[GeoNode-users] Errors in listing layers/maps ver. 2.4b22
Simone Dalmasso simone.dalmasso at gmail.com
Tue Apr 14 01:39:56 PDT 2015
Good!
Thanks for the hints on validate templates I'll take a look soon. They
should create errors in geonode anyway.
2015-04-14 10:37 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> INSTALLED_APPS = INSTALLED_APPS + (
>     'yournewapp',
> ) has resolved our problems! Thanks!!!
> But geonode validate_templates still gives the same.
> We have 2 dir:
> 1. /usr/lib/python2.7/dist-packages/, with django-autocomplete-light-1.4.14
> 2. /usr/local/lib/python2.7/dist-packages/
> Validate_templates points to local
> It seems installation and/or upgrade affect both
> Thanks
> 2015-04-13 10:23 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> It is indeed strange.
>> Check whether that template actually exists in your
>> python2.7/site-packages(or dist-packages)/autocomplete_light.
>> Does your installed apps (in my_geonode/settings.py) looks like this?
>>     'yournewapp',
>> 2015-04-13 10:07 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>> Yes, after we've tried this command but it gives "requirement alrealy
>>> satisfied"
>>> 2015-04-10 13:42 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Sorry it should be pip install django-autocomplete-light==1.4.14 , as
>>>> per setup.py.
>>>> 2015-04-10 13:35 GMT+02:00 Annalisa Schiavon <
>>>>> pip install django-autocomplete fails.
>>>>> We tried to add ad additional django app to our geonode project, so we
>>>>> followed this page:
>>>>> http://geonode.readthedocs.org/en/latest/tutorials/devel/projects/apps.html
>>>>> <http://www.google.com/url?q=http%3A%2F%2Fgeonode.readthedocs.org%2Fen%2Flatest%2Ftutorials%2Fdevel%2Fprojects%2Fapps.html&sa=D&sntz=1&usg=AFQjCNF7PFjkC14ZJlrZzGgmQo94GixP9A>
>>>>> but just after editing the <my_geonode>/settings.py file and inserting
>>>>> the INSTALLED_APPS part
>>>>> with all that geonode + django apps, when we looked at the /layers/
>>>>> page we didn't find any layers.
>>>>> We've installed geonode templates of testing version following these
>>>>> instructions: https://github.com/GeoNode/geonode-project/tree/2.4
>>>>> Any ideas?
>>>>> 2015-04-09 9:20 GMT+02:00 Annalisa Schiavon <
>>>>>> Well, errors are due to our development, but validate_templates still
>>>>>> gives those 2 errors ... we'll investigate.
>>>>>> Thanks
>>>>>> 2015-04-08 14:13 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> Seems that you are missing a django-autocomplete templates or the
>>>>>>> app itself. You can try to fix it with pip install django-autocomplete.
>>>>>>> 2015-04-08 14:04 GMT+02:00 Annalisa Schiavon <
>>>>>>>> Here it is:
>>>>>>>> Internal Server Error: /admin/layers/layer/8/
>>>>>>>> [Wed Apr 08 13:53:54.142311 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] Traceback (most recent call last):
>>>>>>>> [Wed Apr 08 13:53:54.142370 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 137,
>>>>>>>> in get_response
>>>>>>>> [Wed Apr 08 13:53:54.142425 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     response = response.render()
>>>>>>>> [Wed Apr 08 13:53:54.142478 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/response.py", line 105,
>>>>>>>> in render
>>>>>>>> [Wed Apr 08 13:53:54.142683 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     self.content = self.rendered_content
>>>>>>>> [Wed Apr 08 13:53:54.142738 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/response.py", line 82, in
>>>>>>>> rendered_content
>>>>>>>> [Wed Apr 08 13:53:54.142791 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     content = template.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.142853 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.142908 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return self._render(context)
>>>>>>>> [Wed Apr 08 13:53:54.142966 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
>>>>>>>> _render
>>>>>>>> [Wed Apr 08 13:53:54.143136 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return self.nodelist.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.143158 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.143179 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     bit = self.render_node(node, context)
>>>>>>>> [Wed Apr 08 13:53:54.143199 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.143221 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return node.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.143242 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line
>>>>>>>> 123, in render
>>>>>>>> [Wed Apr 08 13:53:54.143262 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return compiled_parent._render(context)
>>>>>>>> [Wed Apr 08 13:53:54.143282 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> _render
>>>>>>>> [Wed Apr 08 13:53:54.143304 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143324 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.143345 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143365 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.143387 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143407 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 123, in render
>>>>>>>> [Wed Apr 08 13:53:54.143428 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143448 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> _render
>>>>>>>> [Wed Apr 08 13:53:54.143479 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143499 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.143519 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143547 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.143568 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143588 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62,
>>>>>>>> in render
