[GeoNode-users] osgeo module install problem
Vicente deluca.vicente at gmail.com
Sun Jun 7 08:59:50 PDT 2015
Good afternoon,
If I run the following line from my command line, the answer is successful
$ sudo apt-get -y install libgdal1h libgdal-dev python-gdal
But if I run from the session virtualenv, the answer is No module named
osgeo.
I have just added the following session variables in my .bashrc:
export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
export WORKON_HOME = ~ / .venvs
source /usr/local/bin/virtualenvwrapper.sh
export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
Both session with virtualenv or outside, the python to run is the same,
Python 2.7.6 (default, Mar 22 2014, 22:59:56)
The result is that I can not run because there is paver start the osgeo
module from within the session obviously.
Thanks!
[image: MANTA] <http://www.estudiomanta.com/>
Vicente Deluca
*+54 11 6091 4579 <%2B54%2011%206091%204579>*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150607/6afa1f0c/attachment.html>
More information about the geonode-users mailing list
