[GeoNode-users] [geonode] Errors were encountered while processing: geoserver-geonode geonode (#2371)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Dec 1 08:03:06 PST 2015
GeoNode runs on port 8000 only GeoServer runs on port 8080.
So you should be able to access your GeoNode at http://54.152.180.217:8000/
If you need to put everything under the same domain/port you need to proxy
the TCP endpoints using an http server like apache, ngnix, ...
Hope this helps,
-A.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Dec 1, 2015 at 4:34 PM, Jessel, Tanner Monroe <tjessel at utk.edu>
wrote:
> Hi Alessio, thanks.
> No, I did not execute dependencies setup steps.
> I'm new to ubuntu and really just wanted to follow the "quick" install
> outlined here:
> http://geonode.org/blog/2015/11/19/geonode-2.4-released/
> I don't really understand what happened, but I did avoid the error I
> had by doing what you suggested.
> (If it's of interest / useful for documentation I'm sending the
> new CLI session text output)
> Now I have a new question:
> I can access geonode at
> http://localhost:8000/ <http://localhost:8080/geonode>
> I can access the geoserver associated with the geonode install online at
> http://54.152.180.217:8080/geoserver/web/
> But, I can't access the geonode at http://54.152.180.217:8080/
> I'm guessing I need to do some more manual configuration?
> I'm a bit terrified of messing something up, which is why I was hoping the
> "quick install" would work.
> Can you recommend a particular place in the instructions for a custom
> install that I should pick up at?
> I'm looking at this right now:
> http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#configure-using-the-ubuntu-config-file
> Thanks again, and looking forward to additional hints.
> -Tanner
> *From:* alessio.fabiani at gmail.com <alessio.fabiani at gmail.com> on behalf
> of Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Sent:* Tuesday, December 1, 2015 5:05 AM
> *To:* Jessel, Tanner Monroe
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] [geonode] Errors were encountered while
> Did you executed the dependencies setup steps?
> # change into the folder called geonde$ cd geonode
> # Installs django etc.$ sudo pip install -e .
> # Downloads geoserver.war$ sudo paver setup
> GeoServer Professional Services from the experts! Visit
> Enterprise Support and Development Services
> GeoSolutions offers enterprise support and development services tobuild
> enterprise-class Spatial Data Infrastructures (SDI) with Open Source
> components.
> Read more... <http://goo.gl/NWWaa2>
> @alfa7691
> GeoSolutions S.A.S.
> Italy
> http://twitter.com/geosolutions_it
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Nov 30, 2015 at 2:36 PM, Jessel, Tanner Monroe <tjessel at utk.edu>
> wrote:
>> Good morning,
>> Thanks.
>> It's a new and fresh ubuntu;
>> I actually just set up a new one this morning and had the same problem.
>> I'm attaching the CLI session as text...
>> The errors are below:
>> Creating config file /etc/logrotate.d/tomcat7 with new version
>>  * Starting Tomcat servlet engine tomcat7
>>                 [ OK ]
>> Processing triggers for ureadahead (0.100.0-16) ...
>> Setting up geoserver-geonode (2.7.4-2) ...
>>  * Stopping Tomcat servlet engine tomcat7
>>                 [ OK ]
>>                 [fail]
>> dpkg: error processing package geoserver-geonode (--configure):
>>  subprocess installed post-installation script returned error exit status
>> 1
>> dpkg: dependency problems prevent configuration of geonode:
>>  geonode depends on geoserver-geonode | geoserver; however:
>>   Package geoserver-geonode is not configured yet.
>>   Package geoserver is not installed.
>> dpkg: error processing package geonode (--configure):
>>  dependency problems - leaving unconfigured
>> Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
>> No apport report written because the error message indicates its a
>> followup error from a previous failure.
>>           Processing triggers for ufw (0.34~rc-0ubuntu2) ...
>> Processing triggers for python-support (1.0.15) ...
>> Processing triggers for ca-certificates (20141019ubuntu0.14.04.1) ...
>> Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
>> Running hooks in /etc/ca-certificates/update.d....
>> done.
>> done.
>>  geoserver-geonode
>>  geonode
>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>> ubuntu at ip-172-31-59-87:~$
>> -Tanner
>> *From:* Simone Dalmasso <notifications at github.com>
>> *Sent:* Monday, November 30, 2015 4:23 AM
>> *To:* GeoNode/geonode
>> *Cc:* Jessel, Tanner Monroe
>> *Subject:* Re: [geonode] Errors were encountered while processing:
>> Hi GeoNode should install smoothly on ubuntu server 14.04. Is the same Os
>> we use for demo.geonode.org.
>> Did you install it on a new and fresh ubuntu?
>> ps, please use the mailing lists geonode-users at lists.osgeo.org rather
>> than tickets to ask for support
>>>> Reply to this email directly or view it on GitHub
>> <https://github.com/GeoNode/geonode/issues/2371#issuecomment-160568535>.
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151201/7c60f458/attachment-0001.html>
More information about the geonode-users mailing list
