[GeoNode-users] help with geonode-geoexplorer layer query
GC-54 nepanode at gmail.com
Fri Apr 3 15:08:53 PDT 2015
Albano it doesn't sound like Geonode is the problem nor the solution...
Sounds like it'd be easier to look into a simple web map that you could
pass the geoserver a WFS request; using some javascript or django forms to
inject/append a CQL filter into... and use a format like GeoJSON which will
load/focus the webmap to the feature when returned
Trying to get Geoexplorer to do this sounds a bit bulky; and would require
you to modified how maps get loaded/saved; is this scenario a reoccurring
need for your data/use of Geonode?
On Fri, Apr 3, 2015 at 11:13 AM, Albano Giovanni <albano.giovanni at tiscali.it
> wrote:
> Hi,
> I should integrate geonode with another application. This is unfortunately written in asp.net . The application allows to select the cadastral parcels starting from the owner. I thought it was possible to pass the filter CQL directly from url. This would reduce to zero the customization work .
> Regards
> *Giovanni Albano*
> Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
> *Please consider the environment – Do you really need to print this email?*
> Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le
> informazioni contenute in questo messaggio sono riservate e ad uso
> esclusivo del destinatario. Qualora il messaggio in parola Le fosse
> pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
> inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
> *This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain
> confidential and/or privileged information. If you are not the addressee or
> authorized to receive this for the addressee, you must not use, copy,
> disclose or take any action based on this message or any information
> herein. If you have received this message in error, please advise the
> sender immediately by reply e-mail and delete this message. **Thank you
> for your cooperation*
> *Da:* GC-54 [mailto:nepanode at gmail.com]
> *Inviato:* venerdì 3 aprile 2015 16:18
> *A:* Albano Giovanni
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: [GeoNode-users] help with geonode-geoexplorer layer query
> Can you explain your need in more detail? You can save a layer w a cql
> filter in a map and use that but dynamically generating a url for a new map
> would take some customization
> On Friday, April 3, 2015, Albano Giovanni <albano.giovanni at tiscali.it>
> wrote:
> hi,
> I wanted to ask you a question.
> it would be possible to switch to geoexplorer a layer with a query
> directly in the url?
> For example:
> http://192.168.2.95/maps/new?layer=geonode%3Aaree_sopra_1200m&filter=geonode%3Aaree_sopra_1200m.area
> >1000
> Thank You
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150403/c4ec1393/attachment.html>
More information about the geonode-users mailing list
