[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jul 2 00:50:56 PDT 2015
Cool, for the thumbnails check the web request and see whether they are not
found or there's some geoserver misconfiguration
2015-07-02 7:39 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
> Thank you very much Simone! Your fixes were really effective..
> The site can now be accessed, though the layer thumbnails are no longer
> showing up.
> Nevertheless, what's important is that the site is now up and running.
> Thank you for your unswerving support! :) *thumbs up
> On Wed, Jul 1, 2015 at 7:37 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Very strange,
>> it's like you are missing some settings. You have to track down the
>> errors until it's fixed, for now add
>> CACHE_TIME = 0
>> to your settings
>> 2015-07-01 13:34 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>> Yeah I'm sure. I also didn't even update Ubuntu..
>>> I was so excited to apply your fix. Unfortunately, it got this error
>>> again :(
>>> AttributeError at /
>>> 'Settings' object has no attribute 'CACHE_TIME'
>>> Request Method:GETRequest URL:http://crisp.norminet.org.ph/Django
>>> Version:1.5.1Exception Type:AttributeErrorException Value:
>>> Exception Location:/usr/local/lib/python2.7/dist-packages/geonode/search/views.py
>>> in search_api, line 154Python Executable:/usr/bin/pythonPython Version:
>>> 2.7.3Python Path:
>>> ['/usr/lib/python2.7',
>>>  '/usr/lib/python2.7/plat-linux2',
>>>  '/usr/lib/python2.7/lib-tk',
>>>  '/usr/lib/python2.7/lib-old',
>>>  '/usr/lib/python2.7/lib-dynload',
>>>  '/usr/local/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages/PIL',
>>>  '/usr/lib/python2.7/dist-packages/gtk-2.0',
>>>  '/usr/lib/pymodules/python2.7',
>>>  '/usr/lib/python2.7/dist-packages/ubuntu-sso-client']
>>> Server time:Wed, 1 Jul 2015 19:31:12 +0800
>>> Traceback Switch to copy-and-paste view <http://crisp.norminet.org.ph/#>
>>>    - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>>>    get_response
>>>    1.
>>>                               response = callback(request, *callback_args, **callback_kwargs)
>>>    ▶ Local vars <http://crisp.norminet.org.ph/#>
>>>    - /usr/local/lib/python2.7/dist-packages/geonode/views.py in index
>>>    1.
>>>           return search_page(request, template=template)
>>>    - /usr/local/lib/python2.7/dist-packages/geonode/search/views.py in
>>>    search_page
>>>    1.
>>>           results, facets, query = search_api(request, format='html', **kw)
>>>    search_api
>>>    1.
>>>                   raise ex
>>> Request informationGET
>>> No GET data
>>> POSTVariableValuetype
>>> 'layer'
>>> FILES
>>> No FILES data
>>> COOKIESVariableValuecsrftoken
>>> 'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>>> METAVariableValuemod_wsgi.listener_port
>>> '80'
>>> HTTP_COOKIE
>>> 'csrftoken=abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>>> mod_wsgi.listener_host
>>> SERVER_SOFTWARE
>>> 'Apache/2.2.22 (Ubuntu)'
>>> SCRIPT_NAME
>>> u''
>>> mod_wsgi.handler_script
>>> SERVER_SIGNATURE
>>> '<address>Apache/2.2.22 (Ubuntu) Server at crisp.norminet.org.ph Port 80</address>\n'
>>> REQUEST_METHOD
>>> 'GET'
>>> PATH_INFO
>>> u'/'
>>> SERVER_PROTOCOL
>>> 'HTTP/1.1'
>>> QUERY_STRING
>>> HTTP_USER_AGENT
>>> 'Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36'
>>> HTTP_CONNECTION
>>> 'keep-alive'
>>> SERVER_NAME
>>> 'crisp.norminet.org.ph'
>>> REMOTE_ADDR
>>> '121.97.223.10'
>>> mod_wsgi.request_handler
>>> 'wsgi-script'
>>> wsgi.url_scheme
>>> 'http'
>>> PATH_TRANSLATED
>>> '/var/www/geonode/wsgi/geonode.wsgi/'
>>> SERVER_PORT
>>> '80'
>>> wsgi.multiprocess
>>> True
>>> mod_wsgi.input_chunked
>>> '0'
>>> SERVER_ADDR
>>> '121.97.223.10'
>>> DOCUMENT_ROOT
>>> '/etc/apache2/htdocs'
>>> mod_wsgi.process_group
>>> 'geonode'
>>> SCRIPT_FILENAME
>>> '/var/www/geonode/wsgi/geonode.wsgi'
>>> SERVER_ADMIN
>>> 'webmaster at localhost'
>>> wsgi.input
>>> <mod_wsgi.Input object at 0x7f03645ab1b0>
>>> HTTP_HOST
>>> wsgi.multithread
>>> True
>>> mod_wsgi.callable_object
>>> 'application'
>>> HTTP_CACHE_CONTROL
>>> 'max-age=0'
>>> REQUEST_URI
>>> HTTP_ACCEPT
>>> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
>>> wsgi.version
>>> (1, 1)
>>> GATEWAY_INTERFACE
>>> 'CGI/1.1'
>>> wsgi.run_once
>>> False
>>> wsgi.errors
>>> <mod_wsgi.Log object at 0x7f0364773c30>
>>> REMOTE_PORT
>>> '40442'
>>> HTTP_ACCEPT_LANGUAGE
>>> 'en-US,en;q=0.8'
>>> mod_wsgi.version
>>> (3, 3)
>>> mod_wsgi.application_group
>>> 'localhost|'
>>> mod_wsgi.script_reloading
>>> '1'
>>> wsgi.file_wrapper
>>> CSRF_COOKIE
>>> u'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>>> HTTP_ACCEPT_ENCODING
>>> 'gzip,deflate,sdch'
>>> SettingsUsing settings module geonode.settingsSettingValue
>>> ACCOUNT_USER_DISPLAY
>>> STATIC_ROOT
>>> '/var/www/geonode/static/'
>>> GOOGLE_API_KEY
>>> u'********************'
>>> USE_THOUSAND_SEPARATOR
>>> False
>>> CSRF_COOKIE_SECURE
>>> False
>>> LANGUAGE_CODE
>>> 'en'
>>> ROOT_URLCONF
>>> 'geonode.urls'
>>> MANAGERS
>>> DB_DATASTORE_NAME
>>> DEFAULT_CHARSET
>>> 'utf-8'
>>> PYCSW
>>> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>>>                                         'contact_email': 'Email Address',
>>>                                         'contact_name': 'Organization Name',
>>>                                         'date': 'YYYY-MM-DD',
>>>                                         'default_language': 'eng',
>>>                                         'enabled': 'true',
>>>                                         'gemet_keywords': 'Utility and governmental services',
>>>                                         'languages_supported': 'eng,gre',
>>>                                         'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>>>                    'metadata:main': {'contact_address': 'Mailing Address',
>>>                                      'contact_city': 'City',
>>>                                      'contact_country': 'Country',
>>>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>>>                                      'contact_hours': 'Hours of Service',
>>>                                      'contact_instructions': 'During hours of service. Off on weekends.',
>>>                                      'contact_name': 'Lastname, Firstname',
>>>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>>>                                      'contact_position': 'Position Title',
>>>                                      'contact_postalcode': 'Zip or Postal Code',
>>>                                      'contact_role': 'pointOfContact',
>>>                                      'contact_stateorprovince': 'Administrative Area',
>>>                                      'contact_url': 'Contact URL',
>>>                                      'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, and collaborative use of geospatial data',
>>>                                      'identification_accessconstraints': 'None',
>>>                                      'identification_fees': 'None',
>>>                                      'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>>>                                      'identification_keywords_type': 'theme',
>>>                                      'identification_title': 'GeoNode Catalogue',
>>>                                      'provider_name': 'Organization Name',
>>>                                      'provider_url': 'http://crisp.norminet.org.ph:8000/'}}}
>>> DEFAULT_MAP_CENTER
>>> (0, 0)
>>> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
>>> 3
>>> DB_DATASTORE
>>> False
>>> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
>>> None
>>> GEOSERVER_BASE_URL
>>> 'http://crisp.norminet.org.ph:8080/geoserver/'
>>> REGISTRATION_OPEN
>>> False
>>> ALLOWED_HOSTS
>>> ['crisp.norminet.org.ph', 'localhost']
>>> OGC_SERVER
>>> {'default': {'BACKEND': 'geonode.geoserver',
>>>              'BACKEND_WRITE_ENABLED': True,
>>>              'DATASTORE': 'datastore',
>>>              'GEOGIT_DATASTORE_DIR': '',
>>>              'GEOGIT_ENABLED': False,
>>>              'GEONODE_SECURITY_ENABLED': True,
>>>              'LOCATION': 'http://crisp.norminet.org.ph:8080/geoserver/',
