[GeoNode-users] migrate geonode 2.4 to another server
Simone Dalmasso simone.dalmasso at gmail.com
Tue Apr 7 02:33:11 PDT 2015
Alessandro I just released the b24 which fixes the error. I apologize for
it :)
2015-04-07 10:34 GMT+02:00 Alessandro Burastero <alessandro at acrotec.it>:
> mmm i tried the geonode-updateip but i didn't worked... maybe i made
> something wrong...
> ...now i'm testing again the procedure, but i can't install the new
> geonode beta 23 in a new ubuntu 14-04 intallation... the following error
> appear during the geonode postinstall step:
> Running GeoNode postinstall ...
> Traceback (most recent call last):
>   File "<string>", line 1, in <module>
> ImportError: No module named geonode
>   File "/usr/bin/django-admin", line 5, in <module>
>     management.execute_from_command_line()
>   File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
>     utility.execute()
> line 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
> line 261, in fetch_command
>     commands = get_commands()
> line 107, in get_commands
>     apps = settings.INSTALLED_APPS
>   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
> 54, in __getattr__
>     self._setup(name)
> 49, in _setup
>     self._wrapped = Settings(settings_module)
> 132, in __init__
>     % (self.SETTINGS_MODULE, e)
> ImportError: Could not import settings 'geonode.settings' (Is it on
> sys.path? Is there an import error in the settings file?): No module named
> geonode.settings
>     utility.execute()
> 54, in __getattr__
>     self._setup(name)
> 49, in _setup
> 132, in __init__
> geonode.settings
> ...while the update from the beta22 goes well
> thanks again
> Alessandro
> On 07/04/15 10:11, Paolo Corti wrote:
>> Uh forget my comment about documentation, I have just realized that
>> geonode-updateip is a bash script and not a django command.
>> cheers
>> p
>> On Tue, Apr 7, 2015 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>> Definitely that is the best way, totally forgot about that command :)
>>> we need to add it to the documentation
>>> (http://docs.geonode.org/en/master/tutorials/admin/
>>> commands.html#commands)
>>> by the way
>>> cheers
>>> p
>>> On Fri, Apr 3, 2015 at 5:38 PM, Simone Dalmasso
>>> <simone.dalmasso at gmail.com> wrote:
>>>> Shouldn't the geonode-updateip command do this?
>>>> 2015-03-31 13:54 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>>> It looks to me to be a bug, could you file a ticket?
>>>>> Thanks
>>>>> Meanwhile what you can do is to manually update the base_links table
>>>>> with something like (not tested):
>>>>> update base_link
>>>>> set url = replace(url, 'old_ip', 'new_ip')
>>>>> p
>>>>> On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
>>>>> <alessandro at acrotec.it> wrote:
>>>>>> i've truncated the base_link table and then i've run the geonode
>>>>>> updatelayers command (and also updatelayerid)... but the base_link
>>>>>> table
>>>>>> remains empty
>>>>>> Alessandro
>>>>>> On 31/03/15 11:39, Paolo Corti wrote:
>>>>>>> I have no way to test this right now but I believe that truncating
>>>>>>> the
>>>>>>> base_links table and running the updatelayers command should fix
>>>>>>> this.
>>>>>>> Before doing this action do a backup and try it on just one layer
>>>>>>> (removing the links related to only that layer from the base_links
>>>>>>> table)
>>>>>>> You may also need to run the updatemaplayerip command.
>>>>>>> p
>>>>>>> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
>>>>>>>> Hi guys
>>>>>>>> i need to migrate my geonode 2.4b22 to another server (same os:
>>>>>>>> ubuntu
>>>>>>>> 14-04
>>>>>>>> and same geonode version)...
>>>>>>>> I tried doing it in this way:
>>>>>>>>    - copy the geoserver data, styles and workspace directory in the
>>>>>>>> new
>>>>>>>> server
>>>>>>>>    - domp via pg_dump and restore via psql the geonode database
>>>>>>>> the result is that geonode recognize all layers but it cannot view
>>>>>>>> them
>>>>>>>> because all links in the layer metadata contains the old server
>>>>>>>> address...
>>>>>>>> haw can i solve it?
>>>>>>>> thanks in advance
>>>>>>>>       Alessandro
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>> Simone
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150407/7c0098f6/attachment-0001.html>
More information about the geonode-users mailing list
