[GeoNode-users] error on saving maps, again!
Francesco Bartoli xbartolone at gmail.com
Sat Dec 5 09:03:21 PST 2015
Hi Eugenio,
what version are you running? Did your unsaved map contain remote any layer from remote service?
Francesco
Il giorno 04/dic/2015, alle ore 16:51, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
> Dear Simone and all,
> I'm very sad to announce you that I'm getting the same error I got 1 month ago.
> I got an error on saving maps, and I retrieve the same error in apache error.log:
> [Fri Dec 04 16:40:39.271057 2015] [core:notice] [pid 15782] AH00051: child pid 26334 exit signal Segmentation fault (11), possible coredump in /etc/apache2
> same stuff on segmentation fault!
> I can consider me very unlucky on this installation.
> Actually It was 10 days up to yesterday that I did not use geonode, but I'm sure it was working fine.
> Yesterday I had the problem raised on the geonode user mailing list, so today I decided to upgrade all geonode system.
> The installation went fine, but I have the same problem on saving map.
> I don't understand what happen.
> I solved this problem upgrading the server from 12.04 up to 14.04 version. This task was a bit time spending but all the applications
> as well as geonode then worked fine.
> In the meanwhile no important activities I performed on the server, only a few OS update.
> Can you help me again?
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151205/9f5e727f/attachment.html>
More information about the geonode-users mailing list
