[GeoNode-users] help with geonode-geoexplorer layer query
GC-54 nepanode at gmail.com
Fri Apr 3 07:17:51 PDT 2015
Can you explain your need in more detail? You can save a layer w a cql
filter in a map and use that but dynamically generating a url for a new map
would take some customization
On Friday, April 3, 2015, Albano Giovanni <albano.giovanni at tiscali.it>
wrote:
> hi,
> I wanted to ask you a question.
> it would be possible to switch to geoexplorer a layer with a query
> directly in the url?
> For example:
> http://192.168.2.95/maps/new?layer=geonode%3Aaree_sopra_1200m&filter=geonode%3Aaree_sopra_1200m.area
> >1000
> Thank You
> Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
> *Please consider the environment – Do you really need to print this email?*
> Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le
> informazioni contenute in questo messaggio sono riservate e ad uso
> esclusivo del destinatario. Qualora il messaggio in parola Le fosse
> pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
> inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
> *This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain
> confidential and/or privileged information. If you are not the addressee or
> authorized to receive this for the addressee, you must not use, copy,
> disclose or take any action based on this message or any information
> herein. If you have received this message in error, please advise the
> sender immediately by reply e-mail and delete this message. **Thank you
> for your cooperation*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150403/d1065c19/attachment.html>
More information about the geonode-users mailing list
