[GeoNode-users] Cannot load geonode page: DoesNotExist: Site matching query does not exist. IntegrityError: Problem installing fixture
Paolo Corti pcorti at gmail.com
Tue Dec 22 09:43:22 PST 2015
Then do a ssh connection to the server, and use psql in place of pgadmin
regards
p
On Tue, Dec 22, 2015 at 3:55 AM, Shah Md. Rajibul Islam
<rajibul.islam at cdmp.org.bd> wrote:
> Dear Ariel,
> Thank you for your reply and I am really sorry for late reply.
> Is there other way to do the required task you mentioned? It would be better
> if I can do this using ssh client putty.
> Looking forward to your reply.
> Best regards
> Rajib
> Sent from Samsung Mobile
> -------- Original message --------
> From: Ariel Nunez <ingenieroariel at gmail.com>
> Date: 12/14/2015 8:06 PM (GMT+06:00)
> To: "Shah Md. Rajibul Islam" <rajibul.islam at cdmp.org.bd>
> Cc: geonode-users at lists.osgeo.org
> Subject: Re: [GeoNode-users] Cannot load geonode page: DoesNotExist: Site
> Hello Rajib,
> Since you deleted the default Site (with id=1) instead of editing the site
> name and url this caused problems with the permissions and all around the
> site.
> Your best bet is to create a new Site object with id =1 and the right name
> and dome. Are you familiar with pgadminIII ? You can use that to connect to
> your database and recreate the missing entry in sites_site graphically.
> -a
> On Sun, Dec 13, 2015 at 12:29 AM, Shah Md. Rajibul Islam
>> Hi,
>> I am using geonode 2.0 on Ubuntu 12.04
>> I am having a problem while loading the geonode site as follows-
>> “There was a problem loading this page. Please contact your GeoNode
>> administrator (he may have received an email automatically if he configured
>> it properly). If you are the site administrator, enable debug mode to see
>> the actual error and fix it or file an issue in GeoNode's issue tracker”
>> It probably happened when I deleted the IP address from geoserver site
>> management and add a site name geonode.dmic.org.bd. However, I have added
>> the IP again to the site.
>> I tried to update the IP again using sudo geonode-updateip 203.83.183.18
>> and gives following error:
>> When I run the sudo apt-get install --reinstall geonode command it gives
>> following error message:
>> '/usr/local/lib/python2.7/dist-packag
>> es/geonode/layers/fixtures/initial_data.json': Could not load
>> security.GenericOb
>> jectRoleMapping(pk=3): duplicate key value violates unique constraint
>> "security_
>> genericobjectrolemap_subject_object_ct_id_object_i_key"
>> DETAIL:  Key (subject, object_ct_id, object_id, role_id)=(anonymous, 42,
>> 1, 4) already exists.
>> Is there any suggestions please?
>> Best regards
>> Rajib
>> GIS Analyst
>> CDMP – II, UNDP
>> Disaster Management & Relief Bhaban
>> 92-93, Mohakhali C/A, Dhaka - 1212
>> Tel # 989 0937; 882 1255; 882 1459, Ext - 303
>> Mobile: +88 01716 027389, E-mail: rajibul.islam at cdmp.org.bd
>> Web: www.cdmp.org.bd
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
