[GeoNode-devel] [GeoNode-users] GeoNode WorldMap client to be part of GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Thu May 31 01:15:26 PDT 2018
+1 definitely.
2018-05-31 9:59 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> I have taken a look at the PR and it looks good to me.
> The module is a contrib module not enabled by default and therefore not
> affecting the core functionalities at all.
> Also there are not schema changes on the GeoNode core. Moreover there are
> a lot of improvements on translations.
> That said, if no other objection. I am +1 on merging the PR and start the
> release process ASAP.
> Let's wait for other feedbacks.
> Thanks Paolo!
> 2018-05-31 9:03 GMT+02:00 Dimitris Kar <dkarakostis at gmail.com>:
>> Thanks Paolo,
>> Great contribution.
>> On Thu, May 31, 2018 at 8:08 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Great! Thanks Paolo
>>> 2018-05-30 21:20 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>> I forgot to mention that this client extends the GeoNode serialization
>>>> format. Therefore maps whic are created using the WorldMap client will
>>>> not
>>>> be compatible with the default GeoNode client. It should be simple
>>>> anyway
>>>> to write a Django command which converts maps back and forth
>>>> best
>>>> Paolo
>>>> On Wed, May 30, 2018 at 3:14 PM Paolo Corti <pcorti at gmail.com> wrote:
>>>> > Dear GeoNode users and developers
>>>> > Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch
>>>> (to
>>>> > become GeoNode 2.8.1), which implements this GNIP [2]. This pull
>>>> request
>>>> > introduce the Harvard WorldMap contribute application in GeoNode.
>>>> > You can have a full list of the features introduced from the
>>>> application
>>>> at
>>>> > [2]. In brief this application introduce a new client, based on an
>>>> improved
>>>> > version of the GeoExplorer default client, with additional features
>>>> such
>>>> as:
>>>> > * layer categories in table of contents
>>>> > * layer graduated style editor
>>>> > * a find place widget and layers gazetteer
>>>> > * feature search
>>>> > * map revisions
>>>> > * URL permalink for maps
>>>> > * layer search with Hypermap Registry (optional)
>>>> > The application is optional and does not introduce any change in
>>>> existing
>>>> > GeoNode tables. If enabled, it will create a few new tables in GeoNode
>>>> > database, which are needed in order for the application to work. You
>>>> must
>>>> > use PostgreSQL to use this application, and PostgreSQL will require
>>>> the
>>>> > PostGIS and dblink extensions.
>>>> > The GNIP implementation is based on current GeoNode WorldMap source
>>>> code
>>>> > [3], and contains code committed by a number of GeoNode developers:
>>>> > * Matt Bertrand
>>>> > * Paolo Corti
>>>> > * Wayner Barrios
>>>> > * Jorge Martínez Gómez
>>>> > * Lennin Suescun
>>>> > * 刘尧 aka Lanni
>>>> > If there is consensus, this application will be merged in GeoNode
>>>> source
>>>> > code as a contribute module.
>>>> > Thanks
>>>> > Paolo
>>>> > [1] https://github.com/GeoNode/geonode/pull/3817
>>>> > [2] https://github.com/GeoNode/geonode/issues/3718
>>>> > [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
>>>> > Paolo Corti
>>>> > Geospatial software developer
>>>> > web: http://www.paolocorti.net
>>>> > twitter: @capooti
>>>> > skype: capooti
>>>> Paolo Corti
>>>> twitter: @capooti
>>>> skype: capooti
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
>  Massarosa
> (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20180531/b41307f8/attachment-0001.html>
More information about the geonode-devel mailing list