>>>              'MAPFISH_PRINT_ENABLED': True,
>>>              'PASSWORD': u'********************',
>>>              'PRINTING_ENABLED': True,
>>>              'PRINTNG_ENABLED': True,
>>>              'PUBLIC_LOCATION': 'http://crisp.norminet.org.ph/geoserver/',
>>>              'USER': 'admin',
>>>              'WMST_ENABLED': False,
>>>              'WPS_ENABLED': False}}
>>> MESSAGE_STORAGE
>>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>>> DATABASE_HOST
>>> 'localhost'
>>> EMAIL_SUBJECT_PREFIX
>>> '[Django] '
>>> SEND_BROKEN_LINK_EMAILS
>>> False
>>> STATICFILES_FINDERS
>>> ('django.contrib.staticfiles.finders.FileSystemFinder',
>>>  'django.contrib.staticfiles.finders.AppDirectoriesFinder')
>>> SESSION_CACHE_ALIAS
>>> 'default'
>>> SESSION_COOKIE_DOMAIN
>>> None
>>> SESSION_COOKIE_NAME
>>> 'sessionid'
>>> DB_DATASTORE_USER
>>> CSRF_COOKIE_NAME
>>> 'csrftoken'
>>> ADMIN_FOR
>>> TIME_INPUT_FORMATS
>>> ('%H:%M:%S', '%H:%M')
>>> DATABASES
>>> {'datastore': {'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>>                'HOST': 'localhost',
>>>                'NAME': 'geonode',
>>>                'OPTIONS': {},
>>>                'PORT': '5432',
>>>                'TEST_CHARSET': None,
>>>                'TEST_COLLATION': None,
>>>                'TEST_MIRROR': None,
>>>                'TEST_NAME': None,
>>>                'TIME_ZONE': 'Asia/Manila',
>>>                'USER': 'geonode'},
>>>  'default': {'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>>              'NAME': 'geonode',
>>>              'OPTIONS': {},
>>>              'PORT': '5432',
>>>              'TEST_NAME': None,
>>>              'USER': 'geonode'}}
>>> FILE_UPLOAD_PERMISSIONS
>>> None
>>> ACCOUNT_TIMEZONES
>>> [('Africa/Abidjan', 'Africa/Abidjan'),
>>>  ('Africa/Accra', 'Africa/Accra'),
>>>  ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>>>  ('Africa/Algiers', 'Africa/Algiers'),
>>>  ('Africa/Asmara', 'Africa/Asmara'),
>>>  ('Africa/Asmera', 'Africa/Asmera'),
>>>  ('Africa/Bamako', 'Africa/Bamako'),
>>>  ('Africa/Bangui', 'Africa/Bangui'),
>>>  ('Africa/Banjul', 'Africa/Banjul'),
>>>  ('Africa/Bissau', 'Africa/Bissau'),
>>>  ('Africa/Blantyre', 'Africa/Blantyre'),
>>>  ('Africa/Brazzaville', 'Africa/Brazzaville'),
>>>  ('Africa/Bujumbura', 'Africa/Bujumbura'),
>>>  ('Africa/Cairo', 'Africa/Cairo'),
>>>  ('Africa/Casablanca', 'Africa/Casablanca'),
>>>  ('Africa/Ceuta', 'Africa/Ceuta'),
>>>  ('Africa/Conakry', 'Africa/Conakry'),
>>>  ('Africa/Dakar', 'Africa/Dakar'),
>>>  ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>>>  ('Africa/Djibouti', 'Africa/Djibouti'),
>>>  ('Africa/Douala', 'Africa/Douala'),
>>>  ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>>>  ('Africa/Freetown', 'Africa/Freetown'),
>>>  ('Africa/Gaborone', 'Africa/Gaborone'),
>>>  ('Africa/Harare', 'Africa/Harare'),
>>>  ('Africa/Johannesburg', 'Africa/Johannesburg'),
>>>  ('Africa/Kampala', 'Africa/Kampala'),
>>>  ('Africa/Khartoum', 'Africa/Khartoum'),
>>>  ('Africa/Kigali', 'Africa/Kigali'),
>>>  ('Africa/Kinshasa', 'Africa/Kinshasa'),
>>>  ('Africa/Lagos', 'Africa/Lagos'),
>>>  ('Africa/Libreville', 'Africa/Libreville'),
>>>  ('Africa/Lome', 'Africa/Lome'),
>>>  ('Africa/Luanda', 'Africa/Luanda'),
>>>  ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>>>  ('Africa/Lusaka', 'Africa/Lusaka'),
>>>  ('Africa/Malabo', 'Africa/Malabo'),
>>>  ('Africa/Maputo', 'Africa/Maputo'),
>>>  ('Africa/Maseru', 'Africa/Maseru'),
>>>  ('Africa/Mbabane', 'Africa/Mbabane'),
>>>  ('Africa/Mogadishu', 'Africa/Mogadishu'),
>>>  ('Africa/Monrovia', 'Africa/Monrovia'),
>>>  ('Africa/Nairobi', 'Africa/Nairobi'),
>>>  ('Africa/Ndjamena', 'Africa/Ndjamena'),
>>>  ('Africa/Niamey', 'Africa/Niamey'),
>>>  ('Africa/Nouakchott', 'Africa/Nouakchott'),
>>>  ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>>>  ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>>>  ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>>>  ('Africa/Timbuktu', 'Africa/Timbuktu'),
>>>  ('Africa/Tripoli', 'Africa/Tripoli'),
>>>  ('Africa/Tunis', 'Africa/Tunis'),
>>>  ('Africa/Windhoek', 'Africa/Windhoek'),
>>>  ('America/Adak', 'America/Adak'),
>>>  ('America/Anchorage', 'America/Anchorage'),
>>>  ('America/Anguilla', 'America/Anguilla'),
>>>  ('America/Antigua', 'America/Antigua'),
>>>  ('America/Araguaina', 'America/Araguaina'),
>>>  ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>>>  ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>>>  ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>>>  ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>>>  ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>>>  ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>>>  ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>>>  ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>>>  ('America/Argentina/Salta', 'America/Argentina/Salta'),
>>>  ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>>>  ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>>>  ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>>>  ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>>>  ('America/Aruba', 'America/Aruba'),
>>>  ('America/Asuncion', 'America/Asuncion'),
>>>  ('America/Atikokan', 'America/Atikokan'),
>>>  ('America/Atka', 'America/Atka'),
>>>  ('America/Bahia', 'America/Bahia'),
>>>  ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>>>  ('America/Barbados', 'America/Barbados'),
>>>  ('America/Belem', 'America/Belem'),
>>>  ('America/Belize', 'America/Belize'),
>>>  ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>>>  ('America/Boa_Vista', 'America/Boa_Vista'),
>>>  ('America/Bogota', 'America/Bogota'),
>>>  ('America/Boise', 'America/Boise'),
>>>  ('America/Buenos_Aires', 'America/Buenos_Aires'),
>>>  ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>>>  ('America/Campo_Grande', 'America/Campo_Grande'),
>>>  ('America/Cancun', 'America/Cancun'),
>>>  ('America/Caracas', 'America/Caracas'),
>>>  ('America/Catamarca', 'America/Catamarca'),
>>>  ('America/Cayenne', 'America/Cayenne'),
>>>  ('America/Cayman', 'America/Cayman'),
>>>  ('America/Chicago', 'America/Chicago'),
>>>  ('America/Chihuahua', 'America/Chihuahua'),
>>>  ('America/Coral_Harbour', 'America/Coral_Harbour'),
>>>  ('America/Cordoba', 'America/Cordoba'),
>>>  ('America/Costa_Rica', 'America/Costa_Rica'),
>>>  ('America/Cuiaba', 'America/Cuiaba'),
>>>  ('America/Curacao', 'America/Curacao'),
>>>  ('America/Danmarkshavn', 'America/Danmarkshavn'),
>>>  ('America/Dawson', 'America/Dawson'),
>>>  ('America/Dawson_Creek', 'America/Dawson_Creek'),
>>>  ('America/Denver', 'America/Denver'),
>>>  ('America/Detroit', 'America/Detroit'),
>>>  ('America/Dominica', 'America/Dominica'),
>>>  ('America/Edmonton', 'America/Edmonton'),
>>>  ('America/Eirunepe', 'America/Eirunepe'),
>>>  ('America/El_Salvador', 'America/El_Salvador'),
>>>  ('America/Ensenada', 'America/Ensenada'),
>>>  ('America/Fort_Wayne', 'America/Fort_Wayne'),
>>>  ('America/Fortaleza', 'America/Fortaleza'),
>>>  ('America/Glace_Bay', 'America/Glace_Bay'),
>>>  ('America/Godthab', 'America/Godthab'),
>>>  ('America/Goose_Bay', 'America/Goose_Bay'),
>>>  ('America/Grand_Turk', 'America/Grand_Turk'),
>>>  ('America/Grenada', 'America/Grenada'),
>>>  ('America/Guadeloupe', 'America/Guadeloupe'),
>>>  ('America/Guatemala', 'America/Guatemala'),
>>>  ('America/Guayaquil', 'America/Guayaquil'),
>>>  ('America/Guyana', 'America/Guyana'),
>>>  ('America/Halifax', 'America/Halifax'),
>>>  ('America/Havana', 'America/Havana'),
>>>  ('America/Hermosillo', 'America/Hermosillo'),
>>>  ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>>>  ('America/Indiana/Knox', 'America/Indiana/Knox'),
>>>  ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>>>  ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>>>  ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>>>  ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>>>  ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>>>  ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>>>  ('America/Indianapolis', 'America/Indianapolis'),
>>>  ('America/Inuvik', 'America/Inuvik'),
>>>  ('America/Iqaluit', 'America/Iqaluit'),
>>>  ('America/Jamaica', 'America/Jamaica'),
