[GeoNode-users] R: help with geonode-geoexplorer layer query
Albano Giovanni albano.giovanni at tiscali.it
Fri Apr 3 08:13:03 PDT 2015
I should integrate geonode with another application. This is unfortunately written in asp.net . The application allows to select the cadastral parcels starting from the owner. I thought it was possible to pass the filter CQL directly from url. This would reduce to zero the customization work .
Regards
Giovanni Albano
Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
Please consider the environment – Do you really need to print this email?
Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le informazioni contenute in questo messaggio sono riservate e ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain confidential and/or privileged information. If you are not the addressee or authorized to receive this for the addressee, you must not use, copy, disclose or take any action based on this message or any information herein. If you have received this message in error, please advise the sender immediately by reply e-mail and delete this message. Thank you for your cooperation
Da: GC-54 [mailto:nepanode at gmail.com]
Inviato: venerdì 3 aprile 2015 16:18
A: Albano Giovanni
Cc: geonode-users at lists.osgeo.org
Oggetto: Re: [GeoNode-users] help with geonode-geoexplorer layer query
Can you explain your need in more detail? You can save a layer w a cql filter in a map and use that but dynamically generating a url for a new map would take some customization
On Friday, April 3, 2015, Albano Giovanni <albano.giovanni at tiscali.it> wrote:
hi,
I wanted to ask you a question.
it would be possible to switch to geoexplorer a layer with a query directly in the url?
For example:http://192.168.2.95/maps/new?layer=geonode%3Aaree_sopra_1200m <http://192.168.2.95/maps/new?layer=geonode%3Aaree_sopra_1200m&filter=geonode%3Aaree_sopra_1200m.area> &filter=geonode%3Aaree_sopra_1200m.area>1000
Thank You
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150403/7c8bb774/attachment-0001.html>
More information about the geonode-users mailing list
