[GeoNode-users] Geonode, pair of questions
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 10 01:05:32 PDT 2015
Hi Eugenio, good to hear that you are back to geonode.
Here my answers.
1) yes we kept developing in these months
2) Yes you should definitely upgrade geonode, there have been many
improvements and also some small data model changes so you might have to
rebuild your db or part of it.
3) although there are plans to fully support such feature, it is not fully
implemented yet so you have to go for two geonodes (for geoserver is
suggested to have two different tomcats on different ports with a geoserver
each)
4) I'm not very confident with geonetwork but yes, it is supported and you
can give a try on using it.
Hope this helps.
Ciao
2015-04-10 9:49 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear list,
> this is my first time I use this list, I had some messages exchange in the
> previous google group.
> In the past I tested geonode installing on my own an instance on my ubuntu
> server 12.04 in the
> version *2.4.dev20140922100009.* For this I have to say thank you to
> Simone Dalmasso who
> drove me in the installation. I performed a custom installation,
> following  this guide:
> http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install
> at this URL my instance is still running but actually it has been
> abandoned since last year more or less:
> http://repoigg.services.iit.cnr.it
> Currently I need to go further using geonode, however, due to a long time
> without using it, I'm requiring you
> some hints and tips.
> My questions are:
>    - is there a new dev version?
>    - do you think would be convenient to upgrade to a new dev version?
>    Are there important code improvements?
>    - I have two different projects: do you suggest me to prepare two
>    geonode installations (one for each project) or can I set up only one
>    instance and configure it to serve the two project? Can I set up two
>    different website (interfaces)?
>    - My data (for both project) are already metadated in a geonetwork
>    catalogue, I know I can use geonetwork as metadata catalogue as well as set
>    up my catalogue as external catalogue. What do you suggest?
> Thank you for now,
> best
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150410/9af98912/attachment.html>
More information about the geonode-users mailing list
