[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Jeffy John Tomarong jeffytoms at gmail.com
Wed Jul 1 00:23:39 PDT 2015
Hi Good Fellas!
Our GeoNode instance was running well in the previous months. But now, it
got Internal Server Error 500.
What I did was to update the IP of geonode (which is just the same anyway),
and it caused me this error:I also tried "pip install relationship" since
it displayed there "Error: No Module named relationships". But it caused
another set of error. GeoNode has been running well in the last months, I
do not know what happened.
I need your help guys on this. I'm at the end of my wits.
Will be very much appreciated. Thank you!
Here's the error message:
Replacing SITEURL in /etc/geonode/local_settings.py
Adding entry for local ip in /usr/share/geoserver/data//printing/config.yaml
  IP was already added to the printing whitelist.
Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
 * Restarting web server apache2
     apache2: Could not reliably determine the server's fully qualified
domain name, using 127.0.1.1 for ServerName
 ... waiting .apache2: Could not reliably determine the server's fully
qualified domain name, using 127.0.1.1 for ServerName
OK ]
/usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
DeprecationWarning: You have no filters defined on the 'mail_admins'
logging handler: adding implicit debug-false-only filter. See
http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
  DeprecationWarning)
  File "/usr/bin/django-admin", line 5, in <module>
    management.execute_from_command_line()
  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
453, in execute_from_command_line
    utility.execute()
  File
392, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
272, in fetch_command
    klass = load_command_class(app_name, subcommand)
  File
77, in load_command_class
    module = import_module('%s.management.commands.%s' % (app_name, name))
  File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line
35, in import_module
    __import__(name)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
line 23, in <module>
    from geonode.geoserver.helpers import gs_slurp
  File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
31, in <module>
    from geonode.utils import _user, _password, ogc_server_settings
  File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 36,
in <module>
    from geonode.security.enumerations import AUTHENTICATED_USERS,
ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
  File
"/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
line 28, in <module>
    ANONYMOUS_USERS: _('Anonymous Users'),
  File
"/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
line 71, in ugettext
    return _trans.ugettext(message)
  File
"/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
line 276, in ugettext
    return do_translate(message, 'ugettext')
  File
line 258, in do_translate
    _default = translation(settings.LANGUAGE_CODE)
  File
line 172, in translation
    default_translation = _fetch(settings.LANGUAGE_CODE)
  File
line 154, in _fetch
    app = import_module(appname)
    __import__(name)
ImportError: No module named relationships
jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pico
local_settings.py
settings.py
jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pip
install -e.
[sudo] password for jjqt:
--editable=. should be formatted with svn+URL, git+URL, hg+URL or bzr+URL
Storing complete log in /home/jjqt/.pip/pip.log
geonode-updateipcrisp.norminet.org.ph
OK ]
  DeprecationWarning)
  File
    utility.execute()
  File
392, in execute
  File
  File
    __import__(name)
  File
  File
31, in <module>
in <module>
  File
  File
  File
  File
  File
  File
line 154, in _fetch
    __import__(name)
jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip install
relationships
Downloading/unpacking relationships
Exception:
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 126, in
main
    self.run(options, args)
  File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line
223, in run
    requirement_set.prepare_files(finder, force_root_egg_info=self.bundle,
bundle=self.bundle)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
prepare_files
    location = req_to_install.build_location(self.build_dir, not
self.is_download)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
build_location
    _make_build_dir(build_dir)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
_make_build_dir
    os.makedirs(build_dir)
  File "/usr/lib/python2.7/os.py", line 157, in makedirs
    mkdir(name, mode)
OSError: [Errno 13] Permission denied:
'/usr/local/lib/python2.7/dist-packages/geonode/build'
  File "/usr/bin/pip", line 9, in <module>
    load_entry_point('pip==1.0', 'console_scripts', 'pip')()
  File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116, in main
    return command.main(initial_args, args[1:], options)
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 147, in
main
    log_fp = open_logfile(log_fn, 'w')
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 176, in
open_logfile
    log_fp = open(filename, mode)
IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/a8580593/attachment.html>
More information about the geonode-users mailing list
