[GeoNode-users] Cannot load geonode page: DoesNotExist: Site matching query does not exist. IntegrityError: Problem installing fixture
Ariel Nunez ingenieroariel at gmail.com
Mon Dec 14 06:06:24 PST 2015
Hello Rajib,
Since you deleted the default Site (with id=1) instead of editing the site
name and url this caused problems with the permissions and all around the
site.
Your best bet is to create a new Site object with id =1 and the right name
and dome. Are you familiar with pgadminIII ? You can use that to connect to
your database and recreate the missing entry in sites_site graphically.
-a
On Sun, Dec 13, 2015 at 12:29 AM, Shah Md. Rajibul Islam <
rajibul.islam at cdmp.org.bd> wrote:
> Hi,
> I am using geonode 2.0 on Ubuntu 12.04
> I am having a problem while loading the geonode site as follows-
> *“There was a problem loading this page. Please contact your GeoNode
> administrator (he may have received an email automatically if he configured
> it properly). If you are the site administrator, enable debug mode to see
> the actual error and fix it or file an issue in GeoNode's issue tracker”*
> It probably happened when I deleted the IP address from geoserver site
> management and add a site name geonode.dmic.org.bd. However, I have added
> the IP again to the site.
> I tried to update the IP again using *sudo geonode-updateip 203.83.183.18*
> and gives following error:
> *DoesNotExist: Site matching query does not exist.*
> When I run the *sudo apt-get install --reinstall geonode *command it
> gives following error message:
> *IntegrityError: Problem installing fixture
> '/usr/local/lib/python2.7/dist-packag
>                                                  es/geonode/layers/fixtures/initial_data.json':
> Could not load
> security.GenericOb
> jectRoleMapping(pk=3): duplicate key value violates unique constraint
> "security_
> genericobjectrolemap_subject_object_ct_id_object_i_key"*
> *DETAIL:  Key (subject, object_ct_id, object_id, role_id)=(anonymous, 42,
> 1, 4) already exists.*
> Is there any suggestions please?
> Best regards
> Rajib
> *Shah Md. Rajibul Islam*
> *GIS Analyst*
> CDMP – II, UNDP
> Disaster Management & Relief Bhaban
> 92-93, Mohakhali C/A, Dhaka - 1212
> Tel # 989 0937; 882 1255; 882 1459, Ext - 303
> Mobile: +88 01716 027389, E-mail: rajibul.islam at cdmp.org.bd
> Web: www.cdmp.org.bd
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151214/dccff78d/attachment-0001.html>
More information about the geonode-users mailing list
