[GeoNode-users] Cannot find /var/lib/geonode/ to get templates
William Francis william.francis.james at gmail.com
Thu Jun 18 05:46:57 PDT 2015
Also after finding the base template files I needed to copy them to this
/var/www/geonode/static/geonode/css
On Thu, Jun 18, 2015 at 6:29 PM, William Francis <
william.francis.james at gmail.com> wrote:
> Thank you GC-45
> Yes, that helps.
> The geonode is already deployed. I am following the documentation for
> Customizing the look and feel of the Geonode
> https://geonode.readthedocs.org/en/1.2/deploy/customize.html
> On Thu, Jun 18, 2015 at 4:21 AM, GC-54 <nepanode at gmail.com> wrote:
>> First things first - when making reference to documentation please
>> provide a link to where you encountered this as there is a developers
>> customization and admin customization depending on how you've deployed
>> geonode...
>> Second tip is to use these linux commands when looking for a file or
>> directory:
>> $ sudo updatedb
>> $ sudo locate {name} | less
>> *Those two lines will usually do the trick if your looking for a specific
>> file or directory just replace {name} with whatever file/dir/path your
>> looking for...
>> *But for what you're looking for the directory geonode is deployed her*e:
>> /usr/local/lib/python2.7/dist-packages/geonode/templates/
>> ?Did you already setup your geonode=project within a virtualenvironment?
>> On Wed, Jun 17, 2015 at 8:54 AM, William Francis <
>>> Hello,
>>> I am following the Customizing the geonode instructions and looking for
>>> the template files to copy to etc/geonode/templates
>>> e.g.
>>> /var/lib/geonode/src/GeoNodePy/geonode/templates/index.html
>>> However the directory  /var/lib/geonode/ doesn't exist.
>>> Where can I find a copy of these templates?
>>> I am using v*ersion 2.4b25*  of geonode.
>>> Thank you.
>>> Will
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150618/dffbc3c7/attachment.html>
More information about the geonode-users mailing list
