[GeoNode-users] osgeo module install problem
Jeffrey Johnson ortelius at gmail.com
Wed Jul 8 12:16:29 PDT 2015
I just ran into some of these same issues and the solution is in this
script I am using.
https://github.com/riskinfo-lk/riskinfo_lk2/blob/master/provision_geonode_dev.sh
On Wed, Jul 8, 2015 at 11:27 AM, Vicente <deluca.vicente at gmail.com> wrote:
> Thanks Simone, the problem was indeed the gdal library, I can't install
> from my virtualenv.
> If I run *#pip install gdal*, the error is  *#include file "cpl_port.h",
> file not found.*
> If I try to build from source (GDAL 2.0,
> https://pypi.python.org/packages/source/G/GDAL/GDAL-2.0.0.tar.gz) with
> the following command setup.py #python build_ext - include-dirs = / usr /
> include / gdal /, the error is error:* command 'x86_64-linux-gnu-gcc'
> failed with exit status 1*
> These errors gdal just happen within a virtualenv.
> Thank You!
> On Sun, Jun 7, 2015 at 4:40 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Hi, you are missing the gdal python bindings, a "pip install gdal" should
>> fix it.
>> Hope it helps, ciao
>> 2015-06-07 17:59 GMT+02:00 Vicente <deluca.vicente at gmail.com>:
>>> Good afternoon,
>>> If I run the following line from my command line, the answer is
>>> successful
>>> $ sudo apt-get -y install libgdal1h libgdal-dev python-gdal
>>> But if I run from the session virtualenv, the answer is No module named
>>> osgeo.
>>> I have just added the following session variables in my .bashrc:
>>> export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
>>> export WORKON_HOME = ~ / .venvs
>>> source /usr/local/bin/virtualenvwrapper.sh
>>> export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
>>> Both session with virtualenv or outside, the python to run is the same,
>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>> The result is that I can not run because there is paver start the osgeo
>>> module from within the session obviously.
>>> Thanks!
>>> [image: MANTA] <http://www.estudiomanta.com/>
>>> Vicente Deluca
>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150708/38f50952/attachment.html>
More information about the geonode-users mailing list
