[GeoNode-users] How Add Custom Metadata Fields
Simone Dalmasso simone.dalmasso at gmail.com
Thu Dec 17 11:51:22 PST 2015
Hi. You should follow the developer docs
http://docs.geonode.org/en/master/tutorials/devel/index.html
there's everything to get started with the GeoNode development
2015-12-17 20:32 GMT+01:00 Joan <joan.machado at gmail.com>:
> Thanks Ariel, I have all ready done what you say, but there isn't the
> forms.py file
> [image: Imágenes integradas 1]
> anything else than I can to do? thanks
> J.
> 2015-12-17 13:17 GMT-06:00 Ariel Nunez <ingenieroariel at gmail.com>:
>> Joan, you can do:
>> python
>> import geonode
>> print geonode.__file__
>> and then go to that location to find the right file.
>> -a
>> On Thu, Dec 17, 2015 at 1:45 PM, Joan <joan.machado at gmail.com> wrote:
>>> Hi thank you for all, but I try to follow your steps, however I can't
>>> find the geonode/base/forms.py file anywhere!
>>> root at osmtest:~# sudo find / -iname '*forms.py*' -type f -exec grep -l
>>> 'Resource
>>> BaseForm' {} \;
>>> root at osmtest:~#_
>>> No match results found!
>>> can you help me please?.
>>> regards.
>>> Joan.
>>> 2015-12-16 5:30 GMT-06:00 Tom Kralidis <tomkralidis at gmail.com>:
>>>> On Wed, 16 Dec 2015, Simone Dalmasso wrote:
>>>> Date: Wed, 16 Dec 2015 12:15:09 +0100
>>>>> From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> To: Joan <joan.machado at gmail.com>
>>>>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>>>> Subject: Re: [GeoNode-users] How Add Custom Metadata Fields
>>>>> Hi,
>>>>> to add fields you have to add them to the ResourceBase model:
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L205
>>>>> then make sure the form supports them
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/forms.py#L59
>>>>> and the pycsw catalogue as well (@tomkralidis correct me):
>>>>> https://github.com/GeoNode/geonode/blob/master/geonode/catalogue/backends/pycsw_local_mappings.py
>>>> pycsw stores one field per CSW queryable.  If the fields being added
>>>> are CSW
>>>> queryables, then they can be added here.  Otherwise, pycsw will work as
>>>> expected for freetext/spatial/attribute searches.
>>>>> 2015-12-15 21:00 GMT+01:00 Joan <joan.machado at gmail.com>:
>>>>> Hi, we are preparing the GeoNode for a project, where we need add
>>>>>> several
>>>>>> custom metadata fields.
>>>>>> Help me please.
>>>>>> Regards.
>>>>>> Joan.
>>> [image: recicla2] *NO imprima este email, a menos que sea muy
>>> necesario. Salvemos árboles*
>>> geonode-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> [image: recicla2] *NO imprima este email, a menos que sea muy necesario.
> Salvemos árboles*
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151217/5d9dbe88/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151217/5d9dbe88/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151217/5d9dbe88/attachment-0003.png>
More information about the geonode-users mailing list