>>>  ('America/Jujuy', 'America/Jujuy'),
>>>  ('America/Juneau', 'America/Juneau'),
>>>  ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>>>  ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>>>  ('America/Knox_IN', 'America/Knox_IN'),
>>>  ('America/Kralendijk', 'America/Kralendijk'),
>>>  ('America/La_Paz', 'America/La_Paz'),
>>>  ('America/Lima', 'America/Lima'),
>>>  ('America/Los_Angeles', 'America/Los_Angeles'),
>>>  ('America/Louisville', 'America/Louisville'),
>>>  ('America/Lower_Princes', 'America/Lower_Princes'),
>>>  ('America/Maceio', 'America/Maceio'),
>>>  ('America/Managua', 'America/Managua'),
>>>  ('America/Manaus', 'America/Manaus'),
>>>  ('America/Marigot', 'America/Marigot'),
>>>  ('America/Martinique', 'America/Martinique'),
>>>  ('America/Matamoros', 'America/Matamoros'),
>>>  ('America/Mazatlan', 'America/Mazatlan'),
>>>  ('America/Mendoza', 'America/Mendoza'),
>>>  ('America/Menominee', 'America/Menominee'),
>>>  ('America/Merida', 'America/Merida'),
>>>  ('America/Metlakatla', 'America/Metlakatla'),
>>>  ('America/Mexico_City', 'America/Mexico_City'),
>>>  ('America/Miquelon', 'America/Miquelon'),
>>>  ('America/Moncton', 'America/Moncton'),
>>>  ('America/Monterrey', 'America/Monterrey'),
>>>  ('America/Montevideo', 'America/Montevideo'),
>>>  ('America/Montreal', 'America/Montreal'),
>>>  ('America/Montserrat', 'America/Montserrat'),
>>>  ('America/Nassau', 'America/Nassau'),
>>>  ('America/New_York', 'America/New_York'),
>>>  ('America/Nipigon', 'America/Nipigon'),
>>>  ('America/Nome', 'America/Nome'),
>>>  ('America/Noronha', 'America/Noronha'),
>>>  ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>>>  ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>>>  ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>>>  ('America/Ojinaga', 'America/Ojinaga'),
>>>  ('America/Panama', 'America/Panama'),
>>>  ('America/Pangnirtung', 'America/Pangnirtung'),
>>>  ('America/Paramaribo', 'America/Paramaribo'),
>>>  ('America/Phoenix', 'America/Phoenix'),
>>>  ('America/Port-au-Prince', 'America/Port-au-Prince'),
>>>  ('America/Port_of_Spain', 'America/Port_of_Spain'),
>>>  ('America/Porto_Acre', 'America/Porto_Acre'),
>>>  ('America/Porto_Velho', 'America/Porto_Velho'),
>>>  ('America/Puerto_Rico', 'America/Puerto_Rico'),
>>>  ('America/Rainy_River', 'America/Rainy_River'),
>>>  ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>>>  ('America/Recife', 'America/Recife'),
>>>  ('America/Regina', 'America/Regina'),
>>>  ('America/Resolute', 'America/Resolute'),
>>>  ('America/Rio_Branco', 'America/Rio_Branco'),
>>>  ('America/Rosario', 'America/Rosario'),
>>>  ('America/Santa_Isabel', 'America/Santa_Isabel'),
>>>  ('America/Santarem', 'America/Santarem'),
>>>  ('America/Santiago', 'America/Santiago'),
>>>  ('America/Santo_Domingo', 'America/Santo_Domingo'),
>>>  ('America/Sao_Paulo', 'America/Sao_Paulo'),
>>>  ('America/Scoresbysund', 'America/Scoresbysund'),
>>>  ('America/Shiprock', 'America/Shiprock'),
>>>  ('America/Sitka', 'America/Sitka'),
>>>  ('America/St_Barthelemy', 'America/St_Barthelemy'),
>>>  ('America/St_Johns', 'America/St_Johns'),
>>>  ('America/St_Kitts', 'America/St_Kitts'),
>>>  ('America/St_Lucia', 'America/St_Lucia'),
>>>  ('America/St_Thomas', 'America/St_Thomas'),
>>>  ('America/St_Vincent', 'America/St_Vincent'),
>>>  ('America/Swift_Current', 'America/Swift_Current'),
>>>  ('America/Tegucigalpa', 'America/Tegucigalpa'),
>>>  ('America/Thule', 'America/Thule'),
>>>  ('America/Thunder_Bay', 'America/Thunder_Bay'),
>>>  ('America/Tijuana', 'America/Tijuana'),
>>>  ('America/Toronto', 'America/Toronto'),
>>>  ('America/Tortola', 'America/Tortola'),
>>>  ('America/Vancouver', 'America/Vancouver'),
>>>  ('America/Virgin', 'America/Virgin'),
>>>  ('America/Whitehorse', 'America/Whitehorse'),
>>>  ('America/Winnipeg', 'America/Winnipeg'),
>>>  ('America/Yakutat', 'America/Yakutat'),
>>>  ('America/Yellowknife', 'America/Yellowknife'),
>>>  ('Antarctica/Casey', 'Antarctica/Casey'),
>>>  ('Antarctica/Davis', 'Antarctica/Davis'),
>>>  ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>>>  ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>>>  ('Antarctica/Mawson', 'Antarctica/Mawson'),
>>>  ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>>>  ('Antarctica/Palmer', 'Antarctica/Palmer'),
>>>  ('Antarctica/Rothera', 'Antarctica/Rothera'),
>>>  ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>>>  ('Antarctica/Syowa', 'Antarctica/Syowa'),
>>>  ('Antarctica/Vostok', 'Antarctica/Vostok'),
>>>  ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>>>  ('Asia/Aden', 'Asia/Aden'),
>>>  ('Asia/Almaty', 'Asia/Almaty'),
>>>  ('Asia/Amman', 'Asia/Amman'),
>>>  ('Asia/Anadyr', 'Asia/Anadyr'),
>>>  ('Asia/Aqtau', 'Asia/Aqtau'),
>>>  ('Asia/Aqtobe', 'Asia/Aqtobe'),
>>>  ('Asia/Ashgabat', 'Asia/Ashgabat'),
>>>  ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>>>  ('Asia/Baghdad', 'Asia/Baghdad'),
>>>  ('Asia/Bahrain', 'Asia/Bahrain'),
>>>  ('Asia/Baku', 'Asia/Baku'),
>>>  ('Asia/Bangkok', 'Asia/Bangkok'),
>>>  ('Asia/Beirut', 'Asia/Beirut'),
>>>  ('Asia/Bishkek', 'Asia/Bishkek'),
>>>  ('Asia/Brunei', 'Asia/Brunei'),
>>>  ('Asia/Calcutta', 'Asia/Calcutta'),
>>>  ('Asia/Choibalsan', 'Asia/Choibalsan'),
>>>  ('Asia/Chongqing', 'Asia/Chongqing'),
>>>  ('Asia/Chungking', 'Asia/Chungking'),
>>>  ('Asia/Colombo', 'Asia/Colombo'),
>>>  ('Asia/Dacca', 'Asia/Dacca'),
>>>  ('Asia/Damascus', 'Asia/Damascus'),
>>>  ('Asia/Dhaka', 'Asia/Dhaka'),
>>>  ('Asia/Dili', 'Asia/Dili'),
>>>  ('Asia/Dubai', 'Asia/Dubai'),
>>>  ('Asia/Dushanbe', 'Asia/Dushanbe'),
>>>  ('Asia/Gaza', 'Asia/Gaza'),
>>>  ('Asia/Harbin', 'Asia/Harbin'),
>>>  ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>>>  ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>>>  ('Asia/Hovd', 'Asia/Hovd'),
>>>  ('Asia/Irkutsk', 'Asia/Irkutsk'),
>>>  ('Asia/Istanbul', 'Asia/Istanbul'),
>>>  ('Asia/Jakarta', 'Asia/Jakarta'),
>>>  ('Asia/Jayapura', 'Asia/Jayapura'),
>>>  ('Asia/Jerusalem', 'Asia/Jerusalem'),
>>>  ('Asia/Kabul', 'Asia/Kabul'),
>>>  ('Asia/Kamchatka', 'Asia/Kamchatka'),
>>>  ('Asia/Karachi', 'Asia/Karachi'),
>>>  ('Asia/Kashgar', 'Asia/Kashgar'),
>>>  ('Asia/Kathmandu', 'Asia/Kathmandu'),
>>>  ('Asia/Katmandu', 'Asia/Katmandu'),
>>>  ('Asia/Kolkata', 'Asia/Kolkata'),
>>>  ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>>>  ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>>>  ('Asia/Kuching', 'Asia/Kuching'),
>>>  ('Asia/Kuwait', 'Asia/Kuwait'),
>>>  ('Asia/Macao', 'Asia/Macao'),
>>>  ('Asia/Macau', 'Asia/Macau'),
>>>  ('Asia/Magadan', 'Asia/Magadan'),
>>>  ('Asia/Makassar', 'Asia/Makassar'),
>>>  ('Asia/Manila', 'Asia/Manila'),
>>>  ('Asia/Muscat', 'Asia/Muscat'),
>>>  ('Asia/Nicosia', 'Asia/Nicosia'),
>>>  ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>>>  ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>>>  ('Asia/Omsk', 'Asia/Omsk'),
>>>  ('Asia/Oral', 'Asia/Oral'),
>>>  ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>>>  ('Asia/Pontianak', 'Asia/Pontianak'),
>>>  ('Asia/Pyongyang', 'Asia/Pyongyang'),
>>>  ('Asia/Qatar', 'Asia/Qatar'),
>>>  ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>>>  ('Asia/Rangoon', 'Asia/Rangoon'),
>>>  ('Asia/Riyadh', 'Asia/Riyadh'),
>>>  ('Asia/Saigon', 'Asia/Saigon'),
>>>  ('Asia/Sakhalin', 'Asia/Sakhalin'),
>>>  ('Asia/Samarkand', 'Asia/Samarkand'),
>>>  ('Asia/Seoul', 'Asia/Seoul'),
>>>  ('Asia/Shanghai', 'Asia/Shanghai'),
>>>  ('Asia/Singapore', 'Asia/Singapore'),
>>>  ('Asia/Taipei', 'Asia/Taipei'),
>>>  ('Asia/Tashkent', 'Asia/Tashkent'),
>>>  ('Asia/Tbilisi', 'Asia/Tbilisi'),
>>>  ('Asia/Tehran', 'Asia/Tehran'),
>>>  ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>>>  ('Asia/Thimbu', 'Asia/Thimbu'),
>>>  ('Asia/Thimphu', 'Asia/Thimphu'),
>>>  ('Asia/Tokyo', 'Asia/Tokyo'),
>>>  ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>>>  ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>>>  ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>>>  ('Asia/Urumqi', 'Asia/Urumqi'),
>>>  ('Asia/Vientiane', 'Asia/Vientiane'),
>>>  ('Asia/Vladivostok', 'Asia/Vladivostok'),
>>>  ('Asia/Yakutsk', 'Asia/Yakutsk'),
>>>  ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>>>  ('Asia/Yerevan', 'Asia/Yerevan'),
