[GeoNode-users] Cannot find /var/lib/geonode/ to get templates
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jun 18 06:00:38 PDT 2015
Hi William, consider using the geonode-project to customize your GeoNode.
https://github.com/GeoNode/geonode-project/tree/2.4
2015-06-18 14:46 GMT+02:00 William Francis <william.francis.james at gmail.com>
> Also after finding the base template files I needed to copy them to this
> location:
> /var/www/geonode/static/geonode/css
> On Thu, Jun 18, 2015 at 6:29 PM, William Francis <
> william.francis.james at gmail.com> wrote:
>> Thank you GC-45
>> Yes, that helps.
>> The geonode is already deployed. I am following the documentation for
>> Customizing the look and feel of the Geonode
>> https://geonode.readthedocs.org/en/1.2/deploy/customize.html
>> On Thu, Jun 18, 2015 at 4:21 AM, GC-54 <nepanode at gmail.com> wrote:
>>> First things first - when making reference to documentation please
>>> provide a link to where you encountered this as there is a developers
>>> customization and admin customization depending on how you've deployed
>>> geonode...
>>> Second tip is to use these linux commands when looking for a file or
>>> directory:
>>> $ sudo updatedb
>>> $ sudo locate {name} | less
>>> *Those two lines will usually do the trick if your looking for a
>>> specific file or directory just replace {name} with whatever file/dir/path
>>> your looking for...
>>> *But for what you're looking for the directory geonode is deployed her*
>>> e:
>>> /usr/local/lib/python2.7/dist-packages/geonode/templates/
>>> ?Did you already setup your geonode=project within a virtualenvironment?
>>> On Wed, Jun 17, 2015 at 8:54 AM, William Francis <
>>>> Hello,
>>>> I am following the Customizing the geonode instructions and looking for
>>>> the template files to copy to etc/geonode/templates
>>>> e.g.
>>>> /var/lib/geonode/src/GeoNodePy/geonode/templates/index.html
>>>> However the directory  /var/lib/geonode/ doesn't exist.
>>>> Where can I find a copy of these templates?
>>>> I am using v*ersion 2.4b25*  of geonode.
>>>> Thank you.
>>>> Will
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150618/ecaf313c/attachment.html>
More information about the geonode-users mailing list
