[GeoNode-users] Errors in listing layers/maps ver. 2.4b22
Simone Dalmasso simone.dalmasso at gmail.com
Wed Apr 8 05:13:21 PDT 2015
Seems that you are missing a django-autocomplete templates or the app
itself. You can try to fix it with pip install django-autocomplete.
2015-04-08 14:04 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Here it is:
> Internal Server Error: /admin/layers/layer/8/
> [Wed Apr 08 13:53:54.142311 2015] [:error] [pid 1056:tid 2950515520]
> Traceback (most recent call last):
> [Wed Apr 08 13:53:54.142370 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line
> 137, in get_response
> [Wed Apr 08 13:53:54.142425 2015] [:error] [pid 1056:tid 2950515520]
> response = response.render()
> [Wed Apr 08 13:53:54.142478 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/response.py", line
> 105, in render
> [Wed Apr 08 13:53:54.142683 2015] [:error] [pid 1056:tid 2950515520]
> self.content = self.rendered_content
> [Wed Apr 08 13:53:54.142738 2015] [:error] [pid 1056:tid 2950515520]
> 82, in rendered_content
> [Wed Apr 08 13:53:54.142791 2015] [:error] [pid 1056:tid 2950515520]
> content = template.render(context)
> [Wed Apr 08 13:53:54.142853 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140,
> in render
> [Wed Apr 08 13:53:54.142908 2015] [:error] [pid 1056:tid 2950515520]
> return self._render(context)
> [Wed Apr 08 13:53:54.142966 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134,
> in _render
> [Wed Apr 08 13:53:54.143136 2015] [:error] [pid 1056:tid 2950515520]
> return self.nodelist.render(context)
> [Wed Apr 08 13:53:54.143158 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840,
> in render
> [Wed Apr 08 13:53:54.143179 2015] [:error] [pid 1056:tid 2950515520]
> bit = self.render_node(node, context)
> [Wed Apr 08 13:53:54.143199 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854,
> in render_node
> [Wed Apr 08 13:53:54.143221 2015] [:error] [pid 1056:tid 2950515520]
> return node.render(context)
> [Wed Apr 08 13:53:54.143242 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py",
> line 123, in render
> [Wed Apr 08 13:53:54.143262 2015] [:error] [pid 1056:tid 2950515520]
> return compiled_parent._render(context)
> [Wed Apr 08 13:53:54.143282 2015] [:error] [pid 1056:tid 2950515520]
> in _render
> [Wed Apr 08 13:53:54.143304 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143324 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.143345 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143365 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.143387 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143407 2015] [:error] [pid 1056:tid 2950515520]
> line 123, in render
> [Wed Apr 08 13:53:54.143428 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143448 2015] [:error] [pid 1056:tid 2950515520]
> in _render
> [Wed Apr 08 13:53:54.143479 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143499 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.143519 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143547 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.143568 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143588 2015] [:error] [pid 1056:tid 2950515520]
> line 62, in render
> [Wed Apr 08 13:53:54.143608 2015] [:error] [pid 1056:tid 2950515520]
> result = block.nodelist.render(context)
> [Wed Apr 08 13:53:54.143630 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.143650 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143670 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.143691 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143712 2015] [:error] [pid 1056:tid 2950515520]
> line 62, in render
> [Wed Apr 08 13:53:54.143733 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143753 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.143773 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143845 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.143876 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.143896 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py",
> line 203, in render
> [Wed Apr 08 13:53:54.143917 2015] [:error] [pid 1056:tid 2950515520]
> nodelist.append(node.render(context))
> [Wed Apr 08 13:53:54.143937 2015] [:error] [pid 1056:tid 2950515520]
> line 155, in render
> [Wed Apr 08 13:53:54.144074 2015] [:error] [pid 1056:tid 2950515520]
> return self.render_template(self.template, context)