>>>  ('Atlantic/Azores', 'Atlantic/Azores'),
>>>  ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>>>  ('Atlantic/Canary', 'Atlantic/Canary'),
>>>  ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>>>  ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>>>  ('Atlantic/Faroe', 'Atlantic/Faroe'),
>>>  ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>>>  ('Atlantic/Madeira', 'Atlantic/Madeira'),
>>>  ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>>>  ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>>>  ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>>>  ('Atlantic/Stanley', 'Atlantic/Stanley'),
>>>  ('Australia/ACT', 'Australia/ACT'),
>>>  ('Australia/Adelaide', 'Australia/Adelaide'),
>>>  ('Australia/Brisbane', 'Australia/Brisbane'),
>>>  ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>>>  ('Australia/Canberra', 'Australia/Canberra'),
>>>  ('Australia/Currie', 'Australia/Currie'),
>>>  ('Australia/Darwin', 'Australia/Darwin'),
>>>  ('Australia/Eucla', 'Australia/Eucla'),
>>>  ('Australia/Hobart', 'Australia/Hobart'),
>>>  ('Australia/LHI', 'Australia/LHI'),
>>>  ('Australia/Lindeman', 'Australia/Lindeman'),
>>>  ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>>>  ('Australia/Melbourne', 'Australia/Melbourne'),
>>>  ('Australia/NSW', 'Australia/NSW'),
>>>  ('Australia/North', 'Australia/North'),
>>>  ('Australia/Perth', 'Australia/Perth'),
>>>  ('Australia/Queensland', 'Australia/Queensland'),
>>>  ('Australia/South', 'Australia/South'),
>>>  ('Australia/Sydney', 'Australia/Sydney'),
>>>  ('Australia/Tasmania', 'Australia/Tasmania'),
>>>  ('Australia/Victoria', 'Australia/Victoria'),
>>>  ('Australia/West', 'Australia/West'),
>>>  ('Australia/Yancowinna', 'Australia/Yancowinna'),
>>>  ('Brazil/Acre', 'Brazil/Acre'),
>>>  ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>>>  ('Brazil/East', 'Brazil/East'),
>>>  ('Brazil/West', 'Brazil/West'),
>>>  ('CET', 'CET'),
>>>  ('CST6CDT', 'CST6CDT'),
>>>  ('Canada/Atlantic', 'Canada/Atlantic'),
>>>  ('Canada/Central', 'Canada/Central'),
>>>  ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>>>  ('Canada/Eastern', 'Canada/Eastern'),
>>>  ('Canada/Mountain', 'Canada/Mountain'),
>>>  ('Canada/Newfoundland', 'Canada/Newfoundland'),
>>>  ('Canada/Pacific', 'Canada/Pacific'),
>>>  ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>>>  ('Canada/Yukon', 'Canada/Yukon'),
>>>  ('Chile/Continental', 'Chile/Continental'),
>>>  ('Chile/EasterIsland', 'Chile/EasterIsland'),
>>>  ('Cuba', 'Cuba'),
>>>  ('EET', 'EET'),
>>>  ('EST', 'EST'),
>>>  ('EST5EDT', 'EST5EDT'),
>>>  ('Egypt', 'Egypt'),
>>>  ('Eire', 'Eire'),
>>>  ('Etc/GMT', 'Etc/GMT'),
>>>  ('Etc/GMT+0', 'Etc/GMT+0'),
>>>  ('Etc/GMT+1', 'Etc/GMT+1'),
>>>  ('Etc/GMT+10', 'Etc/GMT+10'),
>>>  ('Etc/GMT+11', 'Etc/GMT+11'),
>>>  ('Etc/GMT+12', 'Etc/GMT+12'),
>>>  ('Etc/GMT+2', 'Etc/GMT+2'),
>>>  ('Etc/GMT+3', 'Etc/GMT+3'),
>>>  ('Etc/GMT+4', 'Etc/GMT+4'),
>>>  ('Etc/GMT+5', 'Etc/GMT+5'),
>>>  ('Etc/GMT+6', 'Etc/GMT+6'),
>>>  ('Etc/GMT+7', 'Etc/GMT+7'),
>>>  ('Etc/GMT+8', 'Etc/GMT+8'),
>>>  ('Etc/GMT+9', 'Etc/GMT+9'),
>>>  ('Etc/GMT-0', 'Etc/GMT-0'),
>>>  ('Etc/GMT-1', 'Etc/GMT-1'),
>>>  ('Etc/GMT-10', 'Etc/GMT-10'),
>>>  ('Etc/GMT-11', 'Etc/GMT-11'),
>>>  ('Etc/GMT-12', 'Etc/GMT-12'),
>>>  ('Etc/GMT-13', 'Etc/GMT-13'),
>>>  ('Etc/GMT-14', 'Etc/GMT-14'),
>>>  ('Etc/GMT-2', 'Etc/GMT-2'),
>>>  ('Etc/GMT-3', 'Etc/GMT-3'),
>>>  ('Etc/GMT-4', 'Etc/GMT-4'),
>>>  ('Etc/GMT-5', 'Etc/GMT-5'),
>>>  ('Etc/GMT-6', 'Etc/GMT-6'),
>>>  ('Etc/GMT-7', 'Etc/GMT-7'),
>>>  ('Etc/GMT-8', 'Etc/GMT-8'),
>>>  ('Etc/GMT-9', 'Etc/GMT-9'),
>>>  ('Etc/GMT0', 'Etc/GMT0'),
>>>  ('Etc/Greenwich', 'Etc/Greenwich'),
>>>  ('Etc/UCT', 'Etc/UCT'),
>>>  ('Etc/UTC', 'Etc/UTC'),
>>>  ('Etc/Universal', 'Etc/Universal'),
>>>  ('Etc/Zulu', 'Etc/Zulu'),
>>>  ('Europe/Amsterdam', 'Europe/Amsterdam'),
>>>  ('Europe/Andorra', 'Europe/Andorra'),
>>>  ('Europe/Athens', 'Europe/Athens'),
>>>  ('Europe/Belfast', 'Europe/Belfast'),
>>>  ('Europe/Belgrade', 'Europe/Belgrade'),
>>>  ('Europe/Berlin', 'Europe/Berlin'),
>>>  ('Europe/Bratislava', 'Europe/Bratislava'),
>>>  ('Europe/Brussels', 'Europe/Brussels'),
>>>  ('Europe/Bucharest', 'Europe/Bucharest'),
>>>  ('Europe/Budapest', 'Europe/Budapest'),
>>>  ('Europe/Chisinau', 'Europe/Chisinau'),
>>>  ('Europe/Copenhagen', 'Europe/Copenhagen'),
>>>  ('Europe/Dublin', 'Europe/Dublin'),
>>>  ('Europe/Gibraltar', 'Europe/Gibraltar'),
>>>  ('Europe/Guernsey', 'Europe/Guernsey'),
>>>  ('Europe/Helsinki', 'Europe/Helsinki'),
>>>  ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>>>  ('Europe/Istanbul', 'Europe/Istanbul'),
>>>  ('Europe/Jersey', 'Europe/Jersey'),
>>>  ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>>>  ('Europe/Kiev', 'Europe/Kiev'),
>>>  ('Europe/Lisbon', 'Europe/Lisbon'),
>>>  ('Europe/Ljubljana', 'Europe/Ljubljana'),
>>>  ('Europe/London', 'Europe/London'),
>>>  ('Europe/Luxembourg', 'Europe/Luxembourg'),
>>>  ('Europe/Madrid', 'Europe/Madrid'),
>>>  ('Europe/Malta', 'Europe/Malta'),
>>>  ('Europe/Mariehamn', 'Europe/Mariehamn'),
>>>  ('Europe/Minsk', 'Europe/Minsk'),
>>>  ('Europe/Monaco', 'Europe/Monaco'),
>>>  ('Europe/Moscow', 'Europe/Moscow'),
>>>  ('Europe/Nicosia', 'Europe/Nicosia'),
>>>  ('Europe/Oslo', 'Europe/Oslo'),
>>>  ('Europe/Paris', 'Europe/Paris'),
>>>  ('Europe/Podgorica', 'Europe/Podgorica'),
>>>  ('Europe/Prague', 'Europe/Prague'),
>>>  ('Europe/Riga', 'Europe/Riga'),
>>>  ('Europe/Rome', 'Europe/Rome'),
>>>  ('Europe/Samara', 'Europe/Samara'),
>>>  ('Europe/San_Marino', 'Europe/San_Marino'),
>>>  ('Europe/Sarajevo', 'Europe/Sarajevo'),
>>>  ('Europe/Simferopol', 'Europe/Simferopol'),
>>>  ('Europe/Skopje', 'Europe/Skopje'),
>>>  ('Europe/Sofia', 'Europe/Sofia'),
>>>  ('Europe/Stockholm', 'Europe/Stockholm'),
>>>  ('Europe/Tallinn', 'Europe/Tallinn'),
>>>  ('Europe/Tirane', 'Europe/Tirane'),
>>>  ('Europe/Tiraspol', 'Europe/Tiraspol'),
>>>  ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>>>  ('Europe/Vaduz', 'Europe/Vaduz'),
>>>  ('Europe/Vatican', 'Europe/Vatican'),
>>>  ('Europe/Vienna', 'Europe/Vienna'),
>>>  ('Europe/Vilnius', 'Europe/Vilnius'),
>>>  ('Europe/Volgograd', 'Europe/Volgograd'),
>>>  ('Europe/Warsaw', 'Europe/Warsaw'),
>>>  ('Europe/Zagreb', 'Europe/Zagreb'),
>>>  ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>>>  ('Europe/Zurich', 'Europe/Zurich'),
>>>  ('GB', 'GB'),
>>>  ('GB-Eire', 'GB-Eire'),
>>>  ('GMT', 'GMT'),
>>>  ('GMT+0', 'GMT+0'),
>>>  ('GMT-0', 'GMT-0'),
>>>  ('GMT0', 'GMT0'),
>>>  ('Greenwich', 'Greenwich'),
>>>  ('HST', 'HST'),
>>>  ('Hongkong', 'Hongkong'),
>>>  ('Iceland', 'Iceland'),
>>>  ('Indian/Antananarivo', 'Indian/Antananarivo'),
>>>  ('Indian/Chagos', 'Indian/Chagos'),
>>>  ('Indian/Christmas', 'Indian/Christmas'),
>>>  ('Indian/Cocos', 'Indian/Cocos'),
>>>  ('Indian/Comoro', 'Indian/Comoro'),
>>>  ('Indian/Kerguelen', 'Indian/Kerguelen'),
>>>  ('Indian/Mahe', 'Indian/Mahe'),
>>>  ('Indian/Maldives', 'Indian/Maldives'),
>>>  ('Indian/Mauritius', 'Indian/Mauritius'),
>>>  ('Indian/Mayotte', 'Indian/Mayotte'),
>>>  ('Indian/Reunion', 'Indian/Reunion'),
>>>  ('Iran', 'Iran'),
>>>  ('Israel', 'Israel'),
>>>  ('Jamaica', 'Jamaica'),
>>>  ('Japan', 'Japan'),
>>>  ('Kwajalein', 'Kwajalein'),
>>>  ('Libya', 'Libya'),
>>>  ('MET', 'MET'),
>>>  ('MST', 'MST'),
>>>  ('MST7MDT', 'MST7MDT'),
>>>  ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>>>  ('Mexico/BajaSur', 'Mexico/BajaSur'),
>>>  ('Mexico/General', 'Mexico/General'),
>>>  ('NZ', 'NZ'),
>>>  ('NZ-CHAT', 'NZ-CHAT'),
>>>  ('Navajo', 'Navajo'),
>>>  ('PRC', 'PRC'),
>>>  ('PST8PDT', 'PST8PDT'),
>>>  ('Pacific/Apia', 'Pacific/Apia'),
>>>  ('Pacific/Auckland', 'Pacific/Auckland'),
>>>  ('Pacific/Chatham', 'Pacific/Chatham'),
>>>  ('Pacific/Chuuk', 'Pacific/Chuuk'),
>>>  ('Pacific/Easter', 'Pacific/Easter'),
>>>  ('Pacific/Efate', 'Pacific/Efate'),
>>>  ('Pacific/Enderbury', 'Pacific/Enderbury'),
>>>  ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>>>  ('Pacific/Fiji', 'Pacific/Fiji'),
>>>  ('Pacific/Funafuti', 'Pacific/Funafuti'),
>>>  ('Pacific/Galapagos', 'Pacific/Galapagos'),
>>>  ('Pacific/Gambier', 'Pacific/Gambier'),
