[GeoNode-users] An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table
Rajib Islam rajiburp at gmail.com
Tue Dec 22 20:02:35 PST 2015
I just follow the commands of the *create geonode DB **of dmin docs * (
http://docs.geonode.org/en/latest/tutorials/install_and_admin/geonode_install/create_geonode_db.html).
For me, this was basically a permission related issue.
Regards
Rajib
> Regards
> Rajib
> On Wed, Dec 23, 2015 at 5:40 AM, John Jediny <john.jediny at gmail.com>
> wrote:
>> What did you do?
>> On Dec 16, 2015 11:04 AM, "Rajib Islam" <rajiburp at gmail.com> wrote:
>>> I have solved this problem. Thank you.
>>> On Mon, Dec 14, 2015 at 2:42 PM, Rajib Islam <rajiburp at gmail.com> wrote:
>>>> Dear Users,
>>>> I have installed GeoNode 2.4 stable version on Ubuntu 14.04 into a real
>>>> server. While uploading shape file it gives following error message:
>>>> *An exception occurred loading data to PostGIS- java.io.IOException:
>>>> Error occurred creating table*
>>>> *geonode at geonode:~$ tail -f /var/log/apache2/error.log*
>>>> [Mon Dec 14 00:03:52.366469 2015] [:error] [pid 13271]
>>>> update_fields=update_fields)
>>>> [Mon Dec 14 00:03:52.366476 2015] [:error] [pid 13271]   File
>>>> "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
>>>> in send
>>>> [Mon Dec 14 00:03:52.366483 2015] [:error] [pid 13271]     response =
>>>> receiver(signal=self, sender=sender, **named)
>>>> [Mon Dec 14 00:03:52.366490 2015] [:error] [pid 13271]   File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
>>>> 74, in geoserver_pre_save
>>>> [Mon Dec 14 00:03:52.366497 2015] [:error] [pid 13271]
>>>> charset=instance.charset)
>>>> [Mon Dec 14 00:03:52.366504 2015] [:error] [pid 13271]   File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>> 1121, in geoserver_upload
>>>> [Mon Dec 14 00:03:52.366512 2015] [:error] [pid 13271]
>>>> workspace=workspace)
>>>> [Mon Dec 14 00:03:52.366519 2015] [:error] [pid 13271]   File
>>>> 998, in _create_db_featurestore
>>>> [Mon Dec 14 00:03:52.366526 2015] [:error] [pid 13271]     raise
>>>> GeoNodeException(msg)
>>>> [Mon Dec 14 00:03:52.366533 2015] [:error] [pid 13271]
>>>> GeoNodeException: An exception occurred loading data to PostGIS-
>>>> However, I can upload geotiff files and it works fine.
>>>> I am requesting your support in this regard to solve this shape file
>>>> uploading problem.
>>>> Best regards
>>>> Rajib
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151223/23291aa7/attachment.html>
More information about the geonode-users mailing list
