[GeoNode-users] osgeo module install problem
Simone Dalmasso simone.dalmasso at gmail.com
Sun Jun 7 12:40:13 PDT 2015
Hi, you are missing the gdal python bindings, a "pip install gdal" should
fix it.
Hope it helps, ciao
2015-06-07 17:59 GMT+02:00 Vicente <deluca.vicente at gmail.com>:
> Good afternoon,
> If I run the following line from my command line, the answer is successful
> $ sudo apt-get -y install libgdal1h libgdal-dev python-gdal
> But if I run from the session virtualenv, the answer is No module named
> osgeo.
> I have just added the following session variables in my .bashrc:
> export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
> export WORKON_HOME = ~ / .venvs
> source /usr/local/bin/virtualenvwrapper.sh
> export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
> Both session with virtualenv or outside, the python to run is the same,
> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
> The result is that I can not run because there is paver start the osgeo
> module from within the session obviously.
> Thanks!
> [image: MANTA] <http://www.estudiomanta.com/>
> Vicente Deluca
> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150607/91bbf000/attachment.html>
More information about the geonode-users mailing list
