[GeoNode-users] ubuntu 12.04 LTS error installation
Simone Dalmasso simone.dalmasso at gmail.com
Wed Apr 22 11:23:00 PDT 2015
:) you welcome. I will report back the status of the 2.0 installer here,
for the records.
Ciao
2015-04-22 20:18 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
> Installation with ubuntu 14.04 + ppa:geonode/testing works like charm
> thanks a lot! :)
> Vladimiro Bellini              __
> \ /| _ _|. _ . _ |__) _||. _ .
> 2015-04-22 14:43 GMT-03:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
> Simone, i'm testing with Ubuntu 14.04 + ppa:geonode/testing and
>> installation process started OK.
>> is now installing..
>> thanks a lot!
>> ill report if the whole process finish OK.
>> thanks again,
>> Vladimiro Bellini.
>> 2015-04-22 14:36 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> I will test tomorrow what's going on with the 12.04. This is the first
>>> time that I hear such error... Thanks for reporting.
>>> Il mercoledì 22 aprile 2015, Vladimiro Bellini <vlasvlasvlas at gmail.com>
>>> ha scritto:
>>>> Hi,
>>>> yep the Ubuntu 12.04 its a fresh brand new system.
>>>> and i do was following Ubuntu 12.04 online guides....
>>>> https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
>>>> maybe Ubuntu 12.04 guides must be modified, because they really dont
>>>> work..
>>>> i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at
>>>> all..
>>>> i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
>>>> thanks for the quick answer :)
>>>> El 22 de abril de 2015, 14:15, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> escribió:
>>>>> Hi Vladimiro,
>>>>> thanks for posting here.
>>>>> is the ubuntu you are using a brand new system?
>>>>> Are you aware that there is the geonode 2.4 beta available for ubuntu
>>>>> 14.04 which has many many improvements from the 2.0?
>>>>> It's a beta but quite stable and we will not change its data model
>>>>> before the official release so any update should be smooth.
>>>>> To install it on 14.04 use ppa:geonode/testing instead of
>>>>> ppa:geonode/release.
>>>>> Regards
>>>>> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>>>>>> Hi,
>>>>>> i was installing geonode using ubuntu 12.04.5 LTS
>>>>>> I'm following this guide:
>>>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>>>>>> i have dependecies issue right on start:
>>>>>> root at ubuntu:/# cat /etc/issue
>>>>>> Ubuntu 12.04.5 LTS \n \l
>>>>>> root at ubuntu:/#
>>>>>> root at ubuntu:/# sudo apt-get install python-software-properties
>>>>>> Leyendo lista de paquetes... Hecho
>>>>>> Creando árbol de dependencias
>>>>>> Leyendo la información de estado... Hecho
>>>>>> python-software-properties ya está en su versión más reciente.
>>>>>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>>>>>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>>>>>> You are about to add the following PPA to your system:
>>>>>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>>>>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>>>>>> Press [ENTER] to continue or ctrl-c to cancel adding it
>>>>>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>>>>>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>>>>>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>>>>>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>>>>>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>>>>>> gpg: Cantidad total procesada: 1
>>>>>> gpg:               importadas: 1  (RSA: 1)
>>>>>> OK
>>>>>> root at ubuntu:/#
>>>>>> root at ubuntu:/# sudo apt-get update
>>>>>> Obj http://ppa.launchpad.net precise Release.gpg
>>>>>> Obj http://es.archive.ubuntu.com precise Release.gpg
>>>>>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>>>>>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>>>>>> Obj http://ppa.launchpad.net precise/main Sources
>>>>>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>>>>>> Obj http://ppa.launchpad.net precise/main i386 Packages
>>>>>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>>>>>> Obj http://ppa.launchpad.net precise/main Translation-en
>>>>>> Obj http://es.archive.ubuntu.com precise/main Sources
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>>>>>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>>>>>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>>>>>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>>>>>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>>>>>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>>>>>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>>>>>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>>>>>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>>>>>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>>>>>> Descargados 2.535 kB en 6seg. (395 kB/s)
>>>>>> root at ubuntu:/#
>>>>>> and now.. the error !
>>>>>> root at ubuntu:/# sudo apt-get install geonode
>>>>>> No se pudieron instalar algunos paquetes. Esto puede significar que
>>>>>> usted pidió una situación imposible o, si está usando la distribución
>>>>>> inestable, que algunos paquetes necesarios no han sido creados o han
>>>>>> sido movidos fuera de Incoming.
>>>>>> La siguiente información puede ayudar a resolver la situación:
>>>>>> Los siguientes paquetes tienen dependencias incumplidas:
>>>>>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>>>>>                     geoserver pero no va a instalarse
>>>>>>            Depende: python-virtualenv pero no es instalable
>>>>>>            Depende: python-pyproj pero no es instalable
>>>>>>            Depende: python-shapely pero no es instalable
>>>>>>            Depende: gdal-bin pero no es instalable
>>>>>>            Depende: libgeos-dev pero no es instalable
>>>>>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>>>>>                     postgresql-8.4-postgis pero no es instalable
>>>>>>            Depende: python-gdal pero no es instalable
>>>>>>            Depende: libproj-dev pero no es instalable
>>>>>>            Depende: python-django-downloadview pero no va a instalarse
>>>>>>            Depende: python-django-extensions pero no va a instalarse
>>>>>>            Depende: python-django-user-accounts pero no va a instalarse
>>>>>>            Depende: python-pycsw pero no va a instalarse
>>>>>>            Depende: python-paver pero no va a instalarse
>>>>>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>>>>>            Depende: python-multipartposthandler pero no es instalable
>>>>>>            Recomienda: python-gisdata pero no va a instalarse
>>>>>>            Recomienda: transifex-client pero no es instalable
>>>>>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>>>>>> root at ubuntu:/#
>>>>>> anyone know how this could be?
>>>>>> thanks!
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/b73359f3/attachment-0001.html>
More information about the geonode-users mailing list