>>>>>>>> [Wed Apr 08 13:53:54.143608 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     result = block.nodelist.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.143630 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.143650 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143670 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.143691 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143712 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> in render
>>>>>>>> [Wed Apr 08 13:53:54.143733 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143753 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.143773 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143845 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.143876 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.143896 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/defaulttags.py", line
>>>>>>>> 203, in render
>>>>>>>> [Wed Apr 08 13:53:54.143917 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     nodelist.append(node.render(context))
>>>>>>>> [Wed Apr 08 13:53:54.143937 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 155, in render
>>>>>>>> [Wed Apr 08 13:53:54.144074 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return self.render_template(self.template, context)
>>>>>>>> [Wed Apr 08 13:53:54.144231 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 137, in render_template
>>>>>>>> [Wed Apr 08 13:53:54.144253 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     output = template.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.144281 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.144302 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144322 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> _render
>>>>>>>> [Wed Apr 08 13:53:54.144343 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144365 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.144385 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144406 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.144427 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144448 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 203, in render
>>>>>>>> [Wed Apr 08 13:53:54.144469 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144489 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 203, in render
>>>>>>>> [Wed Apr 08 13:53:54.144509 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144538 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 305, in render
>>>>>>>> [Wed Apr 08 13:53:54.144558 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return nodelist.render(context)
>>>>>>>> [Wed Apr 08 13:53:54.144579 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.144608 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144629 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.144661 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144687 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> 305, in render
>>>>>>>> [Wed Apr 08 13:53:54.144708 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144729 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.144749 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144821 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> render_node
>>>>>>>> [Wed Apr 08 13:53:54.144850 2015] [:error] [pid 1056:tid
>>>>>>>> [Wed Apr 08 13:53:54.144871 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 897, in
>>>>>>>> render
>>>>>>>> [Wed Apr 08 13:53:54.144892 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return render_value_in_context(output, context)
>>>>>>>> [Wed Apr 08 13:53:54.144912 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 875, in
>>>>>>>> [Wed Apr 08 13:53:54.144934 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     value = force_text(value)
>>>>>>>> [Wed Apr 08 13:53:54.144954 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/encoding.py", line 100, in
>>>>>>>> force_text
>>>>>>>> [Wed Apr 08 13:53:54.144975 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     s = s.__unicode__()
>>>>>>>> [Wed Apr 08 13:53:54.144995 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 425, in
>>>>>>>> __str__
>>>>>>>> [Wed Apr 08 13:53:54.145017 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return self.as_widget()
>>>>>>>> [Wed Apr 08 13:53:54.145037 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 475, in
>>>>>>>> as_widget
>>>>>>>> [Wed Apr 08 13:53:54.145058 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return widget.render(name, self.value(), attrs=attrs)
>>>>>>>> [Wed Apr 08 13:53:54.145078 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/contrib/admin/widgets.py", line
>>>>>>>> 254, in render
>>>>>>>> [Wed Apr 08 13:53:54.145100 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     output = [self.widget.render(name, value, *args, **kwargs)]
>>>>>>>> [Wed Apr 08 13:53:54.145120 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/autocomplete_light/widgets.py", line 133,
>>>>>>>> in render
>>>>>>>> [Wed Apr 08 13:53:54.145141 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     return safestring.mark_safe(render_to_string(templates,
>>>>>>>> context))
>>>>>>>> [Wed Apr 08 13:53:54.145161 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 160, in
>>>>>>>> render_to_string
>>>>>>>> [Wed Apr 08 13:53:54.145183 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     t = select_template(template_name)
>>>>>>>> [Wed Apr 08 13:53:54.145203 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 186, in
>>>>>>>> select_template
>>>>>>>> [Wed Apr 08 13:53:54.145223 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520]     raise TemplateDoesNotExist(', '.join(not_found))
>>>>>>>> [Wed Apr 08 13:53:54.145244 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] TemplateDoesNotExist: autocomplete_light/type/widget.html,
>>>>>>>> autocomplete_light//widget.html, autocomplete_light/widget.html
>>>>>>>> [Wed Apr 08 13:53:54.148382 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575] mod_wsgi (pid=1056):
>>>>>>>> Exception occurred processing WSGI script
>>>>>>>> '/home/nirweb_progetto/nirweb/nirweb/wsgi.py'.
