[GeoNode-users] How Add Custom Metadata Fields
Ariel Nunez ingenieroariel at gmail.com
Thu Dec 17 11:17:42 PST 2015
Joan, you can do:
python
import geonode
print geonode.__file__
and then go to that location to find the right file.
-a
On Thu, Dec 17, 2015 at 1:45 PM, Joan <joan.machado at gmail.com> wrote:
> Hi thank you for all, but I try to follow your steps, however I can't find
> the geonode/base/forms.py file anywhere!
> root at osmtest:~# sudo find / -iname '*forms.py*' -type f -exec grep -l
> 'Resource
> BaseForm' {} \;
> root at osmtest:~#_
> No match results found!
> can you help me please?.
> regards.
> Joan.
> 2015-12-16 5:30 GMT-06:00 Tom Kralidis <tomkralidis at gmail.com>:
>> On Wed, 16 Dec 2015, Simone Dalmasso wrote:
>> Date: Wed, 16 Dec 2015 12:15:09 +0100
>>> From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>> To: Joan <joan.machado at gmail.com>
>>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>> Subject: Re: [GeoNode-users] How Add Custom Metadata Fields
>>> Hi,
>>> to add fields you have to add them to the ResourceBase model:
>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L205
>>> then make sure the form supports them
>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/forms.py#L59
>>> and the pycsw catalogue as well (@tomkralidis correct me):
>>> https://github.com/GeoNode/geonode/blob/master/geonode/catalogue/backends/pycsw_local_mappings.py
>> pycsw stores one field per CSW queryable.  If the fields being added are
>> CSW
>> queryables, then they can be added here.  Otherwise, pycsw will work as
>> expected for freetext/spatial/attribute searches.
>>> 2015-12-15 21:00 GMT+01:00 Joan <joan.machado at gmail.com>:
>>> Hi, we are preparing the GeoNode for a project, where we need add several
>>>> custom metadata fields.
>>>> Help me please.
>>>> Regards.
>>>> Joan.
> [image: recicla2] *NO imprima este email, a menos que sea muy necesario.
> Salvemos árboles*
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151217/08cc35e6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151217/08cc35e6/attachment-0001.png>
More information about the geonode-users mailing list
