[GeoNode-users] geonode can't retreive layers uplaoded by a deleted user
Paolo Corti pcorti at gmail.com
Mon Jul 13 04:25:02 PDT 2015
Done, and working on it:
https://github.com/GeoNode/geonode/issues/2222
cheers
p
On Mon, Jul 13, 2015 at 11:59 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Hi I tested on demo and can confirm the Hugo error. Need to fix that. Let's
> open a ticket.
> 2015-07-13 11:29 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Hi
>> I made a test, on a fresh geonode instance.
>> what I did:
>> 1. create a new user
>> 2. upload a shapefile with the new user
>> 3. change ownership, and contact points in the layer to a different user
>> now If I try to remove the user, I get the following error:
>> UploadSession matching query does not exist.
>> Definitely something wrong, though the error is different from the one you
>> get.
>> I will have a deeper look and get back.
>> thanks for let us know
>> p
>> On Thu, Jul 9, 2015 at 1:28 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> wrote:
>> > that's what I did.
>> > I change the owner, MD producer and PoC  before deleting the user.
>> > the layers last in geonode resource list but have been deleted from
>> > geoserver.
>> > in my customized geonode instance it's not a problem because  I probably
>> > won't delete a user if I gave him permission to add resource.
>> > But I tought I could' be usefull to mention it.
>> > Thanks again
>> > Le 09/07/2015 15:03, Paolo Corti a écrit :
>> >> If you delete a user all the related objects will be deleted, django
>> >> admin should have provided you with a warning of all the resources
>> >> that would be deleted together with the user.
>> >> The workflow in such a case, if you want to remove a user and keep
>> >> his/her layers, it is to change the ownership of the layers.
>> >> hope it helps
>> >> p
>> >> On Thu, Jul 9, 2015 at 12:00 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> >> wrote:
>> >>> Hello everyone
>> >>> In my geonode instance if I delete a user who had uploaded layers ,
>> >>> the
>> >>> corresponding layers can't be retrieved by geoserver once the user has
>> >>> been
>> >>> deleted
>> >>> and when i go to the geoserver backend interface, all the layers from
>> >>> the
>> >>> deleted user have disapeared
>> >>> from GET request which usually retrive the WMS
>> >>> full request adress
>> >>> http://carto-reunion.cirad.fr/geoserver/wms?LAYERS=geonode%3Aroute_1&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer
>> >>> response
>> >>> <?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
>> >>> ServiceExceptionReport SYSTEM
>> >>> "http://carto-reunion.cirad.fr:80/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
>> >>> <ServiceExceptionReport version="1.1.1" >
>> >>>         <ServiceException code="LayerNotDefined"
>> >>> locator="MapLayerInfoKvpParser">
>> >>>                  geonode:route_1: no such layer on this server
>> >>>         </ServiceException>
>> >>> </ServiceExceptionReport>
>> >>> Is it a normal behavior or did I miss something ?
>> >>> Thanks,
>> >>> Hugo FERRARI
>> >>> Le 06/07/2015 09:33, FERRARI Hugo a écrit :
>> >>> I've found a temporary solution, but with a security failure...
>> >>> I' ve created a directory inside /var/www/geonode called notification
>> >>> and
>> >>> I
>> >>> gave a 777 perms on it.
>> >>> So everyone can write.
>> >>> does it mean that the user who puts the notifications locks is not
>> >>> www-data
>> >>> (ie apache) ? which user could it be ?
>> >>> thanks a lot ,
>> >>> Hugo FERRARI
>> >>> Le 03/07/2015 18:27, FERRARI Hugo a écrit :
>> >>> hello
>> >>>   I've got a problem trying to uplaod layers and having the
>> >>> notification
>> >>> system enabled
>> >>> I got this message in front end
>> >>> failed to create /var/www/<hostname>.MainThread-2979
>> >>> I read this message on the issues forum,
>> >>> so I put
>> >>>   NOTIFICATION_LOCK_LOCATION='/var/www/geonode'
>> >>> in the settings files
>> >>> even if this folder is owned by www-data user, I always get this error
>> >>> message, and no data has been loaded in geoserver. I only received the
>> >>> notification e mail which indicates that the layer have been loaded...
