[GeoNode-users] How to import postGIS table into GeoNode & update metadata?
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jun 18 06:11:44 PDT 2015
Hi you can publish in the GeoNode's geoserver all the data from postgis the
run the command "geonode updatelayers" to register them in geonode. For the
metadata you can either edit them one by one through the geonode interface
or create a python script that does that for you using the geonode django
models.
hope this helps
2015-06-18 12:37 GMT+02:00 KhunSanAung <khunsanaung.gis at gmail.com>:
> Hi All,
> In the geonode, there is an interface where users can upload shape files
> into geonode.
> For my case I have tens of files, (nearly hundred files) to upload to
> GeoNode server.
> My data are in the postGIS format in local computer (hundreds MB).
> I don't want to upload one by one manually.
> *Question 1 : Is there a way to feed postGIS tables directly to GeoNode?*
> Not just importing tables into geonode database but the layers should
> appear for users in the GeoNode CMS view.
> *Question 2: If it is possible, how can I update the metadata for layers
> where the differences in metadata are in the file name and the categories
> only.*
> The rest fields are the same. What method I should use to update the
> metadata in GeoNode?
> ​Thank you very much for any help.​
> Have a nice day!
> *Mr. Khun San Aung*
> * <http://geoportal.icimod.org/>*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150618/91649cd8/attachment-0001.html>
More information about the geonode-users mailing list
