[GeoNode-users] Restrict the add_layer auth to some user
FERRARI Hugo ferrari_hugo at yahoo.fr
Wed Jun 17 01:13:15 PDT 2015
> Ok, maybe I found a simpler way to do what i want.
> there is an "add resource base" in the auth list from the auth group
> admin menu.
> I can check if the current logged user belongs to a group which has
> this auth, with a custom tag which takes the context as parameter.
> If it is true, from the template I display the "add
> layer/map/document". it is not, i don't display anything (or just
> "explore" from index.html).
> the fact is coding some small modification like that doesn't need a
> Pull Request. Am I right ?
> Thanks again.
> Le 17/06/2015 10:07, Simone Dalmasso a écrit :
>> Yes you have to implement the add_layer permission.
>> The ath user has been swapper with people profile in Geonode. And
>> group only work behind the scenes what is called group in Geonode is
>> actually the groupProfile
>> Il mercoledì 17 giugno 2015, FERRARI Hugo <ferrari_hugo at yahoo.fr
>> <mailto:ferrari_hugo at yahoo.fr>> ha scritto:
>>     That's what I thought, but not giving the add_layer auth to a
>>     group  doesn't affect the group members.
>>     So first  Do I have to make it work for a single member?
>>     On the same topic , usually django admin backend has a auth user
>>     menu. It vanished in my geonode installation, there is only the
>>     group auth menu.
>>     Is it the expected behavior ?
>>     Thanks a lot.
>>     Le 16/06/2015 18:26, Simone Dalmasso a écrit :
>>>     Hi Hugo,
>>>     well this permission is not implemented in GeoNode, you will
>>>     need to hack a bit into it and implement checks for it on the
>>>     layer upload views and add its support in the client. The
>>>     permission itself can then be granted to a group.
>>>     2015-06-16 16:13 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr
>>>     <javascript:_e(%7B%7D,'cvml','ferrari_hugo at yahoo.fr');>>:
>>>         Hello world,
>>>         in Geonode there are permissions on resources and we can
>>>         modify them.
>>>         But is there any way to restrict actions for some users ?
>>>         I want only few users to be allowed to add new layers in
>>>         geonode but apparently the only existing criteria to permit
>>>         is authentication.
>>>         I'm sure i'm not the first to ask this question.
>>>         In auth_permission postgres table we can see that the
>>>         "add_layer" permision already exists but it is not affected
>>>         to users.
>>>         Thanks for your advices
>>>         Hugo FERRARI
>>>         Le 09/06/2015 18:50, geonode-users-request at lists.osgeo.org
>>>         <javascript:_e(%7B%7D,'cvml','geonode-users-request at lists.osgeo.org');>
>>>         a écrit :
>>>             Send geonode-users mailing list submissions to
>>>             geonode-users at lists.osgeo.org
>>>             <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>>             To subscribe or unsubscribe via the World Wide Web, visit
>>>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>             or, via email, send a message with subject or body 'help' to
>>>             You can reach the person managing the list at
>>>             geonode-users-owner at lists.osgeo.org
>>>             <javascript:_e(%7B%7D,'cvml','geonode-users-owner at lists.osgeo.org');>
>>>             When replying, please edit your Subject line so it is
>>>             more specific
>>>             than "Re: Contents of geonode-users digest..."
>>>             Today's Topics:
>>>                 1. developpement: Modifying permission behavior and data
>>>                    visibility in Geonode (FERRARI Hugo)
>>>                 2. Re: developpement: Modifying permission behavior
>>>             and data
>>>                    visibility in Geonode (Ariel Nunez)
>>>                 3. Re: developpement: Modifying permission behavior
>>>             and data
>>>                    visibility in Geonode (Paolo Corti)
>>>             Message: 1
>>>             Date: Tue, 09 Jun 2015 16:56:18 +0400
>>>             From: FERRARI Hugo <ferrari_hugo at yahoo.fr
>>>             To: geonode-users at lists.osgeo.org
>>>             Subject: [GeoNode-users] developpement: Modifying
>>>             permission behavior
>>>                     and data visibility in Geonode
>>>             Message-ID: <5576E272.6090606 at yahoo.fr
>>>             <javascript:_e(%7B%7D,'cvml','5576E272.6090606 at yahoo.fr');>>
>>>             Content-Type: text/plain; charset=windows-1252;
>>>             format=flowed
>>>             Hello everyone,
>>>             I have installed a complete geonode instance on a
>>>             developpement server.
