[GeoNode-users] Select/Filter remote services' layers
Alessandro Sarretta alessandro.sarretta at gmail.com
Thu Jun 11 14:39:29 PDT 2015
Yes, you're right, and in particular this issue refers to the selection
of layers: https://github.com/GeoNode/geonode/issues/2055
Thanks.
Ale
On 10/06/2015 20:39, GC-54 wrote:
> This is already a component of a broader ticket:
> https://github.com/GeoNode/geonode/issues/2064
> On Wednesday, June 10, 2015, Paolo Corti <pcorti at gmail.com
> <mailto:pcorti at gmail.com>> wrote:
>     Hi
>     I need this feature as well and I should be implementing it
>     sometime soon in the next few weeks - if it will not be there
>     already at the time :)
>     cheers
>     p
>     On Wed, Jun 10, 2015 at 3:24 PM, Simone Dalmasso
>     <simone.dalmasso at gmail.com
>     <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> wrote:
>         Hi Alessandro, good points. I don't think that is possible to
>         import a subset of the layers nor set the permissions in advance.
>         As a workaround delete layers you could use the admin panel,
>         while for the permissions you can change the GeoNode default
>         permissions from settings
>         https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L413 before
>         importing them or change them in bulk from the layer list page
>         (select all of them and use the set permissions widget).
>         Anyway I think it would be good to have a ticket for the
>         services layers subset. Could you open it?
>         2015-06-10 15:10 GMT+02:00 Alessandro Sarretta
>         <alessandro.sarretta at gmail.com
>         <javascript:_e(%7B%7D,'cvml','alessandro.sarretta at gmail.com');>>:
>             Dear all,
>             I'm testing the use of remote services with GeoNode 2.4.
>             I'm testing it with some WMS services serving hundreds of
>             layers, and I'd like to register in geonode only some of
>             those.
>             Is it possible, before or during the registration phase,
>             to select which layer to register from a specific service?
>             I've seen that after the registration the layers from the
>             registered service can be deleted one by one, but this
>             could be a long and tricky issue...
>             In addition to that, when I register the service, the
>             layers appear to be visible to everyone (and I think this
>             depends from the default permissions): is it possible
>             (from the web interface) to set the default permissions
>             for the registered layer in advance (i.e. during the
>             registration process?).
>             Thank you,
>             Ale
>             Alessandro Sarretta
>             skype/twitter: alesarrett
>             Web: ilsarrett.wordpress.com <http://ilsarrett.wordpress.com>
>             Research information:
>               * Google scholar profile
>                 <http://scholar.google.it/citations?user=IsyXargAAAAJ&hl=it>
>               * ORCID <http://orcid.org/0000-0002-1475-8686>
>               * Research Gate
>                 <https://www.researchgate.net/profile/Alessandro_Sarretta>
>               * <https://impactstory.org/AlessandroSarretta>
>             _______________________________________________
>             geonode-users mailing list
>             geonode-users at lists.osgeo.org
>             <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>         Simone
>     Paolo Corti
>     Geospatial software developer
>     web: http://www.paolocorti.net
>     twitter: @capooti
>     skype: capooti
Alessandro Sarretta
  * Research Gate <https://www.researchgate.net/profile/Alessandro_Sarretta>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150611/e84d7acc/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150611/e84d7acc/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150611/e84d7acc/attachment-0003.png>
More information about the geonode-users mailing list
