[GeoNode-devel] Geonode Thumbnails Error
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Tue May 29 07:29:12 PDT 2018
Dear Toni Schonbuchner,
Though my questions in the previous e-mail do not help to fix the port
8000. And I am still having the issue related  to port 8000 while creating
the thumbnails. Now, I am trying to find incoherent configuration between
Settings.py and Local_settings.py. I know that settings.py inherits the
configuration in local_settings.py, and that means, if I am not wrong, that
whatever I set in local_settings.py will be copied to settings.py and vice
versa, for instance, a variable that is defined in local_settings.py ca be
used in settings.py and vice versa. Now, let's say, for instance, that I
have MONITORING_ENABLE = True in the local_settings.py and
MONITORING_ENABLE = False in the settings.py, which one will prevail, TRUE
or FALSE value? or DEFAULT_MAP_CRS = "EPSG:900913" in local_settings.py and
DEFAULT_MAP_CRS = "EPSG:3857" in settings.py, which one will prevail?
900913 or 3857? And my first shot is FALSE and 900913 for both questions
because settings.py inherits local_settings.py.
I will play with PROJECT_NAME values in both files to see what happens and
get a better understanding.
Also the variable OGC_SERVER has values defined through local_settings.py
[1], but it does not have any value in OGC_SERVER being used in settings.py
[2]. So, I guess the OGC_SERVER values and config in [1] are retrieved in
[2] as settings.py inherits local_settings.py.
*Different values found between settings.py and local_settings.py*
*settings.py
local_settings.py*
PROJECT_NAME = 'my_geonode'
INSTALLED_APPS += ('geonode',
PROJECT_NAME,)
INSTALLED_APPS = INSTALLED_APPS + ('my_geonode',)
GROUP_MANDATORY_RESOURCES =
True
GROUP_MANDATORY_RESOURCES = False
ACCOUNT_APPROVAL_REQUIRED =
True
ACCOUNT_APPROVAL_REQUIRED = False
ACCOUNT_EMAIL_CONFIRMATION_EMAIL =
True
ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED =
True
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
NOTIFICATION_ENABLED =
True
NOTIFICATION_ENABLED = False
MONITORING_ENABLED =
False
MONITORING_ENABLED = True
WSGI_APPLICATION = "{}.wsgi.application".format(PROJECT_NAME)
                               WSGI_APPLICATION =
"my_geonode.wsgi.application"
ROOT_URLCONF = os.getenv('ROOT_URLCONF',
'{}.urls'.format(PROJECT_NAME))                         ROOT_URLCONF =
'my_geonode.urls'
# Queue non-blocking
notifications.
notifications.
PINAX_NOTIFICATIONS_QUEUE_ALL =
False
NOTIFICATION_QUEUE_ALL = False
GEOIP_PATH = os.path.join(os.path.dirname(__file__), '..',
'GeoLiteCity.dat')                                      GEOIP_PATH =
"/usr/local/share/GeoIP"
Does these different values could be causing the issue related to the
thumbnails? Which ones should I comment out?
[1]
https://github.com/GeoNode/geonode-project/blob/2.8.0/project_name/local_settings.py.sample#L105
[2]
https://github.com/GeoNode/geonode-project/blob/2.8.0/project_name/settings.py#L311
Thank you very much for your time and help.
I appreciated it
Julierme
2018-05-28 13:11 GMT-03:00 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com>:
> Thank you very much for your reply and highlights. While tweaking through
> local_settings.py [1] and settings.py [1][2], trying to find any port 8000
> set to geoserver URL, I got some questions:
> 1 - regarding local_settings.py
> 1.1 OGC_SERVER --> LOG_FILE
> OGC_SERVER : {
>           ' default' : {
>             'LOG_FILE' : '%s/geoserver/data/logs/geoserver.log' % os.path.
> abspath(os.path.join(PROJECT_ROOT, os.pardir)),
> PROJECT_ROOT is the only variable in the file, shouldn't it be changed to
> LOCAL_ROOT? PROJECT_ROOT was set as LOCAL_ROOT at the top of the file.
> 1.2 LOCAL_GEOSERVER
> Should I keep the condition (if 'geonode.geoserver' in INSTALLED_APPS:)
> before LOCAL_GEOSERVER configuration?
> 2 - regarding settings.py
> 2.1 -  LOGGING --> loggers
> The configuration in [1] differs from configuration in [2]. Config [2] in
> settings.py gets
> "{{ project_name }}": {
>         "handlers": ["console"], "level": "DEBUG", },
> "my_geonode": {
> project_name = my_geonde
> but config [1] in local_settings does not. I guess this shouldn't be a
> problem because settings.py inherits local_settings.py.
> LOGGING = {
>      }, 'loggers':
> Lastly, my settings.py is different than settings.py in [3]. According to
> [4], my settings.py [5] is downloaded from here [6].
