[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2 LTS
Natalia Queiroz queiroz.nati at gmail.com
Tue Jun 30 07:14:33 PDT 2015
Thanks Jeffrey.
After the installation I', facing an error when I try to create a superuser
$ geonode createsuperuser
  File "/usr/bin/django-admin", line 5, in <module>
    management.execute_from_command_line()
  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
399, in execute_from_command_line
    utility.execute()
  File
392, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
261, in fetch_command
    commands = get_commands()
  File
107, in get_commands
    apps = settings.INSTALLED_APPS
  File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 54,
in __getattr__
    self._setup(name)
  File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 49,
in _setup
    self._wrapped = Settings(settings_module)
132, in __init__
    % (self.SETTINGS_MODULE, e)
ImportError: Could not import settings 'geonode.settings' (Is it on
sys.path? Is there an import error in the settings file?): No module named
geonode.settings
Any idea?
On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
> the release (2.0) is only on 12.04. You should use the snapshots ppa
> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
> update and sudo apt-get install geonode again.
> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <queiroz.nati at gmail.com>
> wrote:
> > Hello,
> > I'm trying to follow the quick reference guide to install geonode on my
> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
> Unable
> > to find the geonode package error message after the install command (sudo
> > apt-get install geonode).
> > There where the steps:
> > sudo apt-get install software-properties-common
> > sudo add-apt-repository ppa:geonode/release
> > sudo apt-get update
> > Any ideia?
> > Thanks
> > Natália Oliveira
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Natália Oliveira
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/16f9a2a9/attachment.html>
More information about the geonode-users mailing list