>>>>>>>> [Wed Apr 08 13:53:54.148460 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575] Traceback (most recent
>>>>>>>> call last):
>>>>>>>> [Wed Apr 08 13:53:54.148499 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
>>>>>>>> in __call__
>>>>>>>> [Wed Apr 08 13:53:54.148554 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     response =
>>>>>>>> self.get_response(request)
>>>>>>>> [Wed Apr 08 13:53:54.148588 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
>>>>>>>> in get_response
>>>>>>>> [Wed Apr 08 13:53:54.148634 2015] [:error] [pid 1056:tid
>>>>>>>> self.handle_uncaught_exception(request, resolver, sys.exc_info())
>>>>>>>> [Wed Apr 08 13:53:54.148666 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
>>>>>>>> in handle_uncaught_exception
>>>>>>>> [Wed Apr 08 13:53:54.148797 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     return
>>>>>>>> callback(request, **param_dict)
>>>>>>>> [Wed Apr 08 13:53:54.148830 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
>>>>>>>> _wrapped_view
>>>>>>>> [Wed Apr 08 13:53:54.148877 2015] [:error] [pid 1056:tid
>>>>>>>> view_func(request, *args, **kwargs)
>>>>>>>> [Wed Apr 08 13:53:54.148908 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 43, in
>>>>>>>> server_error
>>>>>>>> [Wed Apr 08 13:53:54.148958 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     template =
>>>>>>>> loader.get_template(template_name)
>>>>>>>> [Wed Apr 08 13:53:54.148989 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 138, in
>>>>>>>> get_template
>>>>>>>> [Wed Apr 08 13:53:54.149036 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     template, origin =
>>>>>>>> find_template(template_name)
>>>>>>>> [Wed Apr 08 13:53:54.149067 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 127, in
>>>>>>>> find_template
>>>>>>>> [Wed Apr 08 13:53:54.149113 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     source, display_name
>>>>>>>> = loader(name, dirs)
>>>>>>>> [Wed Apr 08 13:53:54.149144 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 43, in
>>>>>>>> __call__
>>>>>>>> [Wed Apr 08 13:53:54.149181 2015] [:error] [pid 1056:tid
>>>>>>>> self.load_template(template_name, template_dirs)
>>>>>>>> [Wed Apr 08 13:53:54.149220 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 49, in
>>>>>>>> load_template
>>>>>>>> [Wed Apr 08 13:53:54.149257 2015] [:error] [pid 1056:tid
>>>>>>>> get_template_from_string(source, origin, template_name)
>>>>>>>> [Wed Apr 08 13:53:54.149290 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 149, in
>>>>>>>> [Wed Apr 08 13:53:54.149327 2015] [:error] [pid 1056:tid
>>>>>>>> Template(source, origin, name)
>>>>>>>> [Wed Apr 08 13:53:54.149367 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 125, in
>>>>>>>> __init__
>>>>>>>> [Wed Apr 08 13:53:54.149406 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     self.nodelist =
>>>>>>>> compile_string(template_string, origin)
>>>>>>>> [Wed Apr 08 13:53:54.149443 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 153, in
>>>>>>>> compile_string
>>>>>>>> [Wed Apr 08 13:53:54.149484 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     return parser.parse()
>>>>>>>> [Wed Apr 08 13:53:54.149524 2015] [:error] [pid 1056:tid
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 278, in
>>>>>>>> parse
>>>>>>>> [Wed Apr 08 13:53:54.149561 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     compiled_result =
>>>>>>>> compile_func(self, token)
>>>>>>>> [Wed Apr 08 13:53:54.149593 2015] [:error] [pid 1056:tid
