[GeoNode-users] Select/Filter remote services' layers
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jun 10 06:24:18 PDT 2015
Hi Alessandro, good points. I don't think that is possible to import a
subset of the layers nor set the permissions in advance.
As a workaround delete layers you could use the admin panel, while for the
permissions you can change the GeoNode default permissions from settings
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L413 before
importing them or change them in bulk from the layer list page (select all
of them and use the set permissions widget).
Anyway I think it would be good to have a ticket for the services layers
subset. Could you open it?
2015-06-10 15:10 GMT+02:00 Alessandro Sarretta <
alessandro.sarretta at gmail.com>:
>  Dear all,
> I'm testing the use of remote services with GeoNode 2.4.
> I'm testing it with some WMS services serving hundreds of layers, and I'd
> like to register in geonode only some of those.
> Is it possible, before or during the registration phase, to select which
> layer to register from a specific service? I've seen that after the
> registration the layers from the registered service can be deleted one by
> one, but this could be a long and tricky issue...
> In addition to that, when I register the service, the layers appear to be
> visible to everyone (and I think this depends from the default
> permissions): is it possible (from the web interface) to set the default
> permissions for the registered layer in advance (i.e. during the
> registration process?).
> Thank you,
> Ale
> Alessandro Sarretta
> skype/twitter: alesarrett
> Web: ilsarrett.wordpress.com
> Research information:
>    - Google scholar profile
>    <http://scholar.google.it/citations?user=IsyXargAAAAJ&hl=it>
>    - ORCID <http://orcid.org/0000-0002-1475-8686>
>    - Research Gate
>    <https://www.researchgate.net/profile/Alessandro_Sarretta>
>    - <https://impactstory.org/AlessandroSarretta>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150610/e345a73f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150610/e345a73f/attachment-0001.png>
More information about the geonode-users mailing list
