[GeoNode-users] Making Harvesting in a dedicated server PyCSW from catalogs CSW in GeoNode servers
Davi Custodio davicustodio at gmail.com
Fri Jun 19 11:22:08 PDT 2015
Hello. I have a scenario consists of 8 GeoNode servers with their
respective PyCSW assets.
To test, Getrecords use as:
http://localhost/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary
and receive the corresponding xml correctly.
You can also configure the harvest within the Geonetwork using:
http: // localhost / catalog / csw version = 2.0.2 & request =
GetCapabilities & service = CSW
and also the harvest runs properly.
I created a dedicated server with the default installation of PyCSW 1.10.0,
and I'm trying to get this server collect all the metadata records of 8
servers GeoNode.
My intention is to have a PyCSW to gather all the metadata of my
organization. I'm avoiding using "federatedcatalogues" because I do not
want the user who will rep csw need to specify additional parameters.
In a first test, I used the command:
pycsw-admin.py -c -u post_xml http: -x //localhost/pycsw/csw.py
/var/www/html/pycsw/bin/request.xml
where request.xml =
<? Xml version = "1.0" encoding = "UTF-8"?>
<Harvest xmlns = "http://www.opengis.net/cat/csw/2.0.2" xmlns: ogc = "
http://www.opengis.net/ogc" xmlns: gmd = "http: // www .isotc211.org / 2005
/ gmd "xmlns: ows =" http://www.opengis.net/ows "xmlns: xsd ="
http://www.w3.org/2001/XMLSchema "xmlns: dc ="
http://purl.org/dc/elements/1.1/ "xmlns: dct =" http://purl.org/dc/terms/
"xmlns: gml =" http://www.opengis.net/gml " xmlns: xsi = "
http://www.w3.org/2001/XMLSchema-instance" xsi: schemaLocation = "
http://www.opengis.net/cat/csw/2.0.2 http: //schemas.opengis .net / csw /
2.0.2 / CSW-publication.xsd "service =" CSW "version =" 2.0.2 ">
  <Source> http: // http: //demo.geonode.org//catalogue/csw </ Source>
  <ResourceType> http://www.opengis.net/cat/csw/2.0.2 </ ResourceType>
  <ResourceFormat> application / xml </ ResourceFormat>
</ Harvest>
pointing to http: // http: //demo.geonode.org//catalogue/csw ..
I get the following error:
<? Xml version = "1.0" encoding = "UTF-8" standalone = "no"?>
<! - Pycsw 1.10.0 ->
<Ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" xmlns:
inspire_common = "http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:
atom = "http://www.w3.org/2005/Atom" xmlns: xs = "
http://www.w3.org/2001/XMLSchema" xmlns: dct = "http://purl.org/dc/ terms /
"xmlns: ows =" http://www.opengis.net/ows "xmlns: apiso ="
http://www.opengis.net/cat/csw/apiso/1.0 "xmlns: gml =" http: //
www.opengis.net/gml "xmlns: diff ="
http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ "xmlns: xlink ="
http://www.w3.org/1999 / xlink "xmlns: gco ="
http://www.isotc211.org/2005/gco "xmlns: gmd =" ​​
http://www.isotc211.org/2005/gmd "xmlns: rdf =" http: //
www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
http://www.isotc211.org/2005/srv "xmlns: ogc =" http: //www.opengis .net /
ogc "xmlns: FGDC =" http://www.opengis.net/cat/csw/csdgm "xmlns: inspire_ds
=" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns : csw = "
http://www.opengis.net/cat/csw/2.0.2" xmlns: xsi = "
http://www.w3.org/2001/XMLSchema-instance" xmlns: the = "http: //
a9.com/-/spec/opensearch/1.1/ "xmlns: soapenv ="
http://www.w3.org/2003/05/soap-envelope "xmlns: sitemap =" http:
//www.sitemaps .org / schemas / sitemap / 0.9 "language =" en-US "version
=" 1.2.0 "xsi: schemaLocation =" http://www.opengis.net/ows
http://schemas.opengis.net/ows
/1.0.0/owsExceptionReport.xsd"><ows:Exception ExceptionCode =
"NoApplicableCode" locator = "service"> <ows: ExceptionText> Exception: the
document is not valid.
Error: Element '{http://www.opengis.net/cat/csw/2.0.2}Source': 'http: //
http: //demo.geonode.org//catalogue/csw' is not a valid value of the atomic
type. 'xs: anyURI' </ ows: ExceptionText> </ ows: Exception> </ ows:
ExceptionReport>
Done
when I point to one of my GeoNode-PyCSW servers using request.xml as:
  <Source> http://aguai.cnpm.embrapa.br/catalogue/csw </ Source>
</ Harvest>
pointing to my server: http://aguai.cnpm.embrapa.br/catalogue/csw
I get the error:
Initializing static context
Executing HTTP POST request /var/www/html/pycsw/bin/request.xml on server
http: //localhost/pycsw/csw.py
"NoApplicableCode" locator = "source"> <ows: ExceptionText> Harvest
(insert) failed: ERROR: null value in column "identifier" violates not-null
constraint
DETAIL: Failing row contains (null, csw: Record,
http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-19T15: 19: 28Z & lt;
ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" ...
Missing keyword: service, null, null, null, null, null, null, null, null,
null, null, null, null, null, null, null, null, null, null, null, null,
http://aguai.cnpm.embrapa.br/catalogue/csw, null, null, null, null, null,
null, null, null, null, null, 'keyword': 2 'miss': 1' servic '3, null).
. </ Ows: ExceptionText> </ ows: Exception> </ ows: ExceptionReport>
Done
Can anyone help me explaining how to best implement it? And because of
errors?
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150619/ffc6a394/attachment.html>
More information about the geonode-users mailing list
