[GeoNode-users] error on saving maps, again!
Francesco Bartoli xbartolone at gmail.com
Sun Dec 6 07:33:10 PST 2015
Eugenio,
a possible way to investigate more your problem is to attach httpd child process to gdb, cause it’s not reproducible. Follow instructions in this blog [1] and then look at the next crash.
Francesco
[1] http://sysadmin.carlusgg.com/?p=197
Il giorno 06/dic/2015, alle ore 10:58, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
> Hi Francesco,
> I'm trying  to use geonode 2.4.dev20151203130956.
> I tried to save both an empty map and one containing a wms from an external geoserver. Same error.
> I also tried to upload a new layer for using it on a new map, but that geonode version misses the category choose, so I got error also on upload a shp file.
> Any idea on the reason of my problem?
> Eugenio
> Subject: Re: [GeoNode-users] error on saving maps, again!
> From: xbartolone at gmail.com
> Date: Sat, 5 Dec 2015 18:03:21 +0100
> CC: simone.dalmasso at gmail.com; geonode-users at lists.osgeo.org
> To: frippe12573 at hotmail.com
> Hi Eugenio,
> what version are you running? Did your unsaved map contain remote any layer from remote service?
> Francesco
> Il giorno 04/dic/2015, alle ore 16:51, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
> Dear Simone and all,
> I'm very sad to announce you that I'm getting the same error I got 1 month ago.
> I got an error on saving maps, and I retrieve the same error in apache error.log:
> [Fri Dec 04 16:40:39.271057 2015] [core:notice] [pid 15782] AH00051: child pid 26334 exit signal Segmentation fault (11), possible coredump in /etc/apache2
> same stuff on segmentation fault!
> I can consider me very unlucky on this installation.
> Actually It was 10 days up to yesterday that I did not use geonode, but I'm sure it was working fine.
> Yesterday I had the problem raised on the geonode user mailing list, so today I decided to upgrade all geonode system.
> The installation went fine, but I have the same problem on saving map.
> I don't understand what happen.
> I solved this problem upgrading the server from 12.04 up to 14.04 version. This task was a bit time spending but all the applications
> as well as geonode then worked fine.
> In the meanwhile no important activities I performed on the server, only a few OS update.
> Can you help me again?
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151206/4a7da59f/attachment.html>
More information about the geonode-users mailing list
