[GeoNode-users] ubuntu 12.04 LTS error installation
Vladimiro Bellini vlasvlasvlas at gmail.com
Wed Apr 22 10:24:15 PDT 2015
yep the Ubuntu 12.04 its a fresh brand new system.
and i do was following Ubuntu 12.04 online guides....
https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
maybe Ubuntu 12.04 guides must be modified, because they really dont work..
i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at all..
i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
thanks for the quick answer :)
Vladimiro Bellini              __
\ /| _ _|. _ . _ |__) _||. _ .
El 22 de abril de 2015, 14:15, Simone Dalmasso <simone.dalmasso at gmail.com>
escribió:
> Hi Vladimiro,
> thanks for posting here.
> is the ubuntu you are using a brand new system?
> Are you aware that there is the geonode 2.4 beta available for ubuntu
> 14.04 which has many many improvements from the 2.0?
> It's a beta but quite stable and we will not change its data model before
> the official release so any update should be smooth.
> To install it on 14.04 use ppa:geonode/testing instead of
> ppa:geonode/release.
> Regards
> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>> Hi,
>> i was installing geonode using ubuntu 12.04.5 LTS
>> I'm following this guide:
>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>> i have dependecies issue right on start:
>> root at ubuntu:/# cat /etc/issue
>> Ubuntu 12.04.5 LTS \n \l
>> root at ubuntu:/#
>> root at ubuntu:/# sudo apt-get install python-software-properties
>> Leyendo lista de paquetes... Hecho
>> Creando árbol de dependencias
>> Leyendo la información de estado... Hecho
>> python-software-properties ya está en su versión más reciente.
>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>> You are about to add the following PPA to your system:
>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>> Press [ENTER] to continue or ctrl-c to cancel adding it
>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>> gpg: Cantidad total procesada: 1
>> gpg:               importadas: 1  (RSA: 1)
>> OK
>> root at ubuntu:/#
>> root at ubuntu:/# sudo apt-get update
>> Obj http://ppa.launchpad.net precise Release.gpg
>> Obj http://es.archive.ubuntu.com precise Release.gpg
>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>> Obj http://ppa.launchpad.net precise/main Sources
>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>> Obj http://ppa.launchpad.net precise/main i386 Packages
>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>> Obj http://ppa.launchpad.net precise/main Translation-en
>> Obj http://es.archive.ubuntu.com precise/main Sources
>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>> Descargados 2.535 kB en 6seg. (395 kB/s)
>> root at ubuntu:/#
>> and now.. the error !
>> root at ubuntu:/# sudo apt-get install geonode
>> No se pudieron instalar algunos paquetes. Esto puede significar que
>> usted pidió una situación imposible o, si está usando la distribución
>> inestable, que algunos paquetes necesarios no han sido creados o han
>> sido movidos fuera de Incoming.
>> La siguiente información puede ayudar a resolver la situación:
>> Los siguientes paquetes tienen dependencias incumplidas:
>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>                     geoserver pero no va a instalarse
>>            Depende: python-virtualenv pero no es instalable
>>            Depende: python-pyproj pero no es instalable
>>            Depende: python-shapely pero no es instalable
>>            Depende: gdal-bin pero no es instalable
>>            Depende: libgeos-dev pero no es instalable
>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>                     postgresql-8.4-postgis pero no es instalable
>>            Depende: python-gdal pero no es instalable
>>            Depende: libproj-dev pero no es instalable
>>            Depende: python-django-downloadview pero no va a instalarse
>>            Depende: python-django-extensions pero no va a instalarse
>>            Depende: python-django-user-accounts pero no va a instalarse
>>            Depende: python-pycsw pero no va a instalarse
>>            Depende: python-paver pero no va a instalarse
>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>            Depende: python-multipartposthandler pero no es instalable
>>            Recomienda: python-gisdata pero no va a instalarse
>>            Recomienda: transifex-client pero no es instalable
>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>> root at ubuntu:/#
>> anyone know how this could be?
>> thanks!
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/e5fdab2a/attachment.html>
More information about the geonode-users mailing list
