[GeoNode-users] migrate geonode 2.4 to another server
Paolo Corti pcorti at gmail.com
Tue Apr 7 01:11:56 PDT 2015
Uh forget my comment about documentation, I have just realized that
geonode-updateip is a bash script and not a django command.
cheers
p
On Tue, Apr 7, 2015 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Definitely that is the best way, totally forgot about that command :)
> we need to add it to the documentation
> (http://docs.geonode.org/en/master/tutorials/admin/commands.html#commands)
> by the way
> cheers
> p
> On Fri, Apr 3, 2015 at 5:38 PM, Simone Dalmasso
> <simone.dalmasso at gmail.com> wrote:
>> Shouldn't the geonode-updateip command do this?
>> 2015-03-31 13:54 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>> It looks to me to be a bug, could you file a ticket?
>>> Thanks
>>> Meanwhile what you can do is to manually update the base_links table
>>> with something like (not tested):
>>> update base_link
>>> set url = replace(url, 'old_ip', 'new_ip')
>>> p
>>> On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
>>> <alessandro at acrotec.it> wrote:
>>> > i've truncated the base_link table and then i've run the geonode
>>> > updatelayers command (and also updatelayerid)... but the base_link table
>>> > remains empty
>>> > Alessandro
>>> > On 31/03/15 11:39, Paolo Corti wrote:
>>> >> I have no way to test this right now but I believe that truncating the
>>> >> base_links table and running the updatelayers command should fix this.
>>> >> Before doing this action do a backup and try it on just one layer
>>> >> (removing the links related to only that layer from the base_links
>>> >> table)
>>> >> You may also need to run the updatemaplayerip command.
>>> >> p
>>> >> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
>>> >>> Hi guys
>>> >>> i need to migrate my geonode 2.4b22 to another server (same os: ubuntu
>>> >>> 14-04
>>> >>> and same geonode version)...
>>> >>> I tried doing it in this way:
>>> >>>   - copy the geoserver data, styles and workspace directory in the new
>>> >>> server
>>> >>>   - domp via pg_dump and restore via psql the geonode database
>>> >>> the result is that geonode recognize all layers but it cannot view
>>> >>> them
>>> >>> because all links in the layer metadata contains the old server
>>> >>> address...
>>> >>> haw can i solve it?
>>> >>> thanks in advance
>>> >>>      Alessandro
>>> >>> _______________________________________________
>>> >>> geonode-users mailing list
>>> >>> geonode-users at lists.osgeo.org
>>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>> Simone
> Paolo Corti
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
