[GeoNode-devel] [GeoNode-users] Geonode-Project: Apache Config / geonode.conf
Francesco Bartoli xbartolone at gmail.com
Thu May 17 09:16:11 PDT 2018
Once you have installed GeoNode as a library/package in your my_geonode virtual environment did you see your custom text and tabs changes starting the development server? That means “python manage.py run server” ?
Once you’ll get this achievement then the apache configuration will be easier.
Hope this helps
Francesco
Il giorno 17/mag/2018, alle ore 18:01, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> ha scritto:
> Dear Framcesco,
> Thank you very much for your reply. I have gone through http://geonode.org/dev-workshop/#/ several times. It is a great source, but again this issue was related to geonode.conf /apache2 config.
> I got to fix this problem making changes to geonode.conf. In my case, if I have geonode production in /home/geonode and geonode-project in /home/my_geonode, the geonode.conf must have all information related to geonode-project, and I was still gathering information from geonode-production in geonode.conf.
> I appreciated your time and help.
> Kind regards
> Julierme
> 2018-05-17 12:17 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> Dear Julierme,
> I encourage you to follow scrupulously the developer workshop where everything you are trying to do is well covered http://geonode.org/dev-workshop/#/.
> Francesco
> Il giorno 17/mag/2018, alle ore 17:06, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear all geonode developers,
>> I have made changes in my geonode production through geonode-project. Just now, I realized that the geonode-project css config is being applied to geonode production main page, however my new tabs and text change in  site_base.html and site.index.html are not being applied to geonode production main page.
>> I ran the commands python manage.py migrate and python manage.py collectstatic and realized that static_root was created in /home/my_geonode/my_geonode/my_geoonde/static_root
>> geonode.conf Directories make reference to several paths /home/my_geonode/my_geonode/my_geonode/uploaded/ and /home/my_geonode/my_geonode/my_geonode/uploaded/* (group, people_group, documents, Layers, avatars and thumbs)
>> but directory uploaded is no in /home/my_geonode/my_geonode/my_geoonode
>> I wonder if this directory <uploaded> and its subdirectories <group, people_group, documents, Layers, avatars and thumbs> are added manually.
>> In order to see the new tabs and text changes in geonode production, I also added another directory to geonode.conf
>>  <Directory "/home/my_geonode/my_geonode/my_geonode/templates/">
>>         Order allow,deny
>>         Options Indexes FollowSymLinks
>>         Allow from all
>>         Require all granted
>>         IndexOptions FancyIndexing
>>  </Directory>
>> The directory templates contains site_base.html and site_index.html. But yet I could not see the new tabs in my geonode production main page.
>> Any help on that will be very appreciated.
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180517/c9f57d50/attachment-0001.html>
More information about the geonode-devel mailing list