>>>  ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>>>  ('Pacific/Guam', 'Pacific/Guam'),
>>>  ('Pacific/Honolulu', 'Pacific/Honolulu'),
>>>  ('Pacific/Johnston', 'Pacific/Johnston'),
>>>  ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>>>  ('Pacific/Kosrae', 'Pacific/Kosrae'),
>>>  ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>>>  ('Pacific/Majuro', 'Pacific/Majuro'),
>>>  ('Pacific/Marquesas', 'Pacific/Marquesas'),
>>>  ('Pacific/Midway', 'Pacific/Midway'),
>>>  ('Pacific/Nauru', 'Pacific/Nauru'),
>>>  ('Pacific/Niue', 'Pacific/Niue'),
>>>  ('Pacific/Norfolk', 'Pacific/Norfolk'),
>>>  ('Pacific/Noumea', 'Pacific/Noumea'),
>>>  ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>>>  ('Pacific/Palau', 'Pacific/Palau'),
>>>  ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>>>  ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>>>  ('Pacific/Ponape', 'Pacific/Ponape'),
>>>  ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>>>  ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>>>  ('Pacific/Saipan', 'Pacific/Saipan'),
>>>  ('Pacific/Samoa', 'Pacific/Samoa'),
>>>  ('Pacific/Tahiti', 'Pacific/Tahiti'),
>>>  ('Pacific/Tarawa', 'Pacific/Tarawa'),
>>>  ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>>>  ('Pacific/Truk', 'Pacific/Truk'),
>>>  ('Pacific/Wake', 'Pacific/Wake'),
>>>  ('Pacific/Wallis', 'Pacific/Wallis'),
>>>  ('Pacific/Yap', 'Pacific/Yap'),
>>>  ('Poland', 'Poland'),
>>>  ('Portugal', 'Portugal'),
>>>  ('ROC', 'ROC'),
>>>  ('ROK', 'ROK'),
>>>  ('Singapore', 'Singapore'),
>>>  ('Turkey', 'Turkey'),
>>>  ('UCT', 'UCT'),
>>>  ('US/Alaska', 'US/Alaska'),
>>>  ('US/Aleutian', 'US/Aleutian'),
>>>  ('US/Arizona', 'US/Arizona'),
>>>  ('US/Central', 'US/Central'),
>>>  ('US/East-Indiana', 'US/East-Indiana'),
>>>  ('US/Eastern', 'US/Eastern'),
>>>  ('US/Hawaii', 'US/Hawaii'),
>>>  ('US/Indiana-Starke', 'US/Indiana-Starke'),
>>>  ('US/Michigan', 'US/Michigan'),
>>>  ('US/Mountain', 'US/Mountain'),
>>>  ('US/Pacific', 'US/Pacific'),
>>>  ('US/Pacific-New', 'US/Pacific-New'),
>>>  ('US/Samoa', 'US/Samoa'),
>>>  ('UTC', 'UTC'),
>>>  ('Universal', 'Universal'),
>>>  ('W-SU', 'W-SU'),
>>>  ('WET', 'WET'),
>>>  ('Zulu', 'Zulu')]
>>> FILE_UPLOAD_HANDLERS
>>> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>>>  'django.core.files.uploadhandler.TemporaryFileUploadHandler')
>>> DEFAULT_CONTENT_TYPE
>>> 'text/html'
>>> LEAFLET_CONFIG
>>> {'TILES_URL': 'http://{s}.tile2.opencyclemap.org/transport/{z}/{x}/{y}.png <http://tile2.opencyclemap.org/transport/%7Bz%7D/%7Bx%7D/%7By%7D.png>'}
>>> DEBUG_STATIC
>>> True
>>> TEST_RUNNER
>>> 'django_nose.NoseTestSuiteRunner'
>>> APPEND_SLASH
>>> True
>>> FIRST_DAY_OF_WEEK
>>> 0
>>> DATABASE_ROUTERS
>>> DEFAULT_MAP_ZOOM
>>> 0
>>> YEAR_MONTH_FORMAT
>>> 'F Y'
>>> STATICFILES_STORAGE
>>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>>> CACHES
>>> {'default': {'BACKEND': 'django.core.cache.backends.locmem.LocMemCache'}}
>>> SERVER_EMAIL
>>> 'root at localhost'
>>> SESSION_COOKIE_PATH
>>> USE_X_FORWARDED_HOST
>>> False
>>> ACCOUNT_OPEN_SIGNUP
>>> True
>>> CATALOGUE
>>> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>>>              'URL': 'http://crisp.norminet.org.ph/catalogue/csw'}}
>>> FILE_UPLOAD_TEMP_DIR
>>> None
>>> MIDDLEWARE_CLASSES
>>> ('django.middleware.common.CommonMiddleware',
>>>  'django.contrib.sessions.middleware.SessionMiddleware',
>>>  'django.contrib.messages.middleware.MessageMiddleware',
>>>  'request.middleware.RequestMiddleware',
>>>  'django.middleware.locale.LocaleMiddleware',
>>>  'pagination.middleware.PaginationMiddleware',
>>>  'django.middleware.csrf.CsrfViewMiddleware',
>>>  'django.contrib.auth.middleware.AuthenticationMiddleware')
>>> USE_I18N
>>> True
>>> THOUSAND_SEPARATOR
>>> SECRET_KEY
>>> DB_DATASTORE_PORT
>>> LANGUAGE_COOKIE_NAME
>>> 'django_language'
>>> ACCOUNT_REMEMBER_ME_EXPIRY
>>> 315360000
>>> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
>>> ACCOUNT_EMAIL_UNIQUE
>>> True
>>> TRANSACTIONS_MANAGED
>>> False
>>> LOGGING_CONFIG
>>> 'django.utils.log.dictConfig'
>>> TEMPLATE_LOADERS
>>> ('django.template.loaders.filesystem.Loader',
>>>  'django.template.loaders.app_directories.Loader')
>>> FORCE_SCRIPT_NAME
>>> None
>>> WSGI_APPLICATION
>>> None
>>> TEMPLATE_DEBUG
>>> True
>>> X_FRAME_OPTIONS
>>> 'SAMEORIGIN'
>>> AUTHENTICATION_BACKENDS
>>> ('geonode.security.auth.GranularBackend',)
>>> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
>>> True
>>> ACCOUNT_LOGIN_REDIRECT_URL
>>> SIGNING_BACKEND
>>> 'django.core.signing.TimestampSigner'
>>> SESSION_COOKIE_SECURE
>>> False
>>> ACCOUNT_LOGIN_URL
>>> 'account_login'
>>> CSRF_COOKIE_DOMAIN
>>> None
>>> FILE_CHARSET
>>> 'utf-8'
>>> DEBUG
>>> True
>>> SESSION_FILE_PATH
>>> None
>>> DEFAULT_FILE_STORAGE
>>> 'django.core.files.storage.FileSystemStorage'
>>> INSTALLED_APPS
>>> ('django.contrib.auth',
>>>  'django.contrib.contenttypes',
>>>  'django.contrib.sessions',
>>>  'django.contrib.sites',
>>>  'django.contrib.admin',
>>>  'django.contrib.sitemaps',
>>>  'django.contrib.staticfiles',
>>>  'django.contrib.messages',
>>>  'django.contrib.humanize',
>>>  'pagination',
>>>  'taggit',
>>>  'taggit_templatetags',
>>>  'south',
>>>  'friendlytagloader',
>>>  'geoexplorer',
>>>  'request',
>>>  'pinax_theme_bootstrap_account',
>>>  'pinax_theme_bootstrap',
>>>  'django_forms_bootstrap',
>>>  'account',
>>>  'avatar',
>>>  'dialogos',
>>>  'agon_ratings',
>>>  'notification',
>>>  'announcements',
>>>  'actstream',
>>>  'relationships',
>>>  'user_messages',
>>>  'geonode.people',
>>>  'geonode.base',
>>>  'geonode.layers',
>>>  'geonode.upload',
>>>  'geonode.maps',
>>>  'geonode.proxy',
>>>  'geonode.security',
>>>  'geonode.search',
>>>  'geonode.catalogue',
>>>  'geonode.documents')
>>> LANGUAGES_BIDI
>>> ('he', 'ar', 'fa')
>>> USE_L10N
>>> False
>>> DATABASE_ENGINE
>>> 'postgresql_psycopg2'
>>> DB_DATASTORE_PASSWORD
>>> DATABASE_NAME
>>> 'geonode'
>>> PREPEND_WWW
>>> False
>>> SECURE_PROXY_SSL_HEADER
>>> None
>>> PASSWORD_RESET_TIMEOUT_DAYS
>>> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
>>> SESSION_COOKIE_HTTPONLY
>>> True
>>> DATABASE_PORT
>>> '5432'
>>> DEBUG_PROPAGATE_EXCEPTIONS
>>> False
>>> MEDIA_URL
>>> '/uploaded/'
>>> MONTH_DAY_FORMAT
>>> 'F j'
>>> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
>>> 'account_login'
>>> LOGIN_URL
>>> '/account/login/'
>>> SESSION_EXPIRE_AT_BROWSER_CLOSE
>>> False
>>> SOUTH_TESTS_MIGRATE
>>> False
>>> SESSION_SAVE_EVERY_REQUEST
>>> False
>>> TIME_FORMAT
>>> 'P'
>>> AUTH_USER_MODEL
>>> 'auth.User'
>>> DATE_INPUT_FORMATS
>>> ('%Y-%m-%d',
>>>  '%m/%d/%Y',
>>>  '%m/%d/%y',
>>>  '%b %d %Y',
>>>  '%b %d, %Y',
>>>  '%d %b %Y',
>>>  '%d %b, %Y',
>>>  '%B %d %Y',
>>>  '%B %d, %Y',
>>>  '%d %B %Y',
>>>  '%d %B, %Y')
>>> ACCOUNT_LOGOUT_REDIRECT_URL
>>> DOCUMENTS_APP
>>> True
>>> EMAIL_HOST_PASSWORD
>>> AUTH_PROFILE_MODULE
>>> 'people.Profile'
>>> CACHE_MIDDLEWARE_ALIAS
>>> 'default'
>>> DB_DATASTORE_HOST
>>> NUMBER_GROUPING
>>> 0
>>> SHORT_DATETIME_FORMAT
>>> 'm/d/Y P'
>>> GEOSERVER_CREDENTIALS
>>> ('admin', 'geoserver')
>>> SESSION_ENGINE
>>> 'django.contrib.sessions.backends.db'
>>> ACCOUNT_DELETION_MARK_CALLBACK
>>> CSRF_COOKIE_PATH
>>> LOGIN_REDIRECT_URL
>>> ABSOLUTE_URL_OVERRIDES
>>> {'auth.user': <function get_user_url at 0x7f03647ab578>}
>>> PROJECT_ROOT
>>> '/usr/local/lib/python2.7/dist-packages/geonode'
>>> ACCOUNT_DELETION_EXPUNGE_HOURS
>>> 48
>>> GEONODE_ROOT
>>> DECIMAL_SEPARATOR
>>> CSRF_FAILURE_VIEW
>>> 'django.views.csrf.csrf_failure'
>>> CACHE_MIDDLEWARE_KEY_PREFIX
>>> NOSE_ARGS
>>> ['--nocapture', '--detailed-errors']
>>> LOCALE_PATHS
>>> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
>>> TEMPLATE_STRING_IF_INVALID
>>> COMMENTS_ALLOW_PROFANITIES
>>> False
>>> LOGOUT_URL
>>> '/account/logout/'
>>> MAP_BASELAYERS
>>> [{'source': {'ptype': 'gxp_wmscsource',
>>>              'restUrl': '/gs/rest',
>>>              'url': 'http://crisp.norminet.org.ph/geoserver/wms'}},
>>>  {'args': ['No background'],
>>>   'fixed': True,
>>>   'group': 'background',
>>>   'source': {'ptype': 'gxp_olsource'},
>>>   'type': 'OpenLayers.Layer',
>>>   'visibility': False},
>>>  {'args': ['OpenStreetMap'],
>>>   'fixed': True,
>>>   'type': 'OpenLayers.Layer.OSM',
>>>  {'group': 'background',