> For instance, USE_GEOSERVER is set in Line 1249 [7], but it is not set in
> [5], at least the configuration is different. Furthermore, some libraries
> are imported in [7], but  they aren't in [5].
> Is it settings.py in [5] out of date?
> Yet, I am tweaking through geonode-updateip script and I will try to make
> some changes in order to have it working for GeNode installed from source.
> As soon as get it, I will share it here.
> I appreciated your time and help.
> Kind regards and greetings to Germany.
> Julierme
> [1] http://docs.geonode.org/en/master/tutorials/install_and_admi
> n/geonode_install/setup_configure_httpd.html
> [2] http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/create_geonode_db.html
> [3] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/settings.py#L650
> [4] http://docs.geonode.org/en/master/tutorials/install_and_
> admin/geonode_install/install_geonode_application.html
> [5] https://github.com/GeoNode/geonode-project/blob/2.8.0/
> [6] http://github.com/Geonode/geonode-project/archive/2.8.0.zip
> [7] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/
> settings.py#L1249
> 2018-05-28 11:20 GMT-03:00 Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com>:
>> Thank you very much for your reply. While tweaking through settings.py
>> and local_settings.py [1], trying to find any port 8000 set to geoserver
>> OGC_SERVER : {
>>           ' default' : {
>> .abspath(os.path.join(PROJECT_ROOT, os.pardir)),
>> 2018-05-25 17:02 GMT-03:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de
>>> Dear Julierme,
>>> I think  using grep does not really help to get insights.
>>> Why not look at the code? The geoserver URL is composed
>>> in settings.py [1]. I think here you will find your 8000.
>>> Next I think the best way to see what´s going on is to have
>>> a look at the helpers.py [2]. Here you should find the code which
>>> is responsible for creating thumbnails and here [3] the signal
>>> which you see in stdout logging. If there is some time I will
>>> do a dev installation and will test it as well.
>>> Further you´ve asked if there is something like geonode-updateip
>>> for an installation by source? Not that I know of but yes it would be
>>> helpful.
>>> But it should not be to hard to write a little script which does the job.
>>> Have a look what geonode-updateip actually does [4] it programatically
>>> changes
>>> the parts which the documentation [5] explains regarding auth.
>>> I hope this helps a bit.
>>> Best greetings to Brasilia!
>>> Toni
>>> [1] https://github.com/GeoNode/geonode/blob/2.8.0/geonode/se
>>> ttings.py#L650
>>> [2] https://github.com/GeoNode/geonode/blob/master/geonode/g
>>> eoserver/helpers.py#L1730
>>> [3] https://github.com/GeoNode/geonode/blob/df12893ced001973
>>> bd748f86d08fa6ae4c10dde9/geonode/geoserver/signals.py#L497
>>> [4] https://github.com/GeoNode/geonode/blob/df12893ced001973
>>> bd748f86d08fa6ae4c10dde9/package/support/geonode.updateip#L126
>>> [5] http://docs.geonode.org/en/master/tutorials/install_and_
>>> admin/geonode_install/install_geoserver_application.html#geo
>>> node-authentication-integration
>>> CSGIS
>>> Kolonnadenstraße 1
>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198
>>> Tel  +49/ (0) 341 24 04 738
>>> Fax  +49/ (0) 341 24 04 73
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>> To: Toni Schönbuchner <toni.schoenbuchner at csgis.de>, geonode-users
>>> <geonode-users at lists.osgeo.org>,  geonode-devel
>>> <geonode-devel at lists.osgeo.org>
>>> Subject: Re: [GeoNode-devel] Geonode Thumbnails Error
>>> Message-ID:
>>> <CAKTKyJJmjL0QBMuZvw0DsBzeCu2yW5vKCj5dMjDN=cddheWJ+g at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Here are some more paths that port 8000 could be coming from:
>>> geo/Envs/geonode/lib/python2.7/site-packages/pycsw/wsgi.py:#
>>> http://localhost:8000/
>>> geo/Envs/geonode/lib/python2.7/site-packages/djangorestframe
>>> work-3.8.2.dist-info/DESCRIPTION.rst:You
>>> can now open the API in your browser at ``http://127.0.0.1:8000/``
>>> <http://127.0.0.1:8000/>,
>>> $ curl -H 'Accept: application/json; indent=4' -u admin:password
>>> http://127.0.0.1:8000/users/
>>> "url": "http://127.0.0.1:8000/users/1/",
>>> $ curl -X POST -d username=new -d email=new at example.com -d
>>> is_staff=false
>>> "url": "http://127.0.0.1:8000/users/2/",
>>> work-3.8.2.dist-info/METADATA:You
>>> is_staff=false
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180529/fbefce8d/attachment-0001.html>
More information about the geonode-devel mailing list
