[GeoNode-users] Cannot load geonode page: DoesNotExist: Site matching query does not exist. IntegrityError: Problem installing fixture
Paolo Corti pcorti at gmail.com
Tue Dec 22 13:43:13 PST 2015
something like (not tested it):
ssh user at servername (not sure how it works on putty)
sudo su postgres
psql databasename
insert into django_site (id, domain, name) values (1, 'domain', 'name');
regards
p
On Tue, Dec 22, 2015 at 1:45 PM, Shah Md. Rajibul Islam
<rajibul.islam at cdmp.org.bd> wrote:
> Dear Paolo,
> Thank you for your reply. I am not good in psql and related coding as well
> and have very limited programming knowledge. It would be very helpful for me
> if you could also tell me the steps and codes that I have follow to do this.
> Best regards
> Rajib
> On Tue, Dec 22, 2015 at 11:43 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Then do a ssh connection to the server, and use psql in place of pgadmin
>> regards
>> p
>> On Tue, Dec 22, 2015 at 3:55 AM, Shah Md. Rajibul Islam
>> > Dear Ariel,
>> > Thank you for your reply and I am really sorry for late reply.
>> > Is there other way to do the required task you mentioned? It would be
>> > better
>> > if I can do this using ssh client putty.
>> > Looking forward to your reply.
>> > Best regards
>> > Rajib
>> > Sent from Samsung Mobile
>> > -------- Original message --------
>> > From: Ariel Nunez <ingenieroariel at gmail.com>
>> > Date: 12/14/2015 8:06 PM (GMT+06:00)
>> > To: "Shah Md. Rajibul Islam" <rajibul.islam at cdmp.org.bd>
>> > Cc: geonode-users at lists.osgeo.org
>> > Subject: Re: [GeoNode-users] Cannot load geonode page: DoesNotExist:
>> > Site
>> > fixture
>> > Hello Rajib,
>> > Since you deleted the default Site (with id=1) instead of editing the
>> > site
>> > name and url this caused problems with the permissions and all around
>> > the
>> > site.
>> > Your best bet is to create a new Site object with id =1 and the right
>> > name
>> > and dome. Are you familiar with pgadminIII ? You can use that to connect
>> > to
>> > your database and recreate the missing entry in sites_site graphically.
>> > -a
>> > On Sun, Dec 13, 2015 at 12:29 AM, Shah Md. Rajibul Islam
>> >> Hi,
>> >> I am using geonode 2.0 on Ubuntu 12.04
>> >> I am having a problem while loading the geonode site as follows-
>> >> “There was a problem loading this page. Please contact your GeoNode
>> >> administrator (he may have received an email automatically if he
>> >> configured
>> >> it properly). If you are the site administrator, enable debug mode to
>> >> see
>> >> the actual error and fix it or file an issue in GeoNode's issue
>> >> tracker”
>> >> It probably happened when I deleted the IP address from geoserver site
>> >> management and add a site name geonode.dmic.org.bd. However, I have
>> >> added
>> >> the IP again to the site.
>> >> I tried to update the IP again using sudo geonode-updateip
>> >> 203.83.183.18
>> >> and gives following error:
>> >> When I run the sudo apt-get install --reinstall geonode command it
>> >> gives
>> >> following error message:
>> >> '/usr/local/lib/python2.7/dist-packag
>> >> es/geonode/layers/fixtures/initial_data.json': Could not load
>> >> security.GenericOb
>> >> jectRoleMapping(pk=3): duplicate key value violates unique constraint
>> >> "security_
>> >> genericobjectrolemap_subject_object_ct_id_object_i_key"
>> >> DETAIL:  Key (subject, object_ct_id, object_id, role_id)=(anonymous,
>> >> 42,
>> >> 1, 4) already exists.
>> >> Is there any suggestions please?
>> >> Best regards
>> >> Rajib
>> >> GIS Analyst
>> >> CDMP – II, UNDP
>> >> Disaster Management & Relief Bhaban
>> >> 92-93, Mohakhali C/A, Dhaka - 1212
>> >> Tel # 989 0937; 882 1255; 882 1459, Ext - 303
>> >> Mobile: +88 01716 027389, E-mail: rajibul.islam at cdmp.org.bd
>> >> Web: www.cdmp.org.bd
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> GIS Analyst
> CDMP – II, UNDP
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