>>>   'name': 'osm',
>>>   'source': {'ptype': 'gxp_mapquestsource'},
>>>   'visibility': True},
>>>   'name': 'naip',
>>>  {'fixed': True,
>>>   'name': 'AerialWithLabels',
>>>   'source': {'ptype': 'gxp_bingsource'},
>>>  {'source': {'ptype': 'gxp_mapboxsource'}}]
>>> EMAIL_USE_TLS
>>> True
>>> ACCOUNT_LANGUAGES
>>> [('en', u'English'),
>>>  ('es', u'espa\xf1ol'),
>>>  ('it', u'italiano'),
>>>  ('fr', u'fran\xe7ais'),
>>>  ('de', u'Deutsch'),
>>>  ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>>>  ('id', u'Bahasa Indonesia'),
>>>  ('ja', u'\u65e5\u672c\u8a9e')]
>>> FIXTURE_DIRS
>>> EMAIL_HOST
>>> 'smtp.gmail.com'
>>> DATE_FORMAT
>>> 'N j, Y'
>>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
>>> MEDIA_ROOT
>>> '/var/www/geonode/uploaded'
>>> AGON_RATINGS_CATEGORY_CHOICES
>>> {'layers.Layer': {'layer': 'How good is this layer?'},
>>>  'maps.Map': {'map': 'How good is this map?'}}
>>> DEFAULT_EXCEPTION_REPORTER_FILTER
>>> 'django.views.debug.SafeExceptionReporterFilter'
>>> ADMINS
>>> (('Jeff', 'jeffytoms at gmail.com'),)
>>> FORMAT_MODULE_PATH
>>> None
>>> DEFAULT_FROM_EMAIL
>>> STATICFILES_DIRS
>>> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
>>> GEOSERVER_URL
>>> DATETIME_FORMAT
>>> 'N j, Y, P'
>>> TEMPLATE_DIRS
>>> ('/etc/geonode/templates',
>>>  '/usr/local/lib/python2.7/dist-packages/geonode/templates')
>>> ALLOWED_DOCUMENT_TYPES
>>> ['doc',
>>>  'docx',
>>>  'xls',
>>>  'xslx',
>>>  'pdf',
>>>  'zip',
>>>  'jpg',
>>>  'jpeg',
>>>  'tif',
>>>  'tiff',
>>>  'png',
>>>  'gif',
>>>  'txt']
>>> ACCOUNT_DELETION_EXPUNGE_CALLBACK
>>> SITE_ID
>>> 1
>>> DISALLOWED_USER_AGENTS
>>> ALLOWED_INCLUDE_ROOTS
>>> ACCOUNT_SETTINGS_REDIRECT_URL
>>> 'account_settings'
>>> SITEURL
>>> 'http://crisp.norminet.org.ph/'
>>> LOGGING
>>> {'disable_existing_loggers': True,
>>>  'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>>>  'formatters': {'simple': {'format': '%(message)s'},
>>>                 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>>>  'handlers': {'console': {'class': 'logging.StreamHandler',
>>>                           'formatter': 'simple',
>>>                           'level': 'ERROR'},
>>>               'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>>>                               'filters': ['require_debug_false'],
>>>                               'level': 'ERROR'},
>>>               'null': {'class': 'django.utils.log.NullHandler',
>>>                        'level': 'ERROR'}},
>>>  'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'django.request': {'handlers': ['mail_admins'],
>>>                                 'level': 'ERROR',
>>>                                 'propagate': True},
>>>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'south': {'handlers': ['console'], 'level': 'ERROR'}},
>>>  'version': 1}
>>> SHORT_DATE_FORMAT
>>> 'm/d/Y'
>>> DATABASE_USER
>>> 'geonode'
>>> DB_DATASTORE_DATABASE
>>> ACCOUNT_SIGNUP_REDIRECT_URL
>>> SITENAME
>>> 'GeoNode'
>>> IGNORABLE_404_URLS
>>> TIME_ZONE
>>> 'Asia/Manila'
>>> SOUTH_MIGRATION_MODULES
>>> {'avatar': 'geonode.migrations.avatar'}
>>> FILE_UPLOAD_MAX_MEMORY_SIZE
>>> 2621440
>>> DB_DATASTORE_TYPE
>>> EMAIL_BACKEND
>>> 'django.core.mail.backends.smtp.EmailBackend'
>>> DEFAULT_TABLESPACE
>>> TEMPLATE_CONTEXT_PROCESSORS
>>> ('django.contrib.auth.context_processors.auth',
>>>  'django.core.context_processors.debug',
>>>  'django.core.context_processors.i18n',
>>>  'django.core.context_processors.tz',
>>>  'django.core.context_processors.media',
>>>  'django.core.context_processors.static',
>>>  'django.core.context_processors.request',
>>>  'django.contrib.messages.context_processors.messages',
>>>  'account.context_processors.account',
>>>  'geonode.context_processors.resource_urls')
>>> SESSION_COOKIE_AGE
>>> 1209600
>>> SETTINGS_MODULE
>>> 'geonode.settings'
>>> USE_ETAGS
>>> False
>>> LANGUAGES
>>> (('en', 'English'),
>>>  ('es', 'Espa\xc3\xb1ol'),
>>>  ('it', 'Italiano'),
>>>  ('fr', 'Fran\xc3\xa7ais'),
>>>  ('de', 'Deutsch'),
>>>  ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>>>  ('id', 'Bahasa Indonesia'),
>>>  ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe4\xba\xba'))
>>> DEFAULT_INDEX_TABLESPACE
>>> INTERNAL_IPS
>>> STATIC_URL
>>> '/static/'
>>> EMAIL_PORT
>>> 587
>>> DEFAULT_TOPICCATEGORY
>>> 'location'
>>> USE_TZ
>>> False
>>> DEFAULT_SEARCH_SIZE
>>> 10
>>> PASSWORD_HASHERS
>>> ACTSTREAM_SETTINGS
>>> {'FETCH_RELATIONS': True,
>>>  'GFK_FETCH_DEPTH': 1,
>>>  'MODELS': ('auth.user', 'layers.layer', 'maps.map'),
>>>  'USE_JSONFIELD': True,
>>>  'USE_PREFETCH': True}
>>> CACHE_MIDDLEWARE_SECONDS
>>> 600
>>> ACCOUNT_CREATE_ON_SAVE
>>> True
>>> DATETIME_INPUT_FORMATS
>>> ('%Y-%m-%d %H:%M:%S',
>>>  '%Y-%m-%d %H:%M:%S.%f',
>>>  '%Y-%m-%d %H:%M',
>>>  '%Y-%m-%d',
>>>  '%m/%d/%Y %H:%M:%S',
>>>  '%m/%d/%Y %H:%M:%S.%f',
>>>  '%m/%d/%Y %H:%M',
>>>  '%m/%d/%Y',
>>>  '%m/%d/%y %H:%M:%S',
>>>  '%m/%d/%y %H:%M:%S.%f',
>>>  '%m/%d/%y %H:%M',
>>>  '%m/%d/%y')
>>> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
>>> False
>>> DATABASE_PASSWORD
>>> PROFANITIES_LIST
>>> EMAIL_HOST_USER
>>> MAX_DOCUMENT_SIZE
>>> 10
>>> You're seeing this error because you have DEBUG = True in your Django
>>> settings file. Change that to False, and Django will display a standard
>>> 500 page.
>>> On Wed, Jul 1, 2015 at 7:10 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hm sure that you didn't upgrade geonode at some point ? :)
>>>> anyway:
>>>> $ geonode syncdb
>>>> should fix it
>>>> 2015-07-01 11:55 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>> That was really Simone! I applied everything there and it somehow
>>>>> started postgres..
>>>>> I also managed to finally execute the updateip command at last.
>>>>> However, I got a longer error (debug=true), and an error page if I
>>>>> access the site url.
>>>>> So here's the error (I hope you can bear with me):
>>>>> DatabaseError at /
>>>>> relation "request_request" does not exist
>>>>> LINE 1: INSERT INTO "request_request" ("response", "method", "path",...
>>>>> Request Method:GETRequest URL:http://localhost/Django Version:1.5.1Exception
>>>>> Type:DatabaseErrorException Value:
>>>>> Exception Location:/usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>>>> in execute, line 54Python Executable:/usr/bin/pythonPython Version:
>>>>> 2.7.3Python Path:
>>>>> Server time:Wed, 1 Jul 2015 17:16:14 +0800
>>>>> Traceback Switch to copy-and-paste view <http://localhost/#>
>>>>>    get_response
>>>>>    1.
>>>>>                       response = middleware_method(request, response)
>>>>>    ▶ Local vars <http://localhost/#>
>>>>>    - /usr/local/lib/python2.7/dist-packages/request/middleware.py in
>>>>>    process_response
>>>>>    1.
>>>>>               r.from_http_request(request, response)
>>>>>    - /usr/local/lib/python2.7/dist-packages/request/models.py in
>>>>>    from_http_request
>>>>>    1.
>>>>>                   self.save()
>>>>>    - /usr/local/lib/python2.7/dist-packages/request/models.py in save
>>>>>    1.
>>>>>               super(Request, self).save(*args, **kwargs)
>>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/base.py in save
>>>>>    1.
>>>>>                              force_update=force_update, update_fields=update_fields)
>>>>>    save_base
>>>>>    1.
>>>>>                       result = manager._insert([self], fields=fields, return_id=update_pk, using=using, raw=raw)
>>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in
>>>>>    _insert
>>>>>    1.
>>>>>               return insert_query(self.model, objs, fields, **kwargs)
>>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in
>>>>>    insert_query
>>>>>    1.
>>>>>           return query.get_compiler(using=using).execute_sql(return_id)
>>>>>    - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>>>>     in execute_sql
>>>>>    1.
>>>>>                   cursor.execute(sql, params)
>>>>>    - /usr/lib/python2.7/dist-packages/django/db/backends/util.py in
>>>>>    execute
>>>>>    1.
>>>>>                   return self.cursor.execute(sql, params)
>>>>>     in execute
>>>>>    1.
>>>>>                   six.reraise(utils.DatabaseError, utils.DatabaseError(*tuple(e.args)), sys.exc_info()[2])
>>>>>     in execute
>>>>>    1.