>>>             I want  to change thebehaviorofthesoftware  to make it
>>>             fit the need of
>>>             the institution I work for.
>>>             So i'm looking for some advices because  I didn't manage
>>>             to code it yet.
>>>             My aim to separate metada access from the data access.
>>>             That  is to make all the layers uploaded in geoserver
>>>             VISIBLE for all
>>>             users (logged or not) but only in the layer-list page ,
>>>             not on the
>>>             layer-detail page .
>>>             If you click on any specific layer in the layer-list (or
>>>             document-list
>>>             because i want the same behavior for both), you get the
>>>             layer detail so
>>>             you what will see is:
>>>             - In the case you have the view_resourcebase permission
>>>             (who can see it
>>>             ?), you will see the current template corresponding to
>>>             layer_detail.html: both access to datas and metadatas.
>>>             - In the other case if you don't have the
>>>             view_resourcebase permission,
>>>             you 'll only have access to metadatas's ressource (that
>>>             means a template
>>>             similar to layer_detail.html but Instead of the
>>>             geoexplorer frame you
>>>             sould have a "permission denied" message, but the
>>>             possibility to
>>>             retrieve metadata).
>>>             It's quite simple to make all the layers visible in the
>>>             layer list,
>>>             whoever is logged in (you just have to modify
>>>             SKIP_PERMS_FILTERS in
>>>             settings.py AND read_list function in module
>>>             api/authorisation.py).
>>>             but the actual behavior is to catch a 403 http error
>>>             when trying to view
>>>             the layer detail.
>>>             Modifying the 403.html template does not seems to be the
>>>             good way to
>>>             process.
>>>             I don't think it is necessary to modify geonode's
>>>             database model because
>>>             the view_ressource permission  is enough, considering
>>>             that  viewing the
>>>             ressource is equivalent to having access to the data
>>>             (even if you can't
>>>             download it). There's no need to add a new kind of
>>>             permissions, as far
>>>             as I can guess.
>>>             What is prefered is not throwing a 403 error but just the
>>>             layer_detail.html template modified to get only metadatas.
>>>             I hope the explanation was clear enough,
>>>             Hugo FERRARI
>>>             PS
>>>             Does it correspond to the actual geonode developpement
>>>             policy ?
>>>             Datas and metada are strongly linked in this software.
>>>             Could this functionnality be interresting for any other
>>>             geonode users?
>>>             Le 08/06/2015 23:00,
>>>             a ?crit :
>>>                 visit
>>>                 'help' to
>>>                 is more specific
>>>                 Today's Topics:
>>>                      1. Re: osgeo module install problem (Simone
>>>                 Dalmasso)
>>>                      2. Problems to Translate Geonode - Transifex -
>>>                    Portuguese
>>>                         (Brazil) (Davi Custodio)
>>>                      3. Re: Problems to Translate Geonode -
>>>                 Transifex - Portuguese
>>>                         (Brazil) (Julien Collaer)
>>>                 Message: 1
>>>                 Date: Sun, 7 Jun 2015 21:40:13 +0200
>>>                 From: Simone Dalmasso <simone.dalmasso at gmail.com
>>>                 <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>>
>>>                 To: Vicente <deluca.vicente at gmail.com
>>>                 <javascript:_e(%7B%7D,'cvml','deluca.vicente at gmail.com');>>
>>>                 Cc: geonode-users <geonode-users at lists.osgeo.org
>>>                 <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>>
>>>                 Subject: Re: [GeoNode-users] osgeo module install
>>>                 problem
>>>                 Message-ID:
>>>                 <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=ZCsTzSUSx5ymVvA at mail.gmail.com
>>>                 <javascript:_e(%7B%7D,'cvml','ZCsTzSUSx5ymVvA at mail.gmail.com');>>
>>>                 Content-Type: text/plain; charset="utf-8"
>>>                 Hi, you are missing the gdal python bindings, a "pip
>>>                 install gdal" should
>>>                 fix it.
>>>                 Hope it helps, ciao
>>>                 2015-06-07 17:59 GMT+02:00 Vicente
>>>                 <javascript:_e(%7B%7D,'cvml','deluca.vicente at gmail.com');>>:
>>>                     Good afternoon,
>>>                     If I run the following line from my command
>>>                     line, the answer is successful
>>>                     $ sudo apt-get -y install libgdal1h libgdal-dev
>>>                     python-gdal
>>>                     But if I run from the session virtualenv, the
>>>                     answer is No module named
>>>                     osgeo.
