[GeoNode-users] geonode can't retreive layers uplaoded by a deleted user
Paolo Corti pcorti at gmail.com
Mon Jul 13 02:29:52 PDT 2015
Hi
I made a test, on a fresh geonode instance.
what I did:
1. create a new user
2. upload a shapefile with the new user
3. change ownership, and contact points in the layer to a different user
now If I try to remove the user, I get the following error:
UploadSession matching query does not exist.
Definitely something wrong, though the error is different from the one you get.
I will have a deeper look and get back.
thanks for let us know
p
On Thu, Jul 9, 2015 at 1:28 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr> wrote:
> that's what I did.
> I change the owner, MD producer and PoC  before deleting the user.
> the layers last in geonode resource list but have been deleted from
> geoserver.
> in my customized geonode instance it's not a problem because  I probably
> won't delete a user if I gave him permission to add resource.
> But I tought I could' be usefull to mention it.
> Thanks again
> Le 09/07/2015 15:03, Paolo Corti a écrit :
>> If you delete a user all the related objects will be deleted, django
>> admin should have provided you with a warning of all the resources
>> that would be deleted together with the user.
>> The workflow in such a case, if you want to remove a user and keep
>> his/her layers, it is to change the ownership of the layers.
>> hope it helps
>> p
>> On Thu, Jul 9, 2015 at 12:00 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> wrote:
>>> Hello everyone
>>> In my geonode instance if I delete a user who had uploaded layers , the
>>> corresponding layers can't be retrieved by geoserver once the user has
>>> been
>>> deleted
>>> and when i go to the geoserver backend interface, all the layers from the
>>> deleted user have disapeared
>>> from GET request which usually retrive the WMS
>>> full request adress
>>> http://carto-reunion.cirad.fr/geoserver/wms?LAYERS=geonode%3Aroute_1&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer
>>> response
>>> <?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
>>> ServiceExceptionReport SYSTEM
>>> "http://carto-reunion.cirad.fr:80/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
>>> <ServiceExceptionReport version="1.1.1" >
>>>         <ServiceException code="LayerNotDefined"
>>> locator="MapLayerInfoKvpParser">
>>>                  geonode:route_1: no such layer on this server
>>>         </ServiceException>
>>> </ServiceExceptionReport>
>>> Is it a normal behavior or did I miss something ?
>>> Thanks,
>>> Hugo FERRARI
>>> Le 06/07/2015 09:33, FERRARI Hugo a écrit :
>>> I've found a temporary solution, but with a security failure...
>>> I' ve created a directory inside /var/www/geonode called notification and
>>> I
>>> gave a 777 perms on it.
>>> So everyone can write.
>>> does it mean that the user who puts the notifications locks is not
>>> www-data
>>> (ie apache) ? which user could it be ?
>>> thanks a lot ,
>>> Hugo FERRARI
>>> Le 03/07/2015 18:27, FERRARI Hugo a écrit :
>>> hello
>>>   I've got a problem trying to uplaod layers and having the notification
>>> system enabled
>>> I got this message in front end
>>> failed to create /var/www/<hostname>.MainThread-2979
>>> I read this message on the issues forum,
>>> so I put
>>>   NOTIFICATION_LOCK_LOCATION='/var/www/geonode'
>>> in the settings files
>>> even if this folder is owned by www-data user, I always get this error
>>> message, and no data has been loaded in geoserver. I only received the
>>> notification e mail which indicates that the layer have been loaded...
>>> In apache error.log I got this queue
>>> [Fri Jul 03 09:07:23.260468 2015] [:error] [pid 2979]   File
>>> "/home/ferrari/geonode/geonode/tasks/email.py" , line 21, in
>>> send_queued_notifications
>>> [Fri Jul 03 09:07:23.260473 2015] [:error] [pid 2979]
>>> send_all(settings.NOTIFICATION_LOCK_LOCATION)
>>> [Fri Jul 03 09:07:23.260478 2015] [:error] [pid 2979]   File
>>> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line 43,
>>> in
>>> send_all
>>> [Fri Jul 03 09:07:23.260483 2015] [:error] [pid 2979]     lock =
>>> acquire_lock(*args)
>>> [Fri Jul 03 09:07:23.260488 2015] [:error] [pid 2979]   File
>>> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line 31,
>>> in
>>> acquire_lock
>>> [Fri Jul 03 09:07:23.260493 2015] [:error] [pid 2979]
>>> lock.acquire(LOCK_WAIT_TIMEOUT)
>>> [Fri Jul 03 09:07:23.260497 2015] [:error] [pid 2979]   File
>>> "/usr/local/lib/python2.7/dist-packages/notification/lockfile.py", line
>>> 249,
>>> in acquire
>>> [Fri Jul 03 09:07:23.260502 2015] [:error] [pid 2979]     raise
>>> LockFailed("failed to create %s" % self.unique_name)
>>> [Fri Jul 03 09:07:23.260507 2015] [:error] [pid 2979] LockFailed: failed
>>> to
>>> create
>>> Any ideas ?
>>> thanks a lot,
>>> Hugo FERRARI
>>> Le 02/07/2015 23:00, geonode-users-request at lists.osgeo.org a écrit :
>>> Send geonode-users mailing list submissions to
>>>         geonode-users at lists.osgeo.org
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>         geonode-users-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-users digest..."
>>> Today's Topics:
>>>     1. Re: geonode_project branch migration (Alessio)
>>>     2. Re: geonode_project branch migration (Simone Dalmasso)
>>>     3. Re: GeoNode Updateip Error (No module named      relationships)
>>>        (Paolo Corti)
>>> Message: 1
>>> Date: Thu, 2 Jul 2015 12:17:57 +0200
>>> From: Alessio <alessio.dl at gmail.com>
>>> To: geonode-users at lists.osgeo.org
>>> Subject: Re: [GeoNode-users] geonode_project branch migration
>>> Message-ID:
>>> <CAHguyMtkSEw9zXuO5fdjiBDdZdZD5Pm7m=7ANa-uEaOHxdp4Eg at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi Simone,
>>> I'm testing GeoNode 2.4b25 on a virtual machine and I just created a
>>> project.
>>> I can't find local_settings.py .sample inside the folder of my project,
>>> is
>>> it fine? It contains only a settings.py file.
>>> Thanks
>>> 2015-06-30 10:47 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Dears,
>>> we just reorganized the geonode_project branches to better reflect the
>>> geonode branches setup and avoid common confusion.
>>> Now the branch master of the geonode_project correctly supports the
>>> branch
>>> master of geonode,
>>> while the branch 2.0 supports the branch 2.0.x of geonode. The branch 2.4
>>> of the geonode_project is gone.
>>> https://github.com/GeoNode/geonode-project
>>> https://github.com/GeoNode/geonode-project/tree/2.0
>>> Hope this makes things easier.
>>> The geonode dev team
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