>>>>>                   return self.cursor.execute(query, args)
>>>>> No GET data
>>>>> 'layer'
>>>>> FILES
>>>>> No FILES data
>>>>> 'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>>> '80'
>>>>> HTTP_COOKIE
>>>>> 'csrftoken=h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>>> SERVER_SOFTWARE
>>>>> SCRIPT_NAME
>>>>> u''
>>>>> SERVER_SIGNATURE
>>>>> '<address>Apache/2.2.22 (Ubuntu) Server at localhost Port 80</address>\n'
>>>>> REQUEST_METHOD
>>>>> 'GET'
>>>>> PATH_INFO
>>>>> u'/'
>>>>> SERVER_PROTOCOL
>>>>> 'HTTP/1.1'
>>>>> QUERY_STRING
>>>>> HTTP_USER_AGENT
>>>>> HTTP_CONNECTION
>>>>> 'keep-alive'
>>>>> SERVER_NAME
>>>>> 'localhost'
>>>>> REMOTE_ADDR
>>>>> '127.0.0.1'
>>>>> 'wsgi-script'
>>>>> wsgi.url_scheme
>>>>> 'http'
>>>>> PATH_TRANSLATED
>>>>> SERVER_PORT
>>>>> '80'
>>>>> wsgi.multiprocess
>>>>> True
>>>>> '0'
>>>>> SERVER_ADDR
>>>>> '127.0.0.1'
>>>>> DOCUMENT_ROOT
>>>>> 'geonode'
>>>>> SCRIPT_FILENAME
>>>>> SERVER_ADMIN
>>>>> wsgi.input
>>>>> <mod_wsgi.Input object at 0x7fa31c5ab1b0>
>>>>> HTTP_HOST
>>>>> 'localhost'
>>>>> wsgi.multithread
>>>>> True
>>>>> 'application'
>>>>> HTTP_CACHE_CONTROL
>>>>> 'max-age=0'
>>>>> REQUEST_URI
>>>>> HTTP_ACCEPT
>>>>> wsgi.version
>>>>> (1, 1)
>>>>> GATEWAY_INTERFACE
>>>>> 'CGI/1.1'
>>>>> wsgi.run_once
>>>>> False
>>>>> wsgi.errors
>>>>> <mod_wsgi.Log object at 0x7fa31d89fc30>
>>>>> REMOTE_PORT
>>>>> '35077'
>>>>> 'en-US,en;q=0.8'
>>>>> mod_wsgi.version
>>>>> (3, 3)
>>>>> 'localhost|'
>>>>> '1'
>>>>> wsgi.file_wrapper
>>>>> CSRF_COOKIE
>>>>> u'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>>> 'gzip,deflate,sdch'
>>>>> STATIC_ROOT
>>>>> GOOGLE_API_KEY
>>>>> False
>>>>> CSRF_COOKIE_SECURE
>>>>> False
>>>>> LANGUAGE_CODE
>>>>> 'en'
>>>>> ROOT_URLCONF
>>>>> 'geonode.urls'
>>>>> MANAGERS
>>>>> DB_DATASTORE_NAME
>>>>> DEFAULT_CHARSET
>>>>> 'utf-8'
>>>>> PYCSW
>>>>>                                         'enabled': 'true',
>>>>> DEFAULT_MAP_CENTER
>>>>> (0, 0)
>>>>> 3
>>>>> DB_DATASTORE
>>>>> False
>>>>> None
>>>>> GEOSERVER_BASE_URL
>>>>> REGISTRATION_OPEN
>>>>> False
>>>>> ALLOWED_HOSTS
>>>>> OGC_SERVER
>>>>>              'USER': 'admin',
>>>>> MESSAGE_STORAGE
>>>>> DATABASE_HOST
>>>>> 'localhost'
>>>>> '[Django] '
>>>>> False
>>>>> STATICFILES_FINDERS
>>>>> SESSION_CACHE_ALIAS
>>>>> 'default'
>>>>> None
>>>>> SESSION_COOKIE_NAME
>>>>> 'sessionid'
>>>>> DB_DATASTORE_USER
>>>>> CSRF_COOKIE_NAME
>>>>> 'csrftoken'
>>>>> ADMIN_FOR
>>>>> TIME_INPUT_FORMATS
>>>>> DATABASES
>>>>>                'NAME': 'geonode',
>>>>>                'OPTIONS': {},
>>>>>                'PORT': '5432',
>>>>>                'TEST_NAME': None,
>>>>>                'USER': 'geonode'},
>>>>>              'NAME': 'geonode',
>>>>>              'OPTIONS': {},
>>>>>              'PORT': '5432',
>>>>>              'TEST_NAME': None,
>>>>>              'USER': 'geonode'}}
>>>>> None
>>>>> ACCOUNT_TIMEZONES
>>>>>  ('CET', 'CET'),
>>>>>  ('Cuba', 'Cuba'),
>>>>>  ('EET', 'EET'),
>>>>>  ('EST', 'EST'),
>>>>>  ('Egypt', 'Egypt'),
>>>>>  ('Eire', 'Eire'),
>>>>>  ('GB', 'GB'),
>>>>>  ('GMT', 'GMT'),
>>>>>  ('GMT+0', 'GMT+0'),
>>>>>  ('GMT-0', 'GMT-0'),
>>>>>  ('GMT0', 'GMT0'),
>>>>>  ('HST', 'HST'),
>>>>>  ('Iran', 'Iran'),
>>>>>  ('Japan', 'Japan'),
>>>>>  ('Libya', 'Libya'),
>>>>>  ('MET', 'MET'),
>>>>>  ('MST', 'MST'),
>>>>>  ('NZ', 'NZ'),
>>>>>  ('PRC', 'PRC'),
>>>>>  ('ROC', 'ROC'),
>>>>>  ('ROK', 'ROK'),
>>>>>  ('UCT', 'UCT'),
>>>>>  ('UTC', 'UTC'),
>>>>>  ('W-SU', 'W-SU'),
>>>>>  ('WET', 'WET'),
>>>>>  ('Zulu', 'Zulu')]
>>>>> 'text/html'
>>>>> LEAFLET_CONFIG
>>>>> DEBUG_STATIC
>>>>> True
>>>>> TEST_RUNNER
>>>>> APPEND_SLASH
>>>>> True
>>>>> FIRST_DAY_OF_WEEK
>>>>> 0
>>>>> DATABASE_ROUTERS
>>>>> DEFAULT_MAP_ZOOM
>>>>> 0
>>>>> YEAR_MONTH_FORMAT
>>>>> 'F Y'
>>>>> STATICFILES_STORAGE
>>>>> CACHES
>>>>> SERVER_EMAIL
>>>>> 'root at localhost'
>>>>> SESSION_COOKIE_PATH
>>>>> False
>>>>> ACCOUNT_OPEN_SIGNUP
>>>>> True
>>>>> CATALOGUE
>>>>> None
>>>>> MIDDLEWARE_CLASSES
>>>>> USE_I18N
>>>>> True
>>>>> THOUSAND_SEPARATOR
>>>>> SECRET_KEY
>>>>> DB_DATASTORE_PORT
>>>>> 'django_language'
>>>>> 315360000
>>>>> True
>>>>> False
>>>>> LOGGING_CONFIG
>>>>> TEMPLATE_LOADERS
>>>>> FORCE_SCRIPT_NAME
>>>>> None
>>>>> WSGI_APPLICATION
>>>>> None
>>>>> TEMPLATE_DEBUG
>>>>> True
>>>>> X_FRAME_OPTIONS
>>>>> 'SAMEORIGIN'
>>>>> True
>>>>> SIGNING_BACKEND
>>>>> False
>>>>> ACCOUNT_LOGIN_URL
>>>>> 'account_login'
>>>>> CSRF_COOKIE_DOMAIN
>>>>> None
>>>>> FILE_CHARSET
>>>>> 'utf-8'
>>>>> DEBUG
>>>>> True
>>>>> SESSION_FILE_PATH
>>>>> None
>>>>> INSTALLED_APPS
>>>>>  'pagination',
>>>>>  'taggit',
>>>>>  'south',
>>>>>  'geoexplorer',
>>>>>  'request',
>>>>>  'account',
>>>>>  'avatar',
>>>>>  'dialogos',
>>>>>  'agon_ratings',
>>>>>  'notification',
>>>>>  'announcements',
>>>>>  'actstream',
>>>>>  'relationships',
>>>>>  'user_messages',
>>>>>  'geonode.people',
>>>>>  'geonode.base',
>>>>>  'geonode.layers',
>>>>>  'geonode.upload',
>>>>>  'geonode.maps',
>>>>>  'geonode.proxy',
>>>>>  'geonode.security',
>>>>>  'geonode.search',
>>>>> LANGUAGES_BIDI
>>>>> ('he', 'ar', 'fa')
>>>>> USE_L10N
>>>>> False
>>>>> DATABASE_ENGINE
>>>>> DATABASE_NAME
>>>>> 'geonode'
>>>>> PREPEND_WWW
>>>>> False
>>>>> None
>>>>> True
>>>>> DATABASE_PORT
>>>>> '5432'
>>>>> False
>>>>> MEDIA_URL
>>>>> '/uploaded/'
>>>>> MONTH_DAY_FORMAT
>>>>> 'F j'
>>>>> 'account_login'
>>>>> LOGIN_URL
>>>>> '/account/login/'
>>>>> False
>>>>> SOUTH_TESTS_MIGRATE
>>>>> False
>>>>> False
>>>>> TIME_FORMAT
>>>>> 'P'
>>>>> AUTH_USER_MODEL
>>>>> 'auth.User'
>>>>> DATE_INPUT_FORMATS
>>>>> ('%Y-%m-%d',
>>>>>  '%m/%d/%Y',
>>>>>  '%m/%d/%y',
>>>>>  '%b %d %Y',
>>>>>  '%b %d, %Y',
>>>>>  '%d %b %Y',
>>>>>  '%d %b, %Y',
>>>>>  '%B %d %Y',
>>>>>  '%B %d, %Y',
>>>>>  '%d %B %Y',
>>>>>  '%d %B, %Y')
>>>>> DOCUMENTS_APP
>>>>> True
>>>>> EMAIL_HOST_PASSWORD
>>>>> AUTH_PROFILE_MODULE
>>>>> 'people.Profile'
>>>>> 'default'
>>>>> DB_DATASTORE_HOST
>>>>> NUMBER_GROUPING
>>>>> 0
>>>>> 'm/d/Y P'
>>>>> SESSION_ENGINE
>>>>> CSRF_COOKIE_PATH
>>>>> LOGIN_REDIRECT_URL
>>>>> {'auth.user': <function get_user_url at 0x7fa31c7ab5f0>}
>>>>> PROJECT_ROOT
>>>>> 48
>>>>> GEONODE_ROOT
>>>>> DECIMAL_SEPARATOR
>>>>> CSRF_FAILURE_VIEW
>>>>> NOSE_ARGS
>>>>> LOCALE_PATHS
>>>>> False
>>>>> LOGOUT_URL
>>>>> '/account/logout/'
>>>>> MAP_BASELAYERS
>>>>>   'fixed': True,
>>>>>   'fixed': True,
>>>>>   'name': 'osm',
>>>>>   'name': 'naip',
>>>>>  {'fixed': True,
>>>>> EMAIL_USE_TLS
>>>>> True
>>>>> ACCOUNT_LANGUAGES
>>>>>  ('de', u'Deutsch'),
>>>>> FIXTURE_DIRS
>>>>> EMAIL_HOST
>>>>> 'smtp.gmail.com'
>>>>> DATE_FORMAT
>>>>> 'N j, Y'
>>>>> MEDIA_ROOT
>>>>> ADMINS
>>>>> FORMAT_MODULE_PATH
>>>>> None
>>>>> DEFAULT_FROM_EMAIL
>>>>> STATICFILES_DIRS
>>>>> GEOSERVER_URL
>>>>> DATETIME_FORMAT
>>>>> 'N j, Y, P'
>>>>> TEMPLATE_DIRS
>>>>> ['doc',
>>>>>  'docx',
>>>>>  'xls',
>>>>>  'xslx',
>>>>>  'pdf',
>>>>>  'zip',
>>>>>  'jpg',
>>>>>  'jpeg',
>>>>>  'tif',
>>>>>  'tiff',
>>>>>  'png',
>>>>>  'gif',
>>>>>  'txt']
>>>>> SITE_ID
>>>>> 1
>>>>> 'account_settings'
>>>>> SITEURL
>>>>> LOGGING
>>>>>                           'level': 'ERROR'},
>>>>>                               'level': 'ERROR'},
>>>>>                        'level': 'ERROR'}},
>>>>>                                 'level': 'ERROR',
>>>>>                                 'propagate': True},
>>>>>  'version': 1}
>>>>> SHORT_DATE_FORMAT
>>>>> 'm/d/Y'
>>>>> DATABASE_USER
>>>>> 'geonode'
>>>>> SITENAME
>>>>> 'GeoNode'
>>>>> IGNORABLE_404_URLS
>>>>> TIME_ZONE
>>>>> 'Asia/Manila'
>>>>> 2621440
>>>>> DB_DATASTORE_TYPE
>>>>> EMAIL_BACKEND
>>>>> DEFAULT_TABLESPACE
>>>>> SESSION_COOKIE_AGE
>>>>> 1209600
>>>>> SETTINGS_MODULE
>>>>> 'geonode.settings'
>>>>> USE_ETAGS
>>>>> False
>>>>> LANGUAGES
>>>>> (('en', 'English'),
>>>>>  ('it', 'Italiano'),
>>>>>  ('de', 'Deutsch'),
>>>>> INTERNAL_IPS
>>>>> STATIC_URL
>>>>> '/static/'
>>>>> EMAIL_PORT
>>>>> 587
>>>>> 'location'
>>>>> USE_TZ
>>>>> False
>>>>> DEFAULT_SEARCH_SIZE
>>>>> 10
>>>>> PASSWORD_HASHERS
>>>>> ACTSTREAM_SETTINGS
>>>>> 600
>>>>> True
>>>>>  '%Y-%m-%d %H:%M',
>>>>>  '%Y-%m-%d',
>>>>>  '%m/%d/%Y %H:%M',
>>>>>  '%m/%d/%Y',
>>>>>  '%m/%d/%y %H:%M',
>>>>>  '%m/%d/%y')
>>>>> False
>>>>> DATABASE_PASSWORD
>>>>> PROFANITIES_LIST
>>>>> EMAIL_HOST_USER
>>>>> MAX_DOCUMENT_SIZE
>>>>> 10
>>>>> standard 500 page.
