[GeoNode-devel] Commiting Geonode-Project Changes to Geonome Production
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed May 16 12:40:55 PDT 2018
Hi all,
I finally got to solve this problem. The issue was related to geonode.conf.
After some tests I concluded that for my case:
DocumentRoot  and Alias /uploaded/ could be either
/home/my_geonode/my_geonode/my_geonode or
/home/geonode/my_geonode/my_geonode
However, for the rest of the configuration, this was the final settings:
WSGIDaemonProcess geonode
python-path=/home/geonode/my_geonode:/home/geo/Envs/geonode/lib/python2.7/site-packages
user=www-data threads=15 processes=2
<VirtualHost *:80>
    ServerName http://localhost
    ServerAdmin webmaster at localhost
    DocumentRoot /home/my_geonode/my_geonode/my_geonode
    LimitRequestFieldSize 32760
    LimitRequestLine 32760
    ErrorLog /var/log/apache2/error.log
    LogLevel warn
    CustomLog /var/log/apache2/access.log combined
    WSGIProcessGroup geonode
    WSGIPassAuthorization On
    WSGIScriptAlias / /home/my_geonode/my_geonode/my_geonode/wsgi.py
    Alias /static/ /home/my_geonode/my_geonode/my_geonode/static_root/
    Alias /uploaded/ /home/my_geonode/my_geonode/my_geonode/uploaded/
    <Directory "/home/my_geonode/my_geonode/my_geonode/">
         <Files wsgi.py>
             Order deny,allow
             Allow from all
             Require all granted
         </Files>
        Order allow,deny
        Options Indexes FollowSymLinks
        Allow from all
        IndexOptions FancyIndexing
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/static_root/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/thumbs/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/avatars/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory
"/home/my_geonode/my_geonode/my_geonode/uploaded/people_group/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/group/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/documents/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/layers/">
        Order allow,deny
        Allow from all
        Require all granted
    </Directory>
    <Proxy *>
        Order allow,deny
        Allow from all
    </Proxy>
    ProxyPreserveHost On
    ProxyPass /geoserver http://127.0.0.1:8080/geoserver
    ProxyPassReverse /geoserver http://127.0.0.1:8080/geoserver
</VirtualHost>
Thank you all for the patience.
I appreciated it
Julierme
2018-05-16 13:08 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Hi All,
> I had try to commit genode-project template (index.html) changes to
> geonode production installed via apt-get, but I had an issue related to the
> production database. After configuring geonode.conf, I could see the
> changes over geonode production templates, made through geonode-project,
> however my production database would get covered / disappeared after
> geonode.conf according to geonode-project WSGI.
> So, I changed my approach and I installed geonode from source as in here:
> http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/
> I have geonode production running in virtualenv directory "/home/geo/Envs"
> and it is found in /home/geonode/my_geonode/*
> I have geonode-progect in the same virtualenv directory "/home/geo/Envs"
> and it is found in /home/my_geonode/my_geonode/*
> I installed geonode-project as in here https://github.com/GeoNode/
> geonode-project (Using Virtualenv)
> Now, I am having the same issue, my production database "development.db" =
> sqlite that is in ~/Envs/geonode/lib/python2.7/site-packages/geonode/development.db
> is being covered or disappears after geonode.conf configuration.
> I have granted all permissions  to development.db (-rwxrwxrw- 1 www-data
> www-data 425984 Mai 14 13:40 development.db) but the issue remains and I am
> unable to sign in to geonode production.
> Could someone help me to figure out what is going on and get this problem
> fixed? Find bellow my geonode.conf
> WSGIDaemonProcess geonode python-path=/home/my_geonode/
> my_geonode:/home/geo/Envs/my_geonode/lib/python2.7/site-packages
> <VirtualHost *:80>
>     DocumentRoot /home/geonode/my_geonode/my_geonode
>     LogLevel warn
>          <Files wsgi.py>
>              Order deny,allow
>              Allow from all
>              Require all granted
>          </Files>
>         Order allow,deny
>         Allow from all
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>     <Directory "/home/my_geonode/my_geonode/my_geonode/uploaded/people_
> group/">
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>         Order allow,deny
>         Allow from all
>         Require all granted
>     </Directory>
>     <Directory "/home/my_geonode/my_geonode/">
>         Order allow,deny
>         Require all granted
>     </Directory>
>     <Proxy *>
>         Order allow,deny
>         Allow from all
>     </Proxy>
> </VirtualHost>
> Thank you for your time in advance
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180516/2ed5e082/attachment.html>
More information about the geonode-devel mailing list