>>>                     I have just added the following session
>>>                     variables in my .bashrc:
>>>                     export VIRTUALENVWRAPPER_PYTHON = / usr / bin /
>>>                     python
>>>                     export WORKON_HOME = ~ / .venvs
>>>                     source /usr/local/bin/virtualenvwrapper.sh
>>>                     export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
>>>                     Both session with virtualenv or outside, the
>>>                     python to run is the same,
>>>                     Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>>                     The result is that I can not run because there
>>>                     is paver start the osgeo
>>>                     module from within the session obviously.
>>>                     Thanks!
>>>                     [image: MANTA] <http://www.estudiomanta.com/>
>>>                     Vicente Deluca
>>>                     *+54 11 6091 4579 <tel:%2B54%2011%206091%204579>
>>>                     <%2B54%2011%206091%204579>*
>>>                     _______________________________________________
>>>             Message: 2
>>>             Date: Tue, 9 Jun 2015 09:01:34 -0500
>>>             From: Ariel Nunez <ingenieroariel at gmail.com
>>>             <javascript:_e(%7B%7D,'cvml','ingenieroariel at gmail.com');>>
>>>             To: FERRARI Hugo <ferrari_hugo at yahoo.fr
>>>             Cc: "geonode-users at lists.osgeo.org
>>>             <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>"
>>>             Subject: Re: [GeoNode-users] developpement: Modifying
>>>             permission
>>>                     behavior and data visibility in Geonode
>>>             Message-ID:
>>>             <CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com
>>>             <javascript:_e(%7B%7D,'cvml','CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com');>>
>>>             Hugo,
>>>             Based on what I understand, the best path forward is to
>>>             have a
>>>             view_metadata permission that you use to enforce the
>>>             behavior you want.
>>>             Assigning a new meaning to the existing permission may
>>>             be problematic for
>>>             other users with different needs (for example where
>>>             metadata is sensitive
>>>             information).
>>>             The place where we want to get to, is to allow uploaders
>>>             to restrict any
>>>             actions they want, but give the end user buttons to
>>>             request permissions (to
>>>             view if they cannot view, to download if they can only
>>>             view, to edit if the
>>>             can only download) to encourage a conversation between
>>>             uploaders and users
>>>             and provide a workflow to allow access to information
>>>             when it is needed.
>>>             The changes you make would be good candidates for
>>>             inclusion in the main
>>>             version of GeoNode so others can benefit in the future.
>>>             Hopefully others
>>>             (Paolo?) can chime in with more specific feedback.
>>>             Best,
>>>             Ariel.
>>>             On Tue, Jun 9, 2015 at 7:56 AM, FERRARI Hugo
>>>             wrote:
>>>                 Hello everyone,
>>>                 it fit the need of the
>>>                 manage to code it yet.
>>>                 geoserver VISIBLE for all
>>>                 page , not on the
>>>                 layer-detail page .
>>>                 (or document-list
>>>                 the layer detail so you
>>>                 what will see is:
>>>                 permission (who can see it
>>>                 to layer_detail.html:
>>>                 (that means a template
>>>                 geoexplorer frame you sould
>>>                 possibility to retrieve
>>>                 metadata).
>>>                 the layer list,
>>>                 when trying to view
>>>                 the layer detail.
>>>                 the good way to
>>>                 process.
>>>                 considering that  viewing the
>>>                 (even if you can't
>>>                 permissions, as far as I
>>>                 can guess.
>>>                 just the
>>>                 metadatas.
>>>                 Hugo FERRARI
>>>                 PS
>>>                 developpement policy ?
>>>                 other geonode users?
>>>                 a ?crit :
>>>                     Web, visit
>>>                     body 'help' to
>>>                     it is more specific
>>>                     Today's Topics:
>>>                     Dalmasso)
>>>                     Message: 1
>>>                     install problem
>>>                     Message-ID:
>>>                     "pip install gdal" should
>>>                     fix it.
>>>                     Hope it helps, ciao
>>>                       Good afternoon,
>>>                         line, the answer is
>>>                         successful
>>>                         libgdal-dev python-gdal
>>>                         the answer is No module named
>>>                         osgeo.
>>>                         bin / python
>>>                         .pip-downloads
>>>                         there is paver start the osgeo
>>>                         Thanks!
