[GeoNode-users] osgeo module install problem
Vicente deluca.vicente at gmail.com
Thu Jul 9 06:16:37 PDT 2015
You are right Paolo Corti, in my case I have gdal 1.11.2 installed by QGIS.
The following documentation is mostly right:
http://geonode.readthedocs.org/en/latest/tutorials/devel/install_devmode/gdal_install.html
Pay attention to point 3:
$ pip install --no-install GDAL==1.10.0
$ nano build/GDAL/setup.cfg
First download, not install, then edit setup.cfg to get the gdal file
configuration from the system, gdal 1.11.2 in my case.
The error in the above documentation is on how to download and install the
library, $pip install --no-download GDAL==1.10.0 just not work because I
never could locate the package downloaded by $ pip install --no-install
GDAL==1.10.0.
These were my steps to move forward:
1) In my (venv) download with wget the right gdal library
2) Edit setup.cfg like doc
3) Compile with $python setup.py build_ext --include-dirs=/usr/include/gdal
4) Move to gdal dir and run $pip install .
5) Get a fresh coffee
Saludos!
On Thu, Jul 9, 2015 at 5:29 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> For me the steps in the Jeff's script work well. although pygdal seems
> good.
> 2015-07-09 9:57 GMT+02:00 Paolo Pasquali <paolo.pasquali at ithaca.polito.it>
>> Sorry Paolo,
>> I've just seen your reply after sending my email.
>> The pip install pygdal==1.10.1 works for me so I was able to run paver
>> sync.
>> Thank you!
>> Ciao
>> P.
>> On Thu, Jul 9, 2015 at 9:43 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>> On Thu, Jul 9, 2015 at 9:34 AM, Paolo Pasquali <
>>> paolo.pasquali at ithaca.polito.it> wrote:
>>>> Hey all,
>>>> I think I am facing the same issue.
>>>> I am trying to install GeoNode on a fresh Ubuntu 14 in virtualenv but I
>>>> get the ImportError: No module named osgeo
>>>> So I've tried to pip install GDAL==1.10.0
>>>> but I get UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in
>>>> position 42: ordinal not in range(128)
>>>> and I am stuck here.
>>>> Thanks for your help!
>>> ciao Paolo
>>> if you did not customize things, Ubuntu 14 LTS comes with GDAL 1.10.1,
>>> therefore try to install pygdal 1.10.1 (there is not the corresponding
>>> package for gdal)
>>> $ yolk -V gdal
>>> GDAL 2.0.0
>>> (env)capooti at ubuntu:~/git/github$ yolk -V pygdal
>>> pygdal 1.11.2.1
>>> pygdal 1.11.1.1
>>> pygdal 1.11.0.1
>>> pygdal 1.10.1.1
>>> pygdal 1.10.0.1
>>> pygdal 1.9.2.1
>>> pygdal 1.8.1.1
>>> not sure why previous gdal versions where removed for the gdal package.
>>> cheers
>>> p
>>> [1]
>>> [2]
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
[image: MANTA] <http://www.estudiomanta.com/>
Vicente Deluca
*+54 11 6091 4579 <%2B54%2011%206091%204579>*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150709/f0b0cb4f/attachment.html>
More information about the geonode-users mailing list