>>>>>>>> 1084, in load
>>>>>>>> [Wed Apr 08 13:53:54.149644 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575]     (taglib, e))
>>>>>>>> [Wed Apr 08 13:53:54.149700 2015] [:error] [pid 1056:tid
>>>>>>>> 2950515520] [remote 192.168.225.19:27575] TemplateSyntaxError:
>>>>>>>> 'announcements_tags' is not a valid tag library: Template library
>>>>>>>> announcements_tags not found, tried
>>>>>>>> django.templatetags.announcements_tags,django.contrib.admin.templatetags.announcements_tags,django.contrib.staticfiles.templatetags.announcements_tags,django.contrib.humanize.templatetags.announcements_tags,avatar.templatetags.announcements_tags,geonode.base.templatetags.announcements_tags,geonode.social.templatetags.announcements_tags,geonode.upload.templatetags.announcements_tags
>>>>>>>> I've launched geonode validate_templates and give me 2 errors:
>>>>>>>> /usr/local/lib/python2.7/dist-packages/geonode/templates/relationships/_profile_
>>>>>>>>                follow.html: TemplateSyntaxError Invalid block tag:
>>>>>>>> 'if_relationship'
>>>>>>>> /usr/local/lib/python2.7/dist-packages/geonode/templates/relationships/relations
>>>>>>>>                hip_list.html: TemplateSyntaxError 'relationship_tags' is
>>>>>>>> not a valid tag librar                y: Template library relationship_tags
>>>>>>>> not found, tried django.templatetags.relat
>>>>>>>>  ionship_tags,django.contrib.admin.templatetags.relationship_tags,django.contrib.
>>>>>>>>  staticfiles.templatetags.relationship_tags,django.contrib.humanize.templatetags.
>>>>>>>>  relationship_tags,pagination.templatetags.relationship_tags,friendlytagloader.te
>>>>>>>>  mplatetags.relationship_tags,leaflet.templatetags.relationship_tags,django_exten
>>>>>>>>  sions.templatetags.relationship_tags,autocomplete_light.templatetags.relationshi
>>>>>>>>  p_tags,mptt.templatetags.relationship_tags,django_forms_bootstrap.templatetags.r
>>>>>>>>  elationship_tags,account.templatetags.relationship_tags,avatar.templatetags.rela
>>>>>>>>  tionship_tags,dialogos.templatetags.relationship_tags,agon_ratings.templatetags.
>>>>>>>>  relationship_tags,announcements.templatetags.relationship_tags,actstream.templat
>>>>>>>>  etags.relationship_tags,user_messages.templatetags.relationship_tags,polymorphic
>>>>>>>>  .templatetags.relationship_tags,guardian.templatetags.relationship_tags,geonode.
>>>>>>>>  base.templatetags.relationship_tags,geonode.social.templatetags.relationship_tag
>>>>>>>>                s,geonode.upload.templatetags.relationship_tags
>>>>>>>> Maybe I've to update something ....
>>>>>>>> 2015-04-08 13:02 GMT+02:00 Simone Dalmasso <
>>>>>>>>> Hi Annalisa, that is a generic Apache error. You can get more
>>>>>>>>> information with tail -f /var/log/apache2/error.log.
>>>>>>>>> You can post here the stacktrace.
>>>>>>>>> 2015-04-08 12:23 GMT+02:00 Annalisa Schiavon <
>>>>>>>>>> Hi list,
>>>>>>>>>> today, after a few days, I open my testing geonode but I don't
>>>>>>>>>> find any layer ...
>>>>>>>>>> Under admin panel there are my 8 layer, but when I select one
>>>>>>>>>> receive Internal server error -> mod_wsgi (pid=1056): Exception occurred
>>>>>>>>>> processing WSGI script '/home/nirweb_progetto/nirweb/nirweb/wsgi.py'
>>>>>>>>>> That wsgi.py is of our template.
>>>>>>>>>> Any ideas?
>>>>>>>>>> Thanks
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>> Simone
>>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150414/6062e270/attachment-0001.html>
More information about the geonode-users mailing list
