[GeoNode-users] "layers_uploadsession" does not exist
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jul 9 09:11:55 PDT 2015
Hi your error is:
Permission denied: u'/var/www/geonode/uploaded/
so a:
$ sudo chmod -R a+w /var/www/geonode/uploaded
should fix.
For the metadata and categories, they shouldn't be gone at all.
Not sure what went wrong there.
2015-07-09 16:56 GMT+02:00 Christian Willmes <
christian.willmes at googlemail.com>:
>  Hi,
> first it seemed to work fine, all layers are back and accessible, but I
> cant edit the metadata of existing layers vie the geonode webapp anymore.
> The frontend dies and gives an "Internal Server Error".
> The apache error messages look like:
> [Thu Jul 09 09:50:53.648422 2015] [:error] [pid 2080:tid 140415632357120]
> Internal Server Error: /layers/geonode:sealevels_10_150m/metadata
> [Thu Jul 09 09:50:53.648484 2015] [:error] [pid 2080:tid 140415632357120]
> Traceback (most recent call last):
> [Thu Jul 09 09:50:53.648652 2015] [:error] [pid 2080:tid 140415632357120]
> IOError: [Errno 13] Permission denied:
> u'/var/www/geonode/uploaded/thumbs/layer-d680d189-b46f-468e-8267-e8e5b497988c-thumb.png'
> [Thu Jul 09 09:50:53.664269 2015] [:error] [pid 2080:tid 140415632357120]
> [remote 134.95.150.136:14361] mod_wsgi (pid=2080): Exception occurred
> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Thu Jul 09 09:50:53.665753 2015] [:error] [pid 2080:tid 140415632357120]
> [remote 134.95.150.136:14361]   File
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Thu Jul 09 09:50:53.665849 2015] [:error] [pid 2080:tid 140415632357120]
> [remote 134.95.150.136:14361]     raise KeyError(key)
> [Thu Jul 09 09:50:53.665872 2015] [:error] [pid 2080:tid 140415632357120]
> [remote 134.95.150.136:14361] KeyError: 'request'
> It is the same account name for the superuser.
> Additionally all the Categories and Keywords are gone... (that's why I
> wanted to edit the metadata in the first place...)
> Any hint on how I can fix this?
> Thanks and regards,
> Christian
> Am 07.07.2015 um 15:49 schrieb Simone Dalmasso:
> Christian, in your case the backup preserver the old schema. Although
> since the difference in the new schema is a single column being added, you
> can use the "geonode syncdb --no-initial-data"  before loading back the
> backup. The syncdb will create the new schema and the backup should load
> leaving the new column blank. The --no-initial-data will make sure that
> syncdb only creates the schema without loading any fixture.
>  Hope this helps.
> 2015-07-07 14:48 GMT+02:00 Christian Willmes <
>> Hi,
>> following up on this thread:
>> https://github.com/GeoNode/geonode/issues/2046
>> I did the sugested steps, but the upload problem persits. No wonder,
>> because in which step should the 'layers_uploadsession' session be created?
>> The erreor inthe apache log looks like:
>> [Tue Jul 07 07:39:11.377817 2015] [:error] [pid 22673:tid
>> 139958275774208] column "context" of relation "layers_uploadsession" does
>> not exist
>> [Tue Jul 07 07:39:11.377877 2015] [:error] [pid 22673:tid
>> 139958275774208] LINE 1: ...e", "user_id", "processed", "error",
>> "traceback", "context")...
>> [Tue Jul 07 07:39:11.377884 2015] [:error] [pid 22673:tid
>> 139958275774208] ^
>> [Tue Jul 07 07:39:11.377898 2015] [:error] [pid 22673:tid
>> 139958275774208] Traceback (most recent call last):
>> [Tue Jul 07 07:39:11.377904 2015] [:error] [pid 22673:tid
>> 139958275774208]   File
>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py"
>> I did exactly the following (from
>> http://docs.geonode.org/en/master/tutorials/admin/backup/index.html):
>> sudo -u postgres -i pg_dump -c -Fc geonode > geonodedb.backup
>> sudo service apache2 stop
>> sudo /etc/init.d/tomcat7 stop
>> sudo service postgresql start
>> sudo -u postgres -i "psql -c 'drop database geonode;'"
>> sudo -u postgres -i "psql -c 'create database geonode;'"
>> sudo -u postgres -s "pg_restore -Fc -d geonode /path/to/geonodedb.backup"
>> sudo service apache2 start
>> sudo /etc/init.d/tomcat7 start
>> How can I solve this problem?
>> Best regards,
>> Christian
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150709/5322d3df/attachment-0001.html>
More information about the geonode-users mailing list