>> >>> In apache error.log I got this queue
>> >>> [Fri Jul 03 09:07:23.260468 2015] [:error] [pid 2979]   File
>> >>> "/home/ferrari/geonode/geonode/tasks/email.py" , line 21, in
>> >>> send_queued_notifications
>> >>> [Fri Jul 03 09:07:23.260473 2015] [:error] [pid 2979]
>> >>> send_all(settings.NOTIFICATION_LOCK_LOCATION)
>> >>> [Fri Jul 03 09:07:23.260478 2015] [:error] [pid 2979]   File
>> >>> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line
>> >>> 43,
>> >>> in
>> >>> send_all
>> >>> [Fri Jul 03 09:07:23.260483 2015] [:error] [pid 2979]     lock =
>> >>> acquire_lock(*args)
>> >>> [Fri Jul 03 09:07:23.260488 2015] [:error] [pid 2979]   File
>> >>> 31,
>> >>> in
>> >>> acquire_lock
>> >>> [Fri Jul 03 09:07:23.260493 2015] [:error] [pid 2979]
>> >>> lock.acquire(LOCK_WAIT_TIMEOUT)
>> >>> [Fri Jul 03 09:07:23.260497 2015] [:error] [pid 2979]   File
>> >>> "/usr/local/lib/python2.7/dist-packages/notification/lockfile.py",
>> >>> line
>> >>> 249,
>> >>> in acquire
>> >>> [Fri Jul 03 09:07:23.260502 2015] [:error] [pid 2979]     raise
>> >>> LockFailed("failed to create %s" % self.unique_name)
>> >>> [Fri Jul 03 09:07:23.260507 2015] [:error] [pid 2979] LockFailed:
>> >>> failed
>> >>> to
>> >>> create
>> >>> Any ideas ?
>> >>> thanks a lot,
>> >>> Hugo FERRARI
>> >>> Le 02/07/2015 23:00, geonode-users-request at lists.osgeo.org a écrit :
>> >>> Send geonode-users mailing list submissions to
>> >>>         geonode-users at lists.osgeo.org
>> >>> To subscribe or unsubscribe via the World Wide Web, visit
>> >>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> >>> or, via email, send a message with subject or body 'help' to
>> >>> You can reach the person managing the list at
>> >>>         geonode-users-owner at lists.osgeo.org
>> >>> When replying, please edit your Subject line so it is more specific
>> >>> than "Re: Contents of geonode-users digest..."
>> >>> Today's Topics:
>> >>>     1. Re: geonode_project branch migration (Alessio)
>> >>>     2. Re: geonode_project branch migration (Simone Dalmasso)
>> >>>     3. Re: GeoNode Updateip Error (No module named      relationships)
>> >>>        (Paolo Corti)
>> >>> Message: 1
>> >>> Date: Thu, 2 Jul 2015 12:17:57 +0200
>> >>> From: Alessio <alessio.dl at gmail.com>
>> >>> To: geonode-users at lists.osgeo.org
>> >>> Subject: Re: [GeoNode-users] geonode_project branch migration
>> >>> Message-ID:
>> >>> <CAHguyMtkSEw9zXuO5fdjiBDdZdZD5Pm7m=7ANa-uEaOHxdp4Eg at mail.gmail.com>
>> >>> Content-Type: text/plain; charset="utf-8"
>> >>> Hi Simone,
>> >>> I'm testing GeoNode 2.4b25 on a virtual machine and I just created a
>> >>> project.
>> >>> I can't find local_settings.py .sample inside the folder of my
>> >>> project,
>> >>> is
>> >>> it fine? It contains only a settings.py file.
>> >>> Thanks
>> >>> 2015-06-30 10:47 GMT+02:00 Simone Dalmasso
>> >>> <simone.dalmasso at gmail.com>:
>> >>> Dears,
>> >>> we just reorganized the geonode_project branches to better reflect the
>> >>> geonode branches setup and avoid common confusion.
>> >>> Now the branch master of the geonode_project correctly supports the
>> >>> branch
>> >>> master of geonode,
>> >>> while the branch 2.0 supports the branch 2.0.x of geonode. The branch
>> >>> 2.4
>> >>> of the geonode_project is gone.
>> >>> https://github.com/GeoNode/geonode-project
>> >>> https://github.com/GeoNode/geonode-project/tree/2.0
>> >>> Hope this makes things easier.
>> >>> The geonode dev team
>> >>> _______________________________________________
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
