[GeoNode-users] 'NoneType' object has no attribute 'name'
GC-54 nepanode at gmail.com
Thu Apr 9 14:06:23 PDT 2015
I encountered this same issue... I solved it by replacing the XML documents
for layers in geoserver_data directory. I'm assuming there must have been a
change in the schema for the upgraded version geoserver geonode now uses -
I'd suggest investigating if you didn't try to migrate data manually; but
if you did move old files in the new geoserver_data dir those are likely to
be what are corrupting things.
On Thu, Apr 9, 2015 at 9:55 AM, Paul Magdon <pmagdon at gwdg.de> wrote:
> Dear all,
> I have trouble with uploading a shapefile on a fresh install of Geonode
> (2.4b24) on a Ubuntu 14.04 VM.
> Everything is running but when I try to upload a layer I get the
> follwoing error (from the apache2 log:
> [Thu Apr 09 07:46:31.547150 2015] [:error][style, created =
> Style.objects.get_or_create(name=gs_style.name)
> [Thu Apr 09 07:46:31.547154 2015] [:error] AttributeError: 'NoneType'
> I guess some think with the Geoserver configuration is missing but I have
> no clue where to start search for.
> Any ideas?
> Greetings Paul
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150409/b3ace3e9/attachment.html>
More information about the geonode-users mailing list