>>>>> On Wed, Jul 1, 2015 at 4:50 PM, Jeffy John Tomarong <
>>>>> jeffytoms at gmail.com> wrote:
>>>>>>  Restarting PostgreSQL 9.1 database server
>>>>>>           * The PostgreSQL server failed to start. Please check the log
>>>>>> output:
>>>>>> 2015-07-01 16:49:11 PHT LOG:  database system was interrupted; last
>>>>>> known up at 2015-05-27 23:25:59 PHT
>>>>>> 2015-07-01 16:49:11 PHT FATAL:  could not open file
>>>>>> "/etc/ssl/certs/ssl-cert-snakeoil.pem": Permission denied
>>>>>> 2015-07-01 16:49:11 PHT LOG:  startup process (PID 5730) exited with
>>>>>> exit code 1
>>>>>> 2015-07-01 16:49:11 PHT LOG:  aborting startup due to startup process
>>>>>> failure
>>>>>>    [fail]
>>>>>> On Wed, Jul 1, 2015 at 3:40 PM, Jeffy John Tomarong <
>>>>>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>>>>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>>>>>> logging handler: adding implicit debug-false-only filter. See
>>>>>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>>>>>   DeprecationWarning)
>>>>>>> OperationalError: could not connect to server: Connection refused
>>>>>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>>>>>> TCP/IP connections on port 5432?
>>>>>>> On Wed, Jul 1, 2015 at 3:15 PM, Jeffy John Tomarong <
>>>>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>>>>> Adding entry for local ip in
>>>>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>>>>   IP was already added to the printing whitelist.
>>>>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>>>>  * Restarting web server apache2
>>>>>>>>              apache2: Could not reliably determine the server's fully
>>>>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>>  ... waiting .apache2: Could not reliably determine the server's
>>>>>>>> fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>>      [ OK ]
>>>>>>>>   DeprecationWarning)
>>>>>>>> Traceback (most recent call last):
>>>>>>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>>>>>>     management.execute_from_command_line()
>>>>>>>>   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>>>> 453, in execute_from_command_line
>>>>>>>>     utility.execute()
>>>>>>>>   File
>>>>>>>> 392, in execute
>>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>   File
>>>>>>>> 272, in fetch_command
>>>>>>>>     klass = load_command_class(app_name, subcommand)
>>>>>>>>   File
>>>>>>>> 77, in load_command_class
>>>>>>>>     module = import_module('%s.management.commands.%s' % (app_name,
>>>>>>>> name))
>>>>>>>>   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line 35, in
>>>>>>>> import_module
>>>>>>>>     __import__(name)
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>>>>> line 23, in <module>
>>>>>>>>     from geonode.geoserver.helpers import gs_slurp
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>>>> 31, in <module>
>>>>>>>>     from geonode.utils import _user, _password, ogc_server_settings
>>>>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py",
>>>>>>>> line 36, in <module>
>>>>>>>>     from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>>>>> line 28, in <module>
>>>>>>>>     ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>>>>   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>>>>> line 71, in ugettext
>>>>>>>>     return _trans.ugettext(message)
>>>>>>>>   File
>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>>>>> line 276, in ugettext
>>>>>>>>     return do_translate(message, 'ugettext')
>>>>>>>>   File
>>>>>>>> line 258, in do_translate
>>>>>>>>     _default = translation(settings.LANGUAGE_CODE)
>>>>>>>>   File
>>>>>>>> line 172, in translation
>>>>>>>>     default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>>>>   File
>>>>>>>> line 154, in _fetch
>>>>>>>>     app = import_module(appname)
>>>>>>>>   File
>>>>>>>> import_module
>>>>>>>>     __import__(name)
>>>>>>>> ImportError: No module named relationships
>>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>>>>> pico local_settings.py
>>>>>>>> pico settings.py
>>>>>>>> pip install -e.
>>>>>>>> [sudo] password for jjqt:
>>>>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>>>>> bzr+URL
>>>>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>>>>> geonode-updateip crisp.norminet.org.ph
>>>>>>>>      [ OK ]
>>>>>>>>   DeprecationWarning)
>>>>>>>>   File
>>>>>>>>     utility.execute()
>>>>>>>>   File
>>>>>>>> 392, in execute
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>> name))
>>>>>>>>   File
>>>>>>>> import_module
>>>>>>>>     __import__(name)
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>> 31, in <module>
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>>   File
>>>>>>>> line 154, in _fetch
>>>>>>>>   File
>>>>>>>> import_module
>>>>>>>>     __import__(name)
>>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>>>>> install relationships
>>>>>>>> Downloading/unpacking relationships
>>>>>>>> Exception:
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>>>>> 126, in main
>>>>>>>>     self.run(options, args)
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>>>>> line 223, in run
>>>>>>>>     requirement_set.prepare_files(finder,
>>>>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>>>>> prepare_files
>>>>>>>>     location = req_to_install.build_location(self.build_dir, not
>>>>>>>> self.is_download)
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>>>>> build_location
>>>>>>>>     _make_build_dir(build_dir)
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>>>>> _make_build_dir
>>>>>>>>     os.makedirs(build_dir)
>>>>>>>>   File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>>>>     mkdir(name, mode)
>>>>>>>> OSError: [Errno 13] Permission denied:
>>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>>>>   File "/usr/bin/pip", line 9, in <module>
>>>>>>>>     load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>>>>   File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line
>>>>>>>> 116, in main
>>>>>>>>     return command.main(initial_args, args[1:], options)
>>>>>>>> 147, in main
>>>>>>>>     log_fp = open_logfile(log_fn, 'w')
>>>>>>>> 176, in open_logfile
>>>>>>>>     log_fp = open(filename, mode)
>>>>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>>>> On Wed, Jul 1, 2015 at 4:55 PM, Simone Dalmasso <
>>>>>> Take a look at this thread if it helps
>>>>>> https://wiki.postgresql.org/wiki/May_2015_Fsync_Permissions_Bug
>>>>>> 2015-07-01 10:52 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>>>> Hi Simone,
>>>>>>> I got this error when I restarted postgresql and it's quite
>>>>>>> persistent:
>>>>>>> output:
>>>>>>> exit code 1
>>>>>>> process failure
>>>>>>>      [fail]
>>>>>>> On Wed, Jul 1, 2015 at 4:11 PM, Simone Dalmasso <
>>>>>>>> There's no way to restore, but you can add back your db
>>>>>>>> configuration. Check whether the local_settings.py file contains the
>>>>>>>> correct db connection parameters and that postgres is up and running.
>>>>>>>> 2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com
>>>>>>>>> Nope we dont have a custom configuration. After I installed
>>>>>>>>> geonode, all I editted were on the ipaddress part or the site url. I did
>>>>>>>>> not touch the DB config in the local_settings.py ..
>>>>>>>>> Or is there a way to restore back the local_settings.py, say
>>>>>>>>> restore it back to two days ago? Because I'm afraid I might have
>>>>>>>>> overwritten the local_settings.py with the old backup file of
>>>>>>>>> local_settings.py the moment it got the internal server error..
>>>>>>>>> Thank you Simone!
>>>>>>>>> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <
>>>>>>>>>> That is because it can't connect to postgresql. Do you have some
>>>>>>>>>> kind of custom configuration?
>>>>>>>>>> That command uses /etc/geonode/local_settings.py to get the db
>>>>>>>>>> configuration
>>>>>>>>>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <
>>>>>>>>>>> Hi Simone,
>>>>>>>>>>> It did help! Thank you very much for your quick response.. I
>>>>>>>>>>> also did pip install django-request after that.
>>>>>>>>>>> However, when I issued updateip again, I got this:
>>>>>>>>>>>   DeprecationWarning)
>>>>>>>>>>> accepting
>>>>>>>>>>> Hmm.. ??
>>>>>>>>>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>>>>>>>>>>> Hi, I see you are using geonode 2.0
>>>>>>>>>>>> the missing package should be django-relationships and since
>>>>>>>>>>>> your geonode is installed systemwide you have to use sudo so:
>>>>>>>>>>>> $ sudo pip install  django-relationships
>>>>>>>>>>>> Hope this helps
>>>>>>>>>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <
>>>>>>>>>>>>> Hi Good Fellas!
>>>>>>>>>>>>> Our GeoNode instance was running well in the previous months.
>>>>>>>>>>>>> But now, it got Internal Server Error 500.
>>>>>>>>>>>>> What I did was to update the IP of geonode (which is just the
>>>>>>>>>>>>> same anyway), and it caused me this error:I also tried "pip install
>>>>>>>>>>>>> relationship" since it displayed there "Error: No Module named
>>>>>>>>>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>>>>>>>>>> running well in the last months, I do not know what happened.
>>>>>>>>>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>>>>>>>>>> Will be very much appreciated. Thank you!
>>>>>>>>>>>>> Here's the error message:
>>>>>>>>>>>>> server's fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>>>>>>>            [ OK ]
>>>>>>>>>>>>>   DeprecationWarning)
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>     utility.execute()
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> 392, in execute
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> (app_name, name))
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> import_module
>>>>>>>>>>>>>     __import__(name)
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> 31, in <module>
>>>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 36, in
>>>>>>>>>>>>> <module>
>>>>>>>>>>>>> AUTHENTICATED_USERS, ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> import_module
>>>>>>>>>>>>>     __import__(name)
>>>>>>>>>>>>> sudo pico local_settings.py
>>>>>>>>>>>>> sudo pico settings.py
>>>>>>>>>>>>> sudo pip install -e.
>>>>>>>>>>>>> or bzr+URL
>>>>>>>>>>>>> sudo geonode-updateipcrisp.norminet.org.ph
>>>>>>>>>>>>>            [ OK ]
>>>>>>>>>>>>>   DeprecationWarning)
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>     utility.execute()
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> 392, in execute
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> (app_name, name))
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> import_module
>>>>>>>>>>>>>     __import__(name)
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> 31, in <module>
>>>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> <module>
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> import_module
>>>>>>>>>>>>>     __import__(name)
>>>>>>>>>>>>> pip install relationships
>>>>>>>>>>>>> Exception:
>>>>>>>>>>>>> line 126, in main
>>>>>>>>>>>>>   File
>>>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 223, in run
>>>>>>>>>>>>> 942, in prepare_files
>>>>>>>>>>>>> not self.is_download)
>>>>>>>>>>>>> 144, in build_location
>>>>>>>>>>>>> 1185, in _make_build_dir
>>>>>>>>>>>>>     mkdir(name, mode)
>>>>>>>>>>>>> line 116, in main
>>>>>>>>>>>>> line 147, in main
>>>>>>>>>>>>> line 176, in open_logfile
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150702/65f668f8/attachment-0001.html>
More information about the geonode-users mailing list