>>>                         Vicente Deluca
>>>                         *+54 11 6091 4579
>>>             -------------- next part --------------
>>>             An HTML attachment was scrubbed...
>>>             URL:
>>>             <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150609/4dbe42d3/attachment-0001.html>
>>>             Message: 3
>>>             Date: Tue, 9 Jun 2015 16:50:01 +0200
>>>             From: Paolo Corti <pcorti at gmail.com
>>>             <javascript:_e(%7B%7D,'cvml','pcorti at gmail.com');>>
>>>             To: Ariel Nunez <ingenieroariel at gmail.com
>>>             Cc: FERRARI Hugo <ferrari_hugo at yahoo.fr
>>>             <javascript:_e(%7B%7D,'cvml','ferrari_hugo at yahoo.fr');>>,
>>>             permission
>>>             Message-ID:
>>>             <CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com
>>>             <javascript:_e(%7B%7D,'cvml','CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com');>>
>>>             Content-Type: text/plain; charset=UTF-8
>>>             Yes, Ariel is totally right.
>>>             Currently we don't have a specific permission for
>>>             viewing metadata.
>>>             This is implicit with the view_resourcebase permission
>>>             that gives
>>>             access to the data and metadata at the same time.
>>>             As suggested by Ariel you may consider to add a new
>>>             django guardian
>>>             permission at the resource base model, like it has been
>>>             done here [1]
>>>             and then have your GeoNode instance behaved according to
>>>             it in views,
>>>             templates and javascript.
>>>             I don't think there is an easy way to avoid forking
>>>             GeoNode and
>>>             customize the beahviour in your GeoNode project, though
>>>             it may be not
>>>             impossible and this would keep your instance easily
>>>             updateable with
>>>             mainstream code.
>>>             Even better, as Ariel suggested, you may though fork it
>>>             and send a PR
>>>             as it could be useful for others as well.
>>>             regards
>>>             p
>>>             [1]
>>>             https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L648
>>>             On Tue, Jun 9, 2015 at 4:01 PM, Ariel Nunez
>>>             wrote:
>>>                 Hugo,
>>>                 to have a view_metadata
>>>                 permission that you use to enforce the behavior you
>>>                 want. Assigning a new
>>>                 meaning to the existing permission may be
>>>                 problematic for other users with
>>>                 different needs (for example where metadata is
>>>                 sensitive information).
>>>                 uploaders to restrict any
>>>                 only view, to edit if the
>>>                 between uploaders and users
>>>                 information when it is needed.
>>>                 future. Hopefully others
>>>                 Best,
>>>                 Ariel.
>>>                 wrote:
>>>                     Hello everyone,
>>>                     a developpement server.
>>>                     make it fit the need of the
>>>                     didn't manage to code it yet.
>>>                     access.
>>>                     page , not on the
>>>                     layer-detail page .
>>>                     layer-list (or document-list
>>>                     get the layer detail so you
>>>                     what will see is:
>>>                     corresponding to layer_detail.html:
>>>                     ressource (that means a template
>>>                     metadata).
>>>                     in the layer list,
>>>                     error when trying to view
>>>                     the layer detail.
>>>                     to be the good way to
>>>                     process.
>>>                     geonode's database model because
>>>                     data (even if you can't
>>>                     of permissions, as far as I
>>>                     can guess.
>>>                     just the
>>>                     metadatas.
>>>                     Hugo FERRARI
>>>                     PS
>>>                     software.
>>>                     any other geonode users?
>>>                     a ?crit :
>>>                         Wide Web, visit
>>>                         or body 'help' to
>>>                         so it is more specific
>>>                         Today's Topics:
>>>                         (Simone Dalmasso)
>>>                         Message: 1
>>>                         Cc: geonode-users
>>>                         install problem
>>>                         Message-ID:
>>>                         bindings, a "pip install gdal" should
>>>                         fix it.
>>>                         Hope it helps, ciao
>>>                             Good afternoon,
>>>                             command line, the answer is
>>>                             successful
>>>                             virtualenv, the answer is No module named
>>>                             osgeo.
>>>                             / bin / python
>>>                             .pip-downloads
>>>                             the python to run is the same,
>>>                             22:59:56)
>>>                             Thanks!
>>>                             [image: MANTA]
>>>                             Vicente Deluca
>>>                             *+54 11 6091 4579
>>>     Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/03d387fd/attachment-0001.html>
More information about the geonode-users mailing list
