[GeoNode-users] Import shape file to server
Jeffrey Johnson ortelius at gmail.com
Thu Jul 30 13:57:20 PDT 2015
This is really a postgres/postgis question, but it looks you need to
enable the postgis extension in your database. Try this in the sql
console in pgadmin3 while connected to your database.
create extension postgis;
On Thu, Jul 30, 2015 at 1:54 PM, GGC Garcia <gacoge at gmail.com> wrote:
> Hello I have a problem when I try to import one shape file to server with
> pgAdmin3.
> I hope you can help me please.
> This is the message when I do this.
> ______________________________________________________________
> Connecting:  host=192.68.1.1 port=5432 user=root password='************'
> dbname=exampletable
> Importing with configuration: limite_estatal, public, geom,
> C:\Users\Joan\Desktop\DESK\shapes\limite_estatal.shp, mode=c, dump=1,
> simple=0, geography=0, index=1, shape=1, srid=0
> Shapefile type: Arc
> PostGIS type: MULTILINESTRING[2]
> Failed SQL begins: "SET CLIENT_ENCODING TO UTF8;
> SET STANDARD_CONFORMING_STRINGS TO ON;
> BEGIN;
> CREATE TABLE "public"."limite_estatal" (gid serial,
> "left_fid" int4,
> "right_fid" int4);
> ALTER TABLE "public"."limite_estatal" ADD PRIMARY KEY (gid);
> SELECT AddGeometryColumn('publi"
> Failed in pgui_exec(): ERROR:  AddGeometryColumns() - invalid SRID
> CONTEXT:  SQL statement "SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6)"
> PL/pgSQL function "addgeometrycolumn" line 5 at SQL statement
> Shapefile import failed.
> Regards
> Gerardo
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
