[GeoNode-users] geonode no maps and layer
Simone Dalmasso simone.dalmasso at gmail.com
Thu Dec 3 07:03:22 PST 2015
Hi Eugenio,
I think that you pulled from master, but on master we introduced new
developments that involve metadata change. If you can't migrate the db by
your own I suggest you to revert to the 2.4.0 tag.
2015-12-03 15:48 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi all,
> today I controlled my geonode home page. It seemed to work fine, since the
> home page
> showed 15 layers and 5 maps. However if I click on layers, any layers
> appears in the list.
> The same happens form maps and documents.
> I tried to launch updatelayers with any result.
> The I re-sync the DB and updatelayers, but no results, only an error:
> python manage.py updatelayers
> Not enabling BingMaps base layer as a BING_API_KEY is not defined in
> local_settings.py file.
> Stopping process because --ignore-errors was not set and an error was
> found.
> Traceback (most recent call last):
>   File "manage.py", line 28, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
>     utility.execute()
>   File
> line 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 242, in run_from_argv
>     self.execute(*args, **options.__dict__)
>   File
> line 285, in execute
>     output = self.handle(*args, **options)
>   File
> "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py", line
> 108, in handle
>     remove_deleted=remove_deleted)
>   File "/dati/geonode/geonode/geoserver/helpers.py", line 458, in gs_slurp
>     "bbox_y1": Decimal(resource.latlon_bbox[3])
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py", line
> 154, in get_or_create
>     return self.get_queryset().get_or_create(**kwargs)
>   File
> "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py", line
> 341, in get_or_create
>     return super(MultilingualQuerySet, self).get_or_create(**kwargs)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 376, in get_or_create
>     return self.get(**lookup), False
> line 304, in get
>     num = len(clone)
> line 77, in __len__
>     self._fetch_all()
> line 857, in _fetch_all
>     self._result_cache = list(self.iterator())
>   File "/usr/local/lib/python2.7/dist-packages/polymorphic/query.py", line
> 264, in iterator
>     for o in base_iter:
> line 220, in iterator
>     for row in compiler.results_iter():
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py",
> line 713, in results_iter
>     for rows in self.execute_sql(MULTI):
>   File
> line 786, in execute_sql
>     cursor.execute(sql, params)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line
> 69, in execute
>     return super(CursorDebugWrapper, self).execute(sql, params)
>   File
> 53, in execute
>     return self.cursor.execute(sql, params)
>   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line
> 99, in __exit__
>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>   File
> 53, in execute
> Exception: ('Failed to process reg2001_s_wgs84utm33',
> ProgrammingError('column base_resourcebase.metadata_uploaded_preserve does
> not exist\nLINE 1: ...ometry", "base_resourcebase"."metadata_uploaded",
> "base_reso...\n
> ^\n',))
> Afterwords I updated also the geonode code from git, re-sync DB and
> updatelayer, but again the same error.
> I checked the DB, the maps and layer are correctly described in the rows.
> I think it is a connection problem between geonode and postgresql/postgis.
> Isn't it? If yes, how can I solve?
> Thanks in advance
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151203/b75acb68/attachment-0001.html>
More information about the geonode-users mailing list
