[GeoNode-users] ubuntu 12.04 LTS error installation
Simone Dalmasso simone.dalmasso at gmail.com
Wed Apr 22 23:43:30 PDT 2015
I installed the 2.0 on ubuntu 12.04 LTS without problems this morning. I
really don't know what was wrong there...
2015-04-22 20:23 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> :) you welcome. I will report back the status of the 2.0 installer here,
> for the records.
> Ciao
> 2015-04-22 20:18 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>> Installation with ubuntu 14.04 + ppa:geonode/testing works like charm
>> thanks a lot! :)
>> Vladimiro Bellini              __
>> \ /| _ _|. _ . _ |__) _||. _ .
>> 2015-04-22 14:43 GMT-03:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>> Simone, i'm testing with Ubuntu 14.04 + ppa:geonode/testing and
>>> installation process started OK.
>>> is now installing..
>>> thanks a lot!
>>> ill report if the whole process finish OK.
>>> thanks again,
>>> Vladimiro Bellini.
>>> 2015-04-22 14:36 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> I will test tomorrow what's going on with the 12.04. This is the first
>>>> time that I hear such error... Thanks for reporting.
>>>> Il mercoledì 22 aprile 2015, Vladimiro Bellini <vlasvlasvlas at gmail.com>
>>>> ha scritto:
>>>>> Hi,
>>>>> yep the Ubuntu 12.04 its a fresh brand new system.
>>>>> and i do was following Ubuntu 12.04 online guides....
>>>>> https://geonode.readthedocs.org/en/master/tutorials/admin/install/quick_install.html
>>>>> maybe Ubuntu 12.04 guides must be modified, because they really dont
>>>>> work..
>>>>> i mean the "On Ubuntu 12.04 and older:" steps... really doesnt work at
>>>>> all..
>>>>> i ll do post the results using Ubuntu 14.04 + Geonode 2.4!
>>>>> thanks for the quick answer :)
>>>>> El 22 de abril de 2015, 14:15, Simone Dalmasso <
>>>>> simone.dalmasso at gmail.com> escribió:
>>>>>> Hi Vladimiro,
>>>>>> thanks for posting here.
>>>>>> is the ubuntu you are using a brand new system?
>>>>>> Are you aware that there is the geonode 2.4 beta available for ubuntu
>>>>>> 14.04 which has many many improvements from the 2.0?
>>>>>> It's a beta but quite stable and we will not change its data model
>>>>>> before the official release so any update should be smooth.
>>>>>> To install it on 14.04 use ppa:geonode/testing instead of
>>>>>> ppa:geonode/release.
>>>>>> Regards
>>>>>> 2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>
>>>>>>> Hi,
>>>>>>> i was installing geonode using ubuntu 12.04.5 LTS
>>>>>>> I'm following this guide:
>>>>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
>>>>>>> i have dependecies issue right on start:
>>>>>>> root at ubuntu:/# cat /etc/issue
>>>>>>> Ubuntu 12.04.5 LTS \n \l
>>>>>>> root at ubuntu:/#
>>>>>>> root at ubuntu:/# sudo apt-get install python-software-properties
>>>>>>> Leyendo lista de paquetes... Hecho
>>>>>>> Creando árbol de dependencias
>>>>>>> Leyendo la información de estado... Hecho
>>>>>>> python-software-properties ya está en su versión más reciente.
>>>>>>> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
>>>>>>> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
>>>>>>> You are about to add the following PPA to your system:
>>>>>>>  Ubuntu packages for GeoNode. More information at http://geonode.org
>>>>>>>  More info: https://launchpad.net/~geonode/+archive/ubuntu/release
>>>>>>> Press [ENTER] to continue or ctrl-c to cancel adding it
>>>>>>> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
>>>>>>> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
>>>>>>> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
>>>>>>> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
>>>>>>> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
>>>>>>> gpg: Cantidad total procesada: 1
>>>>>>> gpg:               importadas: 1  (RSA: 1)
>>>>>>> OK
>>>>>>> root at ubuntu:/#
>>>>>>> root at ubuntu:/# sudo apt-get update
>>>>>>> Obj http://ppa.launchpad.net precise Release.gpg
>>>>>>> Obj http://es.archive.ubuntu.com precise Release.gpg
>>>>>>> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
>>>>>>> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
>>>>>>> Obj http://ppa.launchpad.net precise/main Sources
>>>>>>> Obj http://ppa.launchpad.net precise/main amd64 Packages
>>>>>>> Obj http://ppa.launchpad.net precise/main i386 Packages
>>>>>>> Obj http://ppa.launchpad.net precise/main TranslationIndex
>>>>>>> Obj http://ppa.launchpad.net precise/main Translation-en
>>>>>>> Obj http://es.archive.ubuntu.com precise/main Sources
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Sources
>>>>>>> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
>>>>>>> Obj http://es.archive.ubuntu.com precise/main i386 Packages
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
>>>>>>> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
>>>>>>> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
>>>>>>> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
>>>>>>> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
>>>>>>> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
>>>>>>> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
>>>>>>> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
>>>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-es
>>>>>>> Obj http://es.archive.ubuntu.com precise/main Translation-en
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
>>>>>>> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
>>>>>>> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
>>>>>>> Descargados 2.535 kB en 6seg. (395 kB/s)
>>>>>>> root at ubuntu:/#
>>>>>>> and now.. the error !
>>>>>>> root at ubuntu:/# sudo apt-get install geonode
>>>>>>> No se pudieron instalar algunos paquetes. Esto puede significar que
>>>>>>> usted pidió una situación imposible o, si está usando la distribución
>>>>>>> inestable, que algunos paquetes necesarios no han sido creados o han
>>>>>>> sido movidos fuera de Incoming.
>>>>>>> La siguiente información puede ayudar a resolver la situación:
>>>>>>> Los siguientes paquetes tienen dependencias incumplidas:
>>>>>>>  geonode : Depende: geoserver-geonode pero no va a instalarse o
>>>>>>>                     geoserver pero no va a instalarse
>>>>>>>            Depende: python-virtualenv pero no es instalable
>>>>>>>            Depende: python-pyproj pero no es instalable
>>>>>>>            Depende: python-shapely pero no es instalable
>>>>>>>            Depende: gdal-bin pero no es instalable
>>>>>>>            Depende: libgeos-dev pero no es instalable
>>>>>>>            Depende: postgresql-9.1-postgis pero no es instalable o
>>>>>>>                     postgresql-8.4-postgis pero no es instalable
>>>>>>>            Depende: python-gdal pero no es instalable
>>>>>>>            Depende: libproj-dev pero no es instalable
>>>>>>>            Depende: python-django-downloadview pero no va a instalarse
>>>>>>>            Depende: python-django-extensions pero no va a instalarse
>>>>>>>            Depende: python-django-user-accounts pero no va a instalarse
>>>>>>>            Depende: python-pycsw pero no va a instalarse
>>>>>>>            Depende: python-paver pero no va a instalarse
>>>>>>>            Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
>>>>>>>            Depende: python-multipartposthandler pero no es instalable
>>>>>>>            Recomienda: python-gisdata pero no va a instalarse
>>>>>>>            Recomienda: transifex-client pero no es instalable
>>>>>>> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
>>>>>>> root at ubuntu:/#
>>>>>>> anyone know how this could be?
>>>>>>> thanks!
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150423/c46480d9/attachment-0001.html>
More information about the geonode-users mailing list