> [Wed Apr 08 13:53:54.144231 2015] [:error] [pid 1056:tid 2950515520]
> line 137, in render_template
> [Wed Apr 08 13:53:54.144253 2015] [:error] [pid 1056:tid 2950515520]
> output = template.render(context)
> [Wed Apr 08 13:53:54.144281 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.144302 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144322 2015] [:error] [pid 1056:tid 2950515520]
> in _render
> [Wed Apr 08 13:53:54.144343 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144365 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.144385 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144406 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.144427 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144448 2015] [:error] [pid 1056:tid 2950515520]
> line 203, in render
> [Wed Apr 08 13:53:54.144469 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144489 2015] [:error] [pid 1056:tid 2950515520]
> line 203, in render
> [Wed Apr 08 13:53:54.144509 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144538 2015] [:error] [pid 1056:tid 2950515520]
> line 305, in render
> [Wed Apr 08 13:53:54.144558 2015] [:error] [pid 1056:tid 2950515520]
> return nodelist.render(context)
> [Wed Apr 08 13:53:54.144579 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.144608 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144629 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.144661 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144687 2015] [:error] [pid 1056:tid 2950515520]
> line 305, in render
> [Wed Apr 08 13:53:54.144708 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144729 2015] [:error] [pid 1056:tid 2950515520]
> in render
> [Wed Apr 08 13:53:54.144749 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144821 2015] [:error] [pid 1056:tid 2950515520]
> in render_node
> [Wed Apr 08 13:53:54.144850 2015] [:error] [pid 1056:tid 2950515520]
> [Wed Apr 08 13:53:54.144871 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 897,
> in render
> [Wed Apr 08 13:53:54.144892 2015] [:error] [pid 1056:tid 2950515520]
> return render_value_in_context(output, context)
> [Wed Apr 08 13:53:54.144912 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/base.py", line 875,
> in render_value_in_context
> [Wed Apr 08 13:53:54.144934 2015] [:error] [pid 1056:tid 2950515520]
> value = force_text(value)
> [Wed Apr 08 13:53:54.144954 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/utils/encoding.py", line 100,
> in force_text
> [Wed Apr 08 13:53:54.144975 2015] [:error] [pid 1056:tid 2950515520]     s
> = s.__unicode__()
> [Wed Apr 08 13:53:54.144995 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 425, in
> __str__
> [Wed Apr 08 13:53:54.145017 2015] [:error] [pid 1056:tid 2950515520]
> return self.as_widget()
> [Wed Apr 08 13:53:54.145037 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 475, in
> as_widget
> [Wed Apr 08 13:53:54.145058 2015] [:error] [pid 1056:tid 2950515520]
> return widget.render(name, self.value(), attrs=attrs)
> [Wed Apr 08 13:53:54.145078 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/contrib/admin/widgets.py",
> line 254, in render
> [Wed Apr 08 13:53:54.145100 2015] [:error] [pid 1056:tid 2950515520]
> output = [self.widget.render(name, value, *args, **kwargs)]
> [Wed Apr 08 13:53:54.145120 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/autocomplete_light/widgets.py", line
> 133, in render
> [Wed Apr 08 13:53:54.145141 2015] [:error] [pid 1056:tid 2950515520]
> return safestring.mark_safe(render_to_string(templates, context))
> [Wed Apr 08 13:53:54.145161 2015] [:error] [pid 1056:tid 2950515520]
> File "/usr/lib/python2.7/dist-packages/django/template/loader.py", line
> 160, in render_to_string
> [Wed Apr 08 13:53:54.145183 2015] [:error] [pid 1056:tid 2950515520]     t
> = select_template(template_name)
> [Wed Apr 08 13:53:54.145203 2015] [:error] [pid 1056:tid 2950515520]
> 186, in select_template
> [Wed Apr 08 13:53:54.145223 2015] [:error] [pid 1056:tid 2950515520]
> raise TemplateDoesNotExist(', '.join(not_found))
> [Wed Apr 08 13:53:54.145244 2015] [:error] [pid 1056:tid 2950515520]
> TemplateDoesNotExist: autocomplete_light/type/widget.html,
> autocomplete_light//widget.html, autocomplete_light/widget.html
> [Wed Apr 08 13:53:54.148382 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575] mod_wsgi (pid=1056): Exception occurred
> processing WSGI script '/home/nirweb_progetto/nirweb/nirweb/wsgi.py'.
