
> And could help me to figure out how to fix it?
> Thank you for your time in advance
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180509/86fce5d8/attachment-0001.html>
More information about the geonode-devel mailing list
