[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 1 01:55:13 PDT 2015
Take a look at this thread if it helps
https://wiki.postgresql.org/wiki/May_2015_Fsync_Permissions_Bug
2015-07-01 10:52 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
> Hi Simone,
> I got this error when I restarted postgresql and it's quite persistent:
>  Restarting PostgreSQL 9.1 database server
>     * The PostgreSQL server failed to start. Please check the log output:
> 2015-07-01 16:49:11 PHT LOG:  database system was interrupted; last known
> up at 2015-05-27 23:25:59 PHT
> 2015-07-01 16:49:11 PHT FATAL:  could not open file
> "/etc/ssl/certs/ssl-cert-snakeoil.pem": Permission denied
> 2015-07-01 16:49:11 PHT LOG:  startup process (PID 5730) exited with exit
> code 1
> 2015-07-01 16:49:11 PHT LOG:  aborting startup due to startup process
> failure
>  [fail]
> On Wed, Jul 1, 2015 at 4:11 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> There's no way to restore, but you can add back your db configuration.
>> Check whether the local_settings.py file contains the correct db connection
>> parameters and that postgres is up and running.
>> 2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>> Nope we dont have a custom configuration. After I installed geonode, all
>>> I editted were on the ipaddress part or the site url. I did not touch the
>>> DB config in the local_settings.py ..
>>> Or is there a way to restore back the local_settings.py, say restore it
>>> back to two days ago? Because I'm afraid I might have overwritten the
>>> local_settings.py with the old backup file of local_settings.py the moment
>>> it got the internal server error..
>>> Thank you Simone!
>>> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> That is because it can't connect to postgresql. Do you have some kind
>>>> of custom configuration?
>>>> That command uses /etc/geonode/local_settings.py to get the db
>>>> configuration
>>>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>> Hi Simone,
>>>>> It did help! Thank you very much for your quick response.. I also did
>>>>> pip install django-request after that.
>>>>> However, when I issued updateip again, I got this:
>>>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>>>> logging handler: adding implicit debug-false-only filter. See
>>>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>>>   DeprecationWarning)
>>>>> OperationalError: could not connect to server: Connection refused
>>>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>>>> TCP/IP connections on port 5432?
>>>>> Hmm.. ??
>>>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>>>>> Hi, I see you are using geonode 2.0
>>>>>> the missing package should be django-relationships and since your
>>>>>> geonode is installed systemwide you have to use sudo so:
>>>>>> $ sudo pip install  django-relationships
>>>>>> Hope this helps
>>>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>>>> Hi Good Fellas!
>>>>>>> Our GeoNode instance was running well in the previous months. But
>>>>>>> now, it got Internal Server Error 500.
>>>>>>> What I did was to update the IP of geonode (which is just the same
>>>>>>> anyway), and it caused me this error:I also tried "pip install
>>>>>>> relationship" since it displayed there "Error: No Module named
>>>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>>>> running well in the last months, I do not know what happened.
>>>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>>>> Will be very much appreciated. Thank you!
>>>>>>> Here's the error message:
>>>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>>>> Adding entry for local ip in
>>>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>>>   IP was already added to the printing whitelist.
>>>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>>>  * Restarting web server apache2
>>>>>>>            apache2: Could not reliably determine the server's fully
>>>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>  ... waiting .apache2: Could not reliably determine the server's
>>>>>>> fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>      [ OK ]
>>>>>>>   DeprecationWarning)
>>>>>>> Traceback (most recent call last):
>>>>>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>>>>>     management.execute_from_command_line()
>>>>>>>   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>>> 453, in execute_from_command_line
>>>>>>>     utility.execute()
>>>>>>>   File
>>>>>>> 392, in execute
>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>   File
>>>>>>> 272, in fetch_command
>>>>>>>     klass = load_command_class(app_name, subcommand)
>>>>>>>   File
>>>>>>> 77, in load_command_class
>>>>>>>     module = import_module('%s.management.commands.%s' % (app_name,
>>>>>>> name))
>>>>>>>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>>>>>> line 35, in import_module
>>>>>>>     __import__(name)
>>>>>>>   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>>>> line 23, in <module>
>>>>>>>     from geonode.geoserver.helpers import gs_slurp
>>>>>>>   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>>> 31, in <module>
>>>>>>>     from geonode.utils import _user, _password, ogc_server_settings
>>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py",
>>>>>>> line 36, in <module>
>>>>>>>     from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>>   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>>>> line 28, in <module>
>>>>>>>     ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>>>   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>>>> line 71, in ugettext
>>>>>>>     return _trans.ugettext(message)
>>>>>>>   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>>>> line 276, in ugettext
>>>>>>>     return do_translate(message, 'ugettext')
>>>>>>>   File
>>>>>>> line 258, in do_translate
>>>>>>>     _default = translation(settings.LANGUAGE_CODE)
>>>>>>>   File
>>>>>>> line 172, in translation
>>>>>>>     default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>>>   File
>>>>>>> line 154, in _fetch
>>>>>>>     app = import_module(appname)
>>>>>>>     __import__(name)
>>>>>>> ImportError: No module named relationships
>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>>>> pico local_settings.py
>>>>>>> pico settings.py
>>>>>>> pip install -e.
>>>>>>> [sudo] password for jjqt:
>>>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>>>> bzr+URL
>>>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>>>> geonode-updateipcrisp.norminet.org.ph
>>>>>>>      [ OK ]
>>>>>>>   DeprecationWarning)
>>>>>>>   File
>>>>>>>     utility.execute()
>>>>>>>   File
>>>>>>> 392, in execute
>>>>>>>   File
>>>>>>>   File
>>>>>>> name))
>>>>>>>     __import__(name)
>>>>>>>   File
>>>>>>>   File
>>>>>>> 31, in <module>
>>>>>>>   File
>>>>>>>   File
>>>>>>>   File
>>>>>>>   File
>>>>>>>   File
>>>>>>>   File
>>>>>>> line 154, in _fetch
>>>>>>>     __import__(name)
>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>>>> install relationships
>>>>>>> Downloading/unpacking relationships
>>>>>>> Exception:
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>>>> 126, in main
>>>>>>>     self.run(options, args)
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>>>> line 223, in run
>>>>>>>     requirement_set.prepare_files(finder,
>>>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>>>> prepare_files
>>>>>>>     location = req_to_install.build_location(self.build_dir, not
>>>>>>> self.is_download)
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>>>> build_location
>>>>>>>     _make_build_dir(build_dir)
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>>>> _make_build_dir
>>>>>>>     os.makedirs(build_dir)
>>>>>>>   File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>>>     mkdir(name, mode)
>>>>>>> OSError: [Errno 13] Permission denied:
>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>>>   File "/usr/bin/pip", line 9, in <module>
>>>>>>>     load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116,
>>>>>>> in main
>>>>>>>     return command.main(initial_args, args[1:], options)
>>>>>>> 147, in main
>>>>>>>     log_fp = open_logfile(log_fn, 'w')
>>>>>>> 176, in open_logfile
>>>>>>>     log_fp = open(filename, mode)
>>>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/2f29e307/attachment-0001.html>
More information about the geonode-users mailing list