> [Wed Apr 08 13:53:54.148460 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575] Traceback (most recent call last):
> [Wed Apr 08 13:53:54.148499 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]   File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
> in __call__
> [Wed Apr 08 13:53:54.148554 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     response = self.get_response(request)
> [Wed Apr 08 13:53:54.148588 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
> in get_response
> [Wed Apr 08 13:53:54.148634 2015] [:error] [pid 1056:tid 2950515520]
> self.handle_uncaught_exception(request, resolver, sys.exc_info())
> [Wed Apr 08 13:53:54.148666 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
> in handle_uncaught_exception
> [Wed Apr 08 13:53:54.148797 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     return callback(request, **param_dict)
> [Wed Apr 08 13:53:54.148830 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
> _wrapped_view
> [Wed Apr 08 13:53:54.148877 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     response = view_func(request, *args,
> **kwargs)
> [Wed Apr 08 13:53:54.148908 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 43, in
> server_error
> [Wed Apr 08 13:53:54.148958 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     template =
> loader.get_template(template_name)
> [Wed Apr 08 13:53:54.148989 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 138, in
> get_template
> [Wed Apr 08 13:53:54.149036 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     template, origin =
> find_template(template_name)
> [Wed Apr 08 13:53:54.149067 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 127, in
> find_template
> [Wed Apr 08 13:53:54.149113 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     source, display_name = loader(name,
> dirs)
> [Wed Apr 08 13:53:54.149144 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 43, in
> __call__
> [Wed Apr 08 13:53:54.149181 2015] [:error] [pid 1056:tid 2950515520]
> self.load_template(template_name, template_dirs)
> [Wed Apr 08 13:53:54.149220 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 49, in
> load_template
> [Wed Apr 08 13:53:54.149257 2015] [:error] [pid 1056:tid 2950515520]
> get_template_from_string(source, origin, template_name)
> [Wed Apr 08 13:53:54.149290 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 149, in
> [Wed Apr 08 13:53:54.149327 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     return Template(source, origin, name)
> [Wed Apr 08 13:53:54.149367 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 125, in
> __init__
> [Wed Apr 08 13:53:54.149406 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     self.nodelist =
> compile_string(template_string, origin)
> [Wed Apr 08 13:53:54.149443 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 153, in
> compile_string
> [Wed Apr 08 13:53:54.149484 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     return parser.parse()
> [Wed Apr 08 13:53:54.149524 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 278, in
> parse
> [Wed Apr 08 13:53:54.149561 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     compiled_result = compile_func(self,
> token)
> [Wed Apr 08 13:53:54.149593 2015] [:error] [pid 1056:tid 2950515520]
> "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line
> 1084, in load
> [Wed Apr 08 13:53:54.149644 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575]     (taglib, e))
> [Wed Apr 08 13:53:54.149700 2015] [:error] [pid 1056:tid 2950515520]
> [remote 192.168.225.19:27575] TemplateSyntaxError: 'announcements_tags'
> is not a valid tag library: Template library announcements_tags not found,
> tried
> django.templatetags.announcements_tags,django.contrib.admin.templatetags.announcements_tags,django.contrib.staticfiles.templatetags.announcements_tags,django.contrib.humanize.templatetags.announcements_tags,avatar.templatetags.announcements_tags,geonode.base.templatetags.announcements_tags,geonode.social.templatetags.announcements_tags,geonode.upload.templatetags.announcements_tags
> I've launched geonode validate_templates and give me 2 errors:
> /usr/local/lib/python2.7/dist-packages/geonode/templates/relationships/_profile_
>                follow.html: TemplateSyntaxError Invalid block tag:
> 'if_relationship'
> /usr/local/lib/python2.7/dist-packages/geonode/templates/relationships/relations
>                hip_list.html: TemplateSyntaxError 'relationship_tags' is
> not a valid tag librar                y: Template library relationship_tags
> not found, tried django.templatetags.relat
>  ionship_tags,django.contrib.admin.templatetags.relationship_tags,django.contrib.
>  staticfiles.templatetags.relationship_tags,django.contrib.humanize.templatetags.
>  relationship_tags,pagination.templatetags.relationship_tags,friendlytagloader.te
>  mplatetags.relationship_tags,leaflet.templatetags.relationship_tags,django_exten
>  sions.templatetags.relationship_tags,autocomplete_light.templatetags.relationshi
>  p_tags,mptt.templatetags.relationship_tags,django_forms_bootstrap.templatetags.r
>  elationship_tags,account.templatetags.relationship_tags,avatar.templatetags.rela
>  tionship_tags,dialogos.templatetags.relationship_tags,agon_ratings.templatetags.
>  relationship_tags,announcements.templatetags.relationship_tags,actstream.templat
>  etags.relationship_tags,user_messages.templatetags.relationship_tags,polymorphic
>  .templatetags.relationship_tags,guardian.templatetags.relationship_tags,geonode.
>  base.templatetags.relationship_tags,geonode.social.templatetags.relationship_tag
>                s,geonode.upload.templatetags.relationship_tags
> Maybe I've to update something ....
> 2015-04-08 13:02 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Annalisa, that is a generic Apache error. You can get more information
>> with tail -f /var/log/apache2/error.log.
>> You can post here the stacktrace.
>> 2015-04-08 12:23 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>> Hi list,
>>> today, after a few days, I open my testing geonode but I don't find any
>>> layer ...
>>> Under admin panel there are my 8 layer, but when I select one receive
>>> Internal server error -> mod_wsgi (pid=1056): Exception occurred processing
>>> That wsgi.py is of our template.
>>> Any ideas?
>>> Thanks
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150408/08be8c37/attachment-0001.html>
More information about the geonode-users mailing list
