[GeoNode-devel] Release schedule proposal for GeoNode 2.8.1 and 2.10.0 versions
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed May 16 05:53:01 PDT 2018
*2.8.0 -> 2.8.1*
Mostly bugfixes. The only new relevenat features are:
 - Download Original Dataset link
 - Monitoring contrib module make use of GeoIP2
 - RemoteServices support for ArcGIS Map layers and GeoNode harvesing
 - api/layers API change -> added more metadata fields
 - Support for native projections
 - Support GeoServer 2.13.x
Migrations:
 - ResourceBase: added "uploadsession" foreign key
 - Layers: altered file filed in order to upload to date-time subfolder
You can see the detailed list of changes from here
https://github.com/GeoNode/geonode/pull/3809/files
*2.8.1 -> 2.10.0*
Differences are only on Django version and test runner
*apt-get*
Unless I am able to find some time to work on debian package (or there's
some volunteer work), apt-get install won't be able to update the code by
itself.
Nevertheless it can still be done manually. Probably I can send
instructions to do that.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
2018-05-16 14:34 GMT+02:00 Dave Kennewell <davekennewell at gmail.com>:
> Can I ask - are there new features from 2.8.0 -> 2.8.1 or is it bugfixes?
> If there are new features, particularly new database migrations, can we
> maintain a way to remain on 2.8.0 using the apt-get install? If it's a
> problem, I can create an EC2 image of the current 2.8.0 and install from
> that, but I suspect other users might not have the same luxury?
> And out of curiosity, is there a change log for 2.8 -> 2.10?
> Thanks Alessio!
> On 16 May 2018 at 16:22, Alessio Fabiani-2 [via OSGeo.org] <
> ml+s1560n5364550h65 at n6.nabble.com> wrote:
>> Dear dev and users lists,
>> I would like to propose a time schedule for the GeoNode releases:
>> - 2.10.0; based on Django 1.11.11
>> - 2.8.1; based on Django 1.8.19
>> Since, in terms of issues, they look stable enough to be published, I
>> would like to release them in a week or so.
>> Unless there are complains about that, I would call for an hardening week
>> starting from today and then pushing out the releases on Thursday (24) or
>> Friday (25) next week.
>> In the meantime would be good to spot all potential several issues which
>> might block the release process.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>> (LU)
>> Italy
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5364550&i=0>
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Release-schedule-proposa
>> l-for-GeoNode-2-8-1-and-2-10-0-versions-tp5364550.html
>> To unsubscribe from GeoNode, click here
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5185390&code=ZGF2ZWtlbm5ld2VsbEBnbWFpbC5jb218NTE4NTM5MHwtOTI1NjEyMTk0>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> geonode-devel at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180516/0c14576f/attachment-0001.html>
More information about the geonode-devel mailing list
