[GeoNode-users] can't upload vector layers, but rasters okay
Charles Cossé ccosse at gmail.com
Thu Aug 20 11:45:40 PDT 2015
Hi Simone,
I've just gone through everywhere carefully and no luck.  I used the same
password for everything in the following files (if applicable):
   - /etc/geonode/local_settings.py
   - /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py
   - /usr/local/lib/python2.7/dist-packages/geonode/settings.py
   - /var/www/my_geonode/my_geonode/settings.py
Also same password through Django-Admin and Geoserver-Admin, both.
Restarted services and same result, which is Raster uploads work and vector
layers don't work.  Everything used to work fine, though.
This is the error reported through the UploadLayersGUI, in a tan-colored
container div:
An exception occurred loading data to PostGIS- java.io.IOException
Thanks for any more ideas,
Charles
On Thu, Aug 20, 2015 at 10:25 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi Charles, did you change the geoserver admin login here?
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L498,
> if yes make sure you also updated them in geoserver, you can use the
> geoserver web interface.
> 2015-08-20 16:09 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
>> Hello GeoNode Team,
>> Recently my geonode instance has developed a problem whereby I can
>> upload/view raster layers but not vector layers.  Here are select lines
>> from catalina.out when the upload of a vector layer fails:
>> -----------8<---------
>> 20 Aug 06:34:58 ERROR [geoserver.rest] - No such datastore:
>> geonode,mainrivers_1
>> 20 Aug 06:34:58 ERROR [geoserver.rest] - No such wms store:
>> Caused by: java.lang.RuntimeException: Unable to obtain connection:
>> Cannot create PoolableConnectionFactory (FATAL: password authentication
>> failed for user "geonode")
>> I have triple-checked the geonode password everywhere (local_settings.py,
>> manage-shell, setting psql) and restarted services many times but the
>> problem persists.  I can login using dbshell with my geonode password, so I
>> think that it's set correctly.  If the problem really was the geonode db's
>> password then I would expect raster layer operations to fail as well, but
>> they work fine ... so I'm appealing for help before doing anything drastic.
>> Thank you,
>> Charles Cossé
>> Protected Areas Commission &
>> Geospatial Information Management Unit
>> Georgetown, Guyana
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150820/bba1393f/attachment.html>
More information about the geonode-users mailing list
